Laptop upgrade advice try #2
  • Per Hansson
    • Jul 2005
    • 5895
    • Sweden
    #101
    Re: Laptop upgrade advice try #2
    I'm sorry RD but a metal spacer will not under any circumstance become thicker as it gets heated
    What it might become is slightly wider but that will be negligible at the temperatures we are talking about
    A metal spacer has another advantage btw, if made slightly too thick (in your case they should all be the same extra thickness of course)
    This will put some extra pressure on the BGA under the chips so that if bad solder was used it might make proper contact again...
    I have a crappy Acer here with that issue on it's ATI chipset, damn RoHs
    • PCBONEZ
      Grumpy Old Fart
      • Aug 2005
      • 10661
      Actually he's kind'a right.
      It will get 'thicker' when it heats:
      ... but to such a minute extent that it doesn't make a lick of difference.
      While were at it:
      The integral heat spreader on the IC chips gets thicker, the heat sink does too, and the retaining screws get a tiny bit longer.
      All of those will have much more total expansion than a thin-ass shim.
      - None of the above is enough to matter if it's properly assembled using a thermal compound.
      [Above -and- below the shim if a shim is used.]
      Thermal compound ALSO expands and contacts to keep full contact.
      That's one of the reasons it's used.
      You know, despite the fact that integral heat spreaders in IC chips do in fact expand and contract a TINY bit with temp changes I have yet to see one fall off a chip due to thermal stress cracking at the bond.
      - And they are way thicker than a shim, meaning there is more there to expand.
      Mann-Made Global Warming.
      - Dr Seuss
      • Th3_uN1Qu3
        Believe in
        • Jul 2010
        • 6031
        #103
        Originally posted by yyonline
        I don't know about the Linux drivers, but the Nvidia Windows drivers automatically vary the clock speed of the GPU as needed.
        Yes, and they produce some big ass DPCs when doing so... which screw up any realtime tasks, especially sound. It took me 2 damn months to figure what was doing it, the sound skips and stutters were driving me mad.
        It doesn't help that the two low power states are tuned so well that having Aero enabled switches between them every 30 seconds. I have created profiles for desktop and games, using the very-buggy-but-at-least-it-does-the-job nVidia Performance utility. That made life a lot better.
        A working TV? How boring!
        • Per Hansson
          • Jul 2005
          • 5895
          • Sweden
          #104
          What I meant was that it will expand more on the sides than on the thickness
          On the thickness we are talking way less than 0.001mm
          On the sides maybe it would be 0.001mm maximum difference if heated from room temp to 90°C
          • PCBONEZ
            Grumpy Old Fart
            • Aug 2005
            • 10661
            I didn't think you were really confused, but the way you said it....
            For kicks I got the real numbers:
            Expansion Coefficient of copper: 9.3 x 10-6 in/in per 1F
            Assuming 100F temp rise: 70F [21C] to 170F [77C] = 100F
            Assuming a 1" dimension on the copper:
            .0000093 x 100F = .00093 inch
            => New dimension 1.00093", a gnat wouldn't notice the difference.
            So lets say the shim is .010 inch thick.
            Divide number for 1" by 100 to get number for .010" => .0000093 inch thicker.
            ~~ Whoop dee doo
            Dust is said to be .00002" in diameter so a particle of dust is twice as thick as the shim would change in 100F.
            - Dr Seuss
            • ratdude747
              Black Sheep
              • Nov 2008
              • 17136
              ~~ Whoop dee doo
              reason i brought it up was thermal expansion is the reason the nvidia series 8 bug happens in the first place. the epoxy could not resist and thermal expansion breaks the connections... it all comes down to a poor choice in epoxy.
              sigpic
              (Insert witty quote here)
              • toastygoodness
                • Jul 2005
                • 813
                how about making your own heatsink? your uni has a shop with mills right?
                jk with yeah, but i did make my own gpu heatsink in the shop, was kinda fun.
                • ratdude747
                  Black Sheep
                  • Nov 2008
                  • 17136
                  yes but i don't have classes that allow me access. back where I used go to high school in west lafayette, I had full access to a shop (I was one of the best machinists in the school)
                  biggist issue is the lack of mountpoints to mount heatsinks with.
                  sigpic
                  • toastygoodness
                    • Jul 2005
                    • 813
                    what about with arctic ceramique? thermal glueish should be enough if the heatsink isn't intensely heavy
                    • ratdude747
                      Black Sheep
                      • Nov 2008
                      • 17136
                      yeah... but due tot he laptop's design, it would have to be passively cooled. this is quickly becoming a moot point... with the laptop inthis good of condition, I don't wanna f**k it up over a silly crazy mod.
                      It runs fine now, If it goes poof ill get a new mainboard.
                      sigpic
                      • dood
                        Deputy dood
                        • Mar 2004
                        • 2462
                        RD- my primary traveling laptop is a Dell d620 with the NVS 110M. We bought it used, and I've been using it heavily for 2 years with no problems.
                        Upgraded to 2gb of RAM, a 250GB 7200RPM WD Black drive, and Windows 7... I don't baby it, so it's a little beat up, but it performs flawlessly...
                        Ludicrous gibs!
                        • ratdude747
                          Black Sheep
                          • Nov 2008
                          • 17136
                          odd, i read the d620 had the problems too yet the nvs 110m is a 7300 based design. that is very odd.
                          sigpic
                          • Th3_uN1Qu3
                            Believe in
                            • Jul 2010
                            • 6031
                            #113
                            All nVidia mobile chips from 6000 series up to 8000 series have issues.
                            • ratdude747
                              Black Sheep
                              • Nov 2008
                              • 17136
                              UPDATE
                              I was trying debian out yesterday and well, dummy here mistyped some stuff and nuked the xp partition. (the debian partition trainwrecked later, thatls another story),
                              I ended up putting vista home premium 32 bit sp2 and fedora 15 x64 on it. even with aero, it runs well...
                              sigpic
                              • mockingbird
                                • Dec 2008
                                • 5484
                                #115
                                Let this thread die.
                                Don't use Debian, they're eons behind Ubuntu in their stable release, last time I checked.
                                • ratdude747
                                  Black Sheep
                                  • Nov 2008
                                  • 17136
                                  fyi it was debian testing... stable is equivalent to the ubuntu LTS releases.
                                  once gnome 3 and its dependencies escape experimental and move on to unstable (sid), it may be be worth trying again... right now, it is just too buggy.
                                  I did try ubuntu, it sucked. they still are dumping features onto their steaming pile without fixing half the bugs... and unity... FAIL.
                                  sigpic
                                  • ratdude747
                                    Black Sheep
                                    • Nov 2008
                                    • 17136
                                    It's almost been a year... and I have a major update.
                                    I saw this thread:
                                    https://www.badcaps.net/forum/showthread.php?t=19719
                                    and since my laptop was due for heatsink cleaning, I took a look... and To my surprise, it had a "10" chip in it. Combined with the fact that it had a 2010 dated HDD, I think that sometime in 2010 it bombed the GPU and was refurbed under warranty anfd it was given a new board with a "fixed" gpu (good underfill).
                                    What a relief...
                                    On a side note, I also upgraded the RAM in it... I happened to have a $20 Fry's gift card and I used it for a 4gb PC2-6400 kit... What an improvement (no more swap area slowdowns).
                                    sigpic
                                    • mockingbird
                                      • Dec 2008
                                      • 5484
                                      #118
                                      It doesn't matter... nVidia never fixed the underfill/lead issues with any of their chipsets... They simply just stopped making them.
                                      • ratdude747
                                        Black Sheep
                                        • Nov 2008
                                        • 17136
                                        Whatever. the chip looked to be in good condition (no underfill cracks or the like) and it has been very stable... I read that the lead issue was never fixed but the underfill issue was unoficcially fixed; many repairpeople have noted that while many 08 and 09 chips have died, they have not seen any 10 chips with underfill issues.
                                        sigpic
                                        • mockingbird
                                          • Dec 2008
                                          • 5484
                                          #120
                                          It's not just the underfill... It's also the design and the lead composition... The chips weren't engineered properly in the first place to dissipate heat properly, and they used an inappropriate combination of solders for the leads and contacts. The undefill issue you're talking about is that the one they used was too "tacky" and wouldn't allow the die to "float" under high heat... I don't think you'd see the underfill cracking, there'd just be massive internal chip damage that you wouldn't see.
                                            Microsoft Surface Laptop 3 13.5-inch i5/8GB/256GB SSD Laptop Platinum Notebook Specification for Upgrade or Repair
                                            This specification for the Microsoft Surface Laptop 3 13.5-inch i5/8GB/256GB SSD Laptop Platinum Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Surface Laptop 3 13.5-inch i5/8GB/256GB SSD Laptop Platinum boardview and Surface Laptop 3 13.5-inch i5/8GB/256GB SSD Laptop Platinum schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from...
                                            09-06-2024, 09:30 PM
                                            Microsoft Surface Laptop Surface Laptop 2 Notebook 2 Specification for Upgrade or Repair
                                            This specification for the Microsoft Surface Laptop Surface Laptop 2 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Surface Laptop 2 boardview and Surface Laptop 2 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
                                            09-06-2024, 08:47 AM
                                            Microsoft Surface Laptop Surface Laptop 4 Notebook 4 Specification for Upgrade or Repair
                                            This specification for the Microsoft Surface Laptop Surface Laptop 4 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Surface Laptop 4 boardview and Surface Laptop 4 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
                                            09-07-2024, 06:11 AM
