Photo watermarking
  • stevo1210
    • Oct 2006
    • 4156
    Photo watermarking
    I'm looking for some software to watermark my photos that I take before I upload to the internet, but everything I find is well... purchased software. Are there any free alternatives (open source even) out there that I can use?
  • brethin
    • Dec 2008
    • 1907
    Re: Photo watermarking
    Really annoys me when people do this to pics but I will help you out.
    Try
    http://www.picture-shark.com/waterma...ry_default.htm
    I have used it a few times and it works great. I do not use it often because photos with watermarks tend to block/distort the pic.
    Sellers on Ebay that do this to their pics are the most annoying because they often do it to hide a blemish.
    • Scenic
      o.O
      • Sep 2007
      • 2642
      http://www.watermark-image.com/default.aspx
      ^free for personal use
      otherwise, irfanview also has a function for that.
      just open a pic, draw a box with your mouse where you want the watermark to be, then "edit" -> "insert text into selection"
      http://bambooz.pytalhost.net/badcaps/watermark1.jpg
      http://bambooz.pytalhost.net/badcaps/watermark2.jpg
      • TheLaw
        • Jan 2011
        • 477
        Noooo...don't watermark. =P. If you are going to watermark, just a little in the corners is just as effective.
        I just use powerpoint if I need to. Pretty inefficient, but you can do some cool things in 2007/2010.
        • skalaukh
          Need a photo of the board dag3mpmbce0 rev. E
          by skalaukh
          Good day, I need a photo of the board or a photo of the BIOS flash drive binding
          07-21-2025, 02:51 AM
        • rstrube
          ViewSonic Pf815 (branded as P225f) Horizontal Deflection Issues - Running out of Ideas
          by rstrube
          Note: apologies I initially posted this request for help in the wrong forum! I am reposting it here and will take down the original posting.
          Hi Everyone,
          I've been working on repairing this beautiful CRT monitor off and on for the past several months and I'm really at a loss for what might be causing the problem.
          Unlike other common Horizontal Deflection issues which result in a steady vertical line, when I turn the monitor on, there is a pulsing (somewhat segmented) vertical line. I've attached a photo that shows the issue (difficult to capture without video)....
          Yesterday, 01:37 PM
        • rstrube
          by rstrube
          Hi Everyone,
          Unlike other common Horizontal Deflection issues which result in a steady vertical line, when I turn the monitor on, there is a pulsing (somewhat segmented) vertical line. I've attached a photo that shows the issue (difficult to capture without video). The monitor itself is branded as a P225f, but it turns out that it's actually a Pf815 that has an Add-On smallish PCB that expands it to support...
          Yesterday, 12:19 PM
        • mitsu2k
          The Real Dangers of conductive glue.
          by mitsu2k
          I know many folks on this forum warn against conductive glue and suggest removing it immediately upon site. I'm here to vouch and say these people know what they are talking about. To be more accurate, the glue isn't intended to be and doesn't actually start out conductive. It gets conductive as it is heated by components that get hot. The glue starts out to be a light tan color but as it is exposed to heat, it gets darker and darker until it is a dark brown. I have found that it becomes conductive at the point that it reaches a light brown color on darker.
          Here is an experience I...
          04-16-2023, 06:29 PM
        • Davi.p
          Reduce the size of photos please..
          by Davi.p
          Hi all, i'm asking all to reduce photos to a more comfortable resolution before post, the better like around 2000x2000, otherwise many PC / Tablets / phones refuses often to load them or has strong defection... today's digital cameras integrated in phones especially are a mockery because them saves photos at enormous resolutions with much less the real definition, so reducing them is only a good deal.. THANKS!!...
          05-16-2024, 12:53 AM
