New Home Server
  • weirdlookinguy
    • Sep 2007
    • 1638
    New Home Server
    I'm setting up a headless torrent box/NAS/home server using a small Compaq Deskpro EN I recently got (traded my buddy a P4 machine for it). Specs:
    Pentium 3 700mhz
    512MB RAM
    300GB IDE HDD (Seagate 7200.10)
    I love this little Compaq, the form factor is excellent and the build quality is outstanding. My buddy has another one of these Compaqs that he has been using as a torrent box for almost two years now and it is running strong as ever.
    I am going to do what he did and set it up in a corner of the closet and let it run torrents 24/7. It will dump them into a large hard drive which will be accessible on the network.
    OS will be XP Pro, I will manage it through Remote Desktop, applications used will be uTorrent for torrents and Web GUI, Soulseek for mp3s.
    I did a test setup of the OS, I attached a screenshot of how the box looks through remote desktop. I like how everything turned out so I think I might use it how it is, even though it was just supposed to be a test setup.
    Right now I am getting write speeds of 23MB/s through gigabit ethernet when writing to the open network drive.
    Now here are my questions:
    1. Any neato stuff you guys do with a home server that runs 24/7? Cool applications, etc.
    2. If I add a cheap silicon image SATA card and pop a 1TB hard drive in there (along with the gigabit ethernet PCI card that's already there), will the PCI bus start choking and ruin my 23MB/s upload that I'm getting now?
  • Scenic
    o.O
    • Sep 2007
    • 2640
    Re: New Home Server
    small private game servers, FTP, VPN, ...
    if the motherboard supports large HDDs (which it seems to do .. at least 128+GB), you could use a IDE->SATA converter. they're transparent to the software and the only real drawback is that they hurt the performance a bit. (my 1TB WD runs about 8MB/s slower on a converter compared to a real native SATA port ... which is next to nothing in a PIII box considering this HDD gets 90MB/s average)
    http://cgi.ebay.com/310202707992
    http://cgi.ebay.com/260753964629
    • Uranium-235
      Comrade Glimmer
      • Aug 2007
      • 5042
      • US
      Re: New Home Server
      your pci bus runs waaay faster then that
      personally...I would prefer you at least get a fake raid card and run a mirror array, or get a HBA and run linux raid. with ext3 compression i'm pulling about ~70MB from my server, 1tb drives in linux raid 1
      I have no camera to show you my server
      its a dell poweredge 700, if that helps
      • PCBONEZ
        Grumpy Old Fart
        • Aug 2005
        • 10661
        Re: New Home Server
        I would get your hands on a 3Ware 9500 Series RAID card in low profile.
        It's PCI-X but all you need to do is put some electric tape over the extra pins and it will work in a regular 32-bit 5v PCI slot.
        [The 9550 and up series' do NOT work in 5v slots.]
        The 4-port 9500SX cards aren't so pricey anymore.
        You are getting ripped off if you spend over $40.
        They are hardware RAID and supported in both Linux and Windows.
        Mann-Made Global Warming.
        - Dr Seuss
        • PCBONEZ
          Grumpy Old Fart
          • Aug 2005
          • 10661
          Re: New Home Server
          9500S-4LP & 9500SX-4LP
          - same card.
          The SX is lead free.
          LP = Low Profile.
          There are also 8 port cards in low profile (-8LP).
          - Dr Seuss
          • weirdlookinguy
            • Sep 2007
            • 1638
            Re: New Home Server
            That 3ware card sounds really good. I have a silicon image fakeraid card laying around already but if I find the performance unsatisfactory, I will track down one of those 3ware cards.
            I spent 4 hours crawling around in the attic yesterday and got this server rolling. There was an unused 120v line just laying there in the attic, it was coming out of the junction box that feeds the attic light so I figured it was safe for some low-wattage use. I wired it up to an outlet (inside a romex box, securely mounted to a ceiling beam, and not the backstab type) and ran a power strip down into my closet. Then I ran a phone line for the DSL modem, and a 50ft Cat5e line directly to my desk. The rest of the house runs on wifi.
            Result: my server and everything internet-related is tucked away in its own little corner in the closet with an ethernet cable running direct to my desktop. It looks really nice and clean. I attached 4 pictures so you guys can see where I stashed the server away. I'm really happy with how it turned out.
            Photo 1: from afar
            Photo 2: zoomed in
            Photo 3: closet door opened
            Photo 4: close-up of the setup
            • ratdude747
              Black Sheep
              • Nov 2008
              • 17136
              Re: New Home Server
              hint: pIII+fakeraid= FAIL.
              i tried it with a 533mhz k6-2 with 768mb ram. and a via card. the array wasn't being booted (network share) and it still sucked the living life out of the computer. SLOW!!! it even ran win 2k like a turd.
              i'd imagine a pIII would not be any better.
              see if you can find a cheap and fast 3ware card on fleabay... i found one for $12 for my server.
              sigpic
              (Insert witty quote here)
              • Uranium-235
                Comrade Glimmer
                • Aug 2007
                • 5042
                • US
                Re: New Home Server
                l-i-n-u-x
                • ratdude747
                  Black Sheep
                  • Nov 2008
                  • 17136
                  Re: New Home Server
                  duh... but he don't like linux...
                  sigpic
                  • brethin
                    • Dec 2008
                    • 1907
                    Re: New Home Server
                    My opitplex 110 (which is smaller than the deskpro EN) does fine with a P3 1k and 512 ram for a home server (running win 2k), it also runs a printer for network and a magic jack. I stream in HD to my tv from it via my MCE PC all the time and never see any chopping or skipping with no raid (just a IDE drive).
                    I guess it might be slow if your accessing it from more than 1 PC at a time but as a home server that is not likely to happen unless you all hate each other and each need to do your own thing alone all the time.
                    • PCBONEZ
                      Grumpy Old Fart
                      • Aug 2005
                      • 10661
                      Re: New Home Server
                      PIII is a hell of alot better than socket 7.
                      - Dr Seuss
                      • weirdlookinguy
                        • Sep 2007
                        • 1638
                        Re: New Home Server
                        I put a 1TB WD Caviar Green in there today, along with the fakeraid card. I flashed the BIOS of the fakeraid card (Silicon Image 3512) to take the raid out of fakeraid and make it a regular IDE card. Then I loaded up XP. The system feels snappy and I am still getting the same 23MB/s sustained speeds across the network. I think the fakeraid card is staying.
                        • weirdlookinguy
                          • Sep 2007
                          • 1638
                          Re: New Home Server
                          Also, I considered Linux but I just want this thing to torrent and host files on the network. Not worth tinkering around endlessly w/ Linux for such a simple setup IMO.
                          • ratdude747
                            Black Sheep
                            • Nov 2008
                            • 17136
                            Re: New Home Server
                            if it ain't in fakeraid mode, you will be fine. raiding things with it causes the real problems.
                            sigpic
                            • Scenic
                              o.O
                              • Sep 2007
                              • 2640
                              Re: New Home Server
                              agreed. i only use those cheapo software-raid cards as normal IDE/SATA controllers. it's usually called JBOD (Just a Bunch Of Disks) mode on a lot of them
                              • ratdude747
                                Black Sheep
                                • Nov 2008
                                • 17136
                                Re: New Home Server
                                funny, thats what mode crippled the k6-2.
                                sigpic
                                • Scenic
                                  o.O
                                  • Sep 2007
                                  • 2640
                                  Re: New Home Server
                                  anything cripples a socket7 sys..
                                  my K6 II 550 can't keep up with a PII 400
