Ratdude's first true server?
  • ratdude747
    Black Sheep
    • Nov 2008
    • 17136
    i might have finally made something that can be called a server (as opposed to my last unit, which was a combo web browser).
    My old RIMM job has been given a makeover...
    what I have for it now is one of my favorite builds to date.
    specs:
    Intel vc820
    PIII coppermine 800EB
    512mb pc600/700 rambus
    s3 savage 4 agp (32mb?)
    3com 10/100 LAN card with WOL cable
    2x 320gb 7200RPM wd blue ATA + 3ware hardware raid card
    52x cdrom
    zip 100
    AGI 300w psu (ATX 1.0)
    the case is perfect for it... It is a foxconn made side saddle'd PSU case.
    what makes the case nice is that the whole motherboard tray and card bracket mounts slide out the back on a set of rails.
    I modded the case... I added a daughterboard to the tray. what it does is allows me to put all of the front I/O (pwr/hdd lights, pwr/reset switches) on one connector and break it out to individual pairs. that way to slide oput the tray, i only have one connector for that instead of 5 (the PC beep is on the board as well). The board also has the same switches and LED's the front of the case has to make diagnostics faster.
    For an OS, it has ubuntu server edition 10.04.2 on it. my goal is to make it a fully headless server so all it needs is power and a network cable (and a keyboard if auto login is not possible)
    i do have a question:
    the RAM is a mix-match of a pc600 stick and a pc700 stick. the board will do up to pc800. I found this for $7.99 a pop. they are 256mb pc800 ECC chips. my board is good for two. I also think my setup will do ECC.
    would a speed boost (from 600 to 800) and ECC be worth it?
    no pics now... my camera is playing dead again and I do not know if it will come back. Once i have access to a camera, expect pics.
    any other comments?
    sigpic
    (Insert witty quote here)
  • Th3_uN1Qu3
    Believe in
    • Jul 2010
    • 6031
    Re: Ratdude's first true server?
    I expected it to be a dual.
    A working TV? How boring!
    • Topcat
      The Boss Stooge
      • Oct 2003
      • 16956
      What will this machine be serving>?
      <--- Badcaps.net Founder
      Badcaps.net Services:
      Motherboard Repair Services
      http://folding.stanford.edu/
      Team : 49813
      Join in!!
      Team Stats
      • ratdude747
        Black Sheep
        • Nov 2008
        • 17136
        for now, files. maybe more in the future
        sigpic
        • ratdude747
          Black Sheep
          • Nov 2008
          • 17136
          don't have a dual that would fit. I have one but it uses 4 slots sdram (though a rdram converter) and it uses two slot 1 coppermines (i used to use a pair of 733's) and is eatx (not the notched kind that would have fitted my case).
          if it bothers you too much, you could always gift me one
          sigpic
          • Topcat
            The Boss Stooge
            • Oct 2003
            • 16956
            For a file server on a home network, a dual really isn't necessary. Fast drives on a good controller are what make a file server shine. They don't require a lot of CPU horsepower, the P3 is more than plenty.
            Team : 49813
            Join in!!
            Team Stats
            • toastygoodness
              • Jul 2005
              • 813
              sounds good for a file server. P3 is plenty, especially with that hardware 3ware card.
              • Uranium-235
                Comrade Glimmer
                • Aug 2007
                • 5042
                • US
                You might want to think about getting a decent gigabit card and a gigabit switch for a fileserver.
                • ratdude747
                  Black Sheep
                  • Nov 2008
                  • 17136
                  if i had the $$$
                  sigpic
                  • NxB
                    • Feb 2009
                    • 1595
                    ebay... that stuff is cheap. especially older server stuff.
                    • ratdude747
                      Black Sheep
                      • Nov 2008
                      • 17136
                      whatever... my 10/100 does fine. to make use of the 1000 advantage i would need a a gigabit router and 2 or 3 gigabit switches.
                      sigpic
                      • Uranium-235
                        Comrade Glimmer
                        • Aug 2007
                        • 5042
                        • US
                        how big is your network? is your server really that far from your main computer?
                        • ratdude747
                          Black Sheep
                          • Nov 2008
                          • 17136
                          my room has the router. the parent's office has a switch. between the two is another switch. the server is tied to the middle switch... and my parents will bed backing stuff up on the server as well as myself.
                          sigpic
                          • NxB
                            • Feb 2009
                            • 1595
                            All daisy chained up like that?
                            • ratdude747
                              Black Sheep
                              • Nov 2008
                              • 17136
                              yes. to save the amount of cable needed for runs.
                              sigpic
                              • Pyr0Beast
                                • Feb 2009
                                • 406
                                Better than mine -> Old compax desktop
                                P3 933, 512MB ram, Integrated Intel Graphic card which causes kernel panic on shutdown !
                                Added 4 port sata+esata controller and 1x1TB WD green HDD
                                It works for now and it is reasonably quiet.
                                Problem is only 10MB network traffic speed with Gbit cards - should fix that.
                                • Uranium-235
                                  Comrade Glimmer
                                  • Aug 2007
                                  • 5042
                                  • US
                                  I have a poweredge 700, two wd 1tb drives and a gigabit switch, with ext compression I can actually stream files from the hard drives faster then the speed of the drives themselfs
                                  • Uranium-235
                                    Comrade Glimmer
                                    • Aug 2007
                                    • 5042
                                    • US
                                    I actually also have a PE 1800, 1650, and a promise vtrak 15100 (picked up for $125 /w 8 good 200gb sata drives) >
                                    • NxB
                                      • Feb 2009
                                      • 1595
                                      Better slower and easier to cool than loud with 50 fans.
                                      • omega
                                        Troubleshooting of redundant F750E-S0 Dell PowerEdge Server
                                        by omega
                                        Hello all,
                                        as a beginner electronics hobbyist, after a few years I would like to place another post on this Forum section, given that I did not succeed in finding any useful advice among the other posts.
                                        Over the last years, I have been using a PowerEdge Dell Server with two redundant PSUs, namely the 750W F750E-S0 ones (aka 06W2PW). Unfortunately, last summer one of them failed (perhaps owing to an overheating), and the server had for working to take into account the other one only. Of course I opened and tried to troubleshoot the failed PSU, but each cap I tested seemed to...
                                        02-09-2024, 03:34 PM
                                        HP ZBook 15v G5 Mobile server 15v Specification for Upgrade or Repair
                                        This specification for the HP ZBook 15v G5 Mobile server can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 15v G5 boardview and 15v G5 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for HP ZBook 15v...
                                        09-06-2024, 11:39 AM
                                      • harp
                                        Comparing FreeNAS, FTP server, SMB server, multimedia server...
                                        by harp
                                        I thinking about some central LAN file server, on where I can put some files from other devices, or access to them, and maybe play some movie without download...
                                        I never study this, but when I see that freenas need few gigabyte of ram to recommended working, some wiered partition, I wonder if I miss somewhat in the midletime...
                                        Also exist "turnkey file server", and other turnkey products that I can not distinguished what is major difference and how it perform - no experiance at all.
                                        What is general difference between this products, and what be most useful...
                                        01-04-2024, 02:44 PM
                                      • Fireballcz
                                        Windows 2016 server L2TP/IPsec VPN - two subnets
                                        by Fireballcz
                                        Hello, please how to properly configure VPN in this environment?
                                        I have two subnets in two different (geographical) workplaces, connected via IPsec (thru gateway routers)
                                        Main subnet: 192.168.11.0/24, gateway (router IP) 192.168.11.1, Windows 2016 server (VPN, DHCP, DC etc.) 192.168.11.3
                                        2nd subnet : 192.168.22.0/24, gateway (router IP) 192.168.22.1 - just client computers.
                                        I need to allow external (home office) users connect via VPN server (192.168.11.3) to the 2nd subnet (192.168.22.0/24) to their computers (via RDP).
                                        I have no problems with VPN connection...
                                        07-29-2022, 03:20 AM
                                      • ChaosLegionnaire
                                        optical drive tray loading problem
                                        by ChaosLegionnaire
                                        i started using a couple of my optical drives again to perform some testing and backup but to my disappointment, they have tray loading problems. both drives wont eject the tray and when i load the tray back, it auto ejects the tray again. it seems that the laser sled assembly in the drives wont drop down fully to the correct position to release the tray and the laser sled assembly wont extend back up to the proper position to lock and load the tray so it auto ejects the tray again.
                                        i tried lubricating the gears in the tray loading mechanism and the tray sled rails but it didnt...
                                        02-26-2019, 02:07 PM
