Shuttle SS59G V2- BIOS won't update
  • Maxxarcade
    • Jul 2006
    • 973
    Got an SS59G V2 here that I want to update the BIOS on. Got the AWDFlash and the BIOS from Shuttle's website, and AWDFlash keeps telling me the file's part number doesn't match the system. It has an FS59 V2 motherboard. Should I just force a flash?
  • Th3_uN1Qu3
    Believe in
    • Jul 2010
    • 6031
    Re: Shuttle SS59G V2- BIOS won't update
    If it says it doesn't match, it means it doesn't match. Find another one or leave it alone.
    I had to ask someone who had a programmer to reflash my BIOS chip after i made the same mistake on a friend's ECS board. Turns out ECS put the WRONG BIOS onto their site.
    A working TV? How boring!
    • Maxxarcade
      • Jul 2006
      • 973
      I figured as much. I really want to get it updated though, because the full screen logo is REALLY annoying when I'm trying to see what the POST says. I'm using the SS59U00T BIOS file, and it apparently is wrong.
      • Scenic
        o.O
        • Sep 2007
        • 2642
        hold TAB so see the POST instead of the logo.
        as soon as you see the POST, hit pause.
        BIOS seems to be the same for the FS59 and the FS59 V2 boards.
        http://download.shuttle.eu/Downloads...59G_V2.0/Bios/
        Bios file "ss59s00t.bin"
        ss59s00t.bin, size: 512 K, RELEASE version on 20070330
        This file can be used for the product(s):
        * Barebone SS59G
        * Barebone SS59G V2.0
        Original Download URL:
        http://image.shuttle.com/ResourceCen...p?file_id=7206
        Remark:
        Checksum: F500 Date: 04/18/06
        Patch Intel CPU support.
        Shuttle Inc. Taiwan http://www.shuttle.com - updated on: 29/06/2009
        edit: they also have a couple flash tools in the utilities folder.
        http://download.shuttle.eu/Downloads...2.0/Utilities/
        -> afudos, afuwin, winflash, awdflash
        • Maxxarcade
          • Jul 2006
          • 973
          That BIOS worked, however it still has the logo. It just gets to be a pain to do TAB and Pause all the time.
          I just bought a Pentium D 930 to try in the system. Should give it a nice performance boost. Too bad it only has AGP.
          • Scenic
            o.O
            • Sep 2007
            • 2642
            look around in the BIOS options.. most boards i've seen so far had an option to turn that crap off.
            Make sure you've got a good cooler on it..
            Pentium D = Pentium 4 Prescott x2
            worst of the worst heat/performance wise..
            • Maxxarcade
              • Jul 2006
              • 973
              No option to turn the logo off on this one... That's why they had a BIOS update. The U00T version had that as the only change LOL.
              The Pentium D 930 is 95W (65nm). Older ones were 130W, based on 90nm. The system is rated for 95W CPU's, but probably no higher. In fact the manual only lists up to Pentium D 920, but the 930 is identical in everything but the multiplier. Should work fine I suppose.
              • Scenic
                o.O
                • Sep 2007
                • 2642
                hm.. i might try some bios hacking like in the good old days (making hidden functions visible/working with bios editors.. sort of like what the "cheepo bios" did to the K7S5A way back when..)
                if the chip is soldered down or you don't wanna risk it tell me.
                otherwise i'd have to look for the tools in my backups
                • Maxxarcade
                  • Jul 2006
                  • 973
                  I'll check it tomorrow, but I think it's soldered in. I'll probably just end up selling it in the near future.
                  • Scenic
                    o.O
                    • Sep 2007
                    • 2642
                    hmm.. i've looked at both files with bios editors.
                    good thing you didnt flash the SS59U00T BIOS.. it seems to be the right one (apart from the BIOS ID being different), so a forced flash would've probably worked out allright, but they removed shitloads of options from the BIOS..
                    i then took the SS59S00T BIOS and edited it. made a couple hidden options visible and selectable again, and did what shuttle did with the "newer" SS59U00T BIOS and simply removed the logo/splash screen image completely, as there was no option to enable/disable that logo in the BIOS that i could un-hide and make selectable.
                    changes:
                    - boot splash screen / logo removed completely (attached to this post just for the heck of it )
                    - un-hid typematic rate settings (keystroke repeat settings)
                    - un-hid RAM settings "auto config" item
                    - onboard video memory default is now 32MB (instead of 128MB)
                    - un-hid "graphics engine clock" submenu (changing onboard GPU clockspeed now possible ; doubt it'll affect performance much (if it actually works that is))
                    - un-hid "IDE Burst Mode" setting
                    - un-hid USB Keyboard & USB Mouse support settings
                    - init display first is now defaulted to "AGP, then Onboard" (instead of PCI)
                    - un-hid CPU temperature shutdown submenu
                    PS: nothing has been removed from the edited BIOS (apart from the spash screen). Both BIOS files (SS59U00T and SS59S00T) are pretty much identical, so all shuttle did was remove the logo and hide a dozen or so options in the BIOS..
                    PPS: you should definitely recap the entire board for that Pentium D. shuttle is well known to use junk caps like OST and the like on their motherboards. and they still do in the brand new barebones
                    • Maxxarcade
                      • Jul 2006
                      • 973
                      changes:
                      Sweet, I'll see if I can test that tonight. Gotta love BIOS editors
                      I did have to replace several bad G-Luxon caps to get it running. I just contacted TopCat about making a cap kit for it, so I'll probably replace the rest too.
                      The worst part is, there are some bent pins in the CPU socket. They must not be too bad though, because it works fine. I might try to straighten them out a bit better though, if I can get a good magnifying glass and some small tools.
                      • Maxxarcade
                        • Jul 2006
                        • 973
                        The modded BIOS works great
                        Did you use the Award editor, or some other program?
                        • Scenic
                          o.O
                          • Sep 2007
                          • 2642
                          i used CBROM 1.98 to delete (and export) the .bmp splashscreen and MODBIN6 V2.03.02 (within DOSBox, as DOS software won't run at all in Win7 64Bit ) to un-hide the settings and edit some default settings (like the default amount of RAM used by the onboard video card)
                          both tools attached if someone wants to play around
                          • TheMartel
                            • Nov 2011
                            gone try this to.
                            Some news for the 930?
                            Looking for a P4 661 to upgrade my 630...
                            • mikeybass
                              by mikeybass
                              04-23-2025, 04:30 PM
                            • akwky
                              by akwky
                              Hi!
                              04-14-2025, 01:56 PM
                            • al3m0di
                              Update bios EFCN58WW to EFCN59WW
                              by al3m0di
                              Update bios EFCN58WW to EFCN59WW for solving The Connected AC adapter has a lower wattage than the recommended AC adapter
                              I have a Lenovo Legion 5 15imh05a device that I bought used online. It came with a 20V 8.5A 170W charger.
                              The BIOS version is EFCN58WW.
                              When I turn on the device, it displays the message:
                              "The Connected AC adapter has a lower wattage than the recommended AC adapter..."
                              The device rarely charges the battery, and even when it does, it doesn't show that it's charging.
                              I've tried
                              07-29-2024, 10:32 AM
                            • trix11
                              Dell Precision T1650 MT Workstation bricked after BIOS update
                              by trix11
                              I have a Dell Precision T1650 MT workstation (of the following spec.) that was bricked yesterday when attempting to update the BIOS from A27 to A28 per:
                              - https://www.dell.com/support/home/en...-t1650/drivers > Dell Precision T1650 System BIOS
                              - Dell Precision T1650 mid tower Workstation
                              - Xeon E3-1225 V2
                              - 32Gb PC3-12800E RAM
                              - 4Tb SATA HDD
                              - motherboard: Dell part: 0C3YXR CN-0C3YXR-72200-39C-01GR-A02
                              I see now that others have experienced like issues e.g.:
                              - https://www.dell.com/community/Prec...
                              10-24-2022, 10:35 PM
                            • Julian Bailey
                              BIOS update wont complete - Dell Latitude 7420
                              by Julian Bailey
                              Hi all
                              Anyone come across this issue where a BIOS flash will only part complete?
                              It will update the system BIOS and Primary EC BIOS fine but fails to update the Intel TBT Retimer, Intel TBT Retimer 2 and ME Firmware.
                              NVMe m.2 drive isnt detected in the BIOS, but you can get into the BIOS fine and it all works in there as intended.
                              The drive works fine in another laptop.
                              Link to a video I made of what its doing here:
                              Any ideas on how to overcome this?
                              Cheers...
                              06-02-2025, 01:39 PM
