Water Cooling?
  • bigbeark
    • Jan 2010
    • 661
    Water Cooling?
    Just wondered if anyone here has experimented with water cooling?
    How effective is it on flame-thrower Prescott CPUs?
    What sort of gear is out there? Is this strictly an extreme gamer application?
    What's the cost and do you need a special case etc?
    Are these setups completely silent?
    Thanks for your input.
  • Scenic
    o.O
    • Sep 2007
    • 2642
    Re: Water Cooling?
    i'd rather upgrade to a core-based system than spend lotsa money on watercooling.
    Used socket 775 stuff is cheap now because it's "outdated"..
    the smallest Core 2 Duo (E4300) will outperform most P4's.. and doesn't get nearly as hot..
    watercooling is not really only "extreme gamer" stuff. a lot of people prefer it because it's pretty quiet when set up right.
    strong points:
    - quiet (depends ; pump is usually the loudest part)
    - more effective than aircooling
    weak points:
    - expensive
    - needs careful & regular maintenance (water levels, anti-oxidization chemicals, leaks, ..)
    - if it leaks, you've got a BIG problem
    - takes up quite a lot of space
    there are also "hybrid" solutions with closed loops, like the Corsair H50 & H70
    they're not as effective as a "real" watercooling setup though..
    • dood
      Deputy dood
      • Mar 2004
      • 2462
      Re: Water Cooling?
      I agree... I wouldn't bother trying to water cool a Prescott at this point in life. Unless you _really_ like to tinker... it's simply not worth it.
      Ludicrous gibs!
      • Phaihn
        • Jan 2009
        • 842
        Re: Water Cooling?
        haha just do what i did run a tube made of old pop bottles out the window and bring in the cold night air or winter whare i am now.
        My Computer.
        AMD APU A4-3300 2.5ghz 1mb cache
        Motherboard GigaByte GA-A75M-S2V
        Kingston HyperX Blue DDR3 8GB (2x4GB)
        SB Audigy 2 ZS [B800] Sound Card
        500GB WD Caviar® Blue™
        1 Terabyte WD Caviar® Black™
        2 Terabyte WD Caviar® Black™
          20 year old Kenmore refrigerator ice maker bad water valve coil took a crap
          by sam_sam_sam
          I got lucky that when I got home and was about to get some ice out of the ice dispenser I hear and see water running down the outside of the ice dispenser what the heck is going on here
          At first I thought that the ice dispenser mold was cracked so I brought a new ice maker because this one has been in there for about 10 years now
          Well I put the new one in and wait and I wait for the water valve to open and let water in no such luck well there is a way to check the function of the motor and the water valve on this ice maker just need a jumper wire “L” to...
          04-09-2023, 08:04 PM
        • Ace Perception
          Samsung R530 Bremen motherboard cooling
          by Ace Perception
          I'm wondering if anybody out there has much knowledge of Samsung Bremen motherboards.
          I've got a Samsung R530 which is about 10 years old, over the last 12 months it developed a worsening problem where when asked to do much work it would shut itself down. I had a good idea this was due to overheating which was confirmed by a temperature monitor programme which showed little balls of fire next to the various internal temperature readings. I could also prevent it shutting down if I placed a huge fan running at full speed in front of its air intake!
          So I went in pursuit of...
          07-21-2020, 03:05 PM
        • Ugur87
          MacBook Air M4 A3240 Brand New Water Damage no Image
          by Ugur87
          I have a brand new 13.6-inch MacBook Air M4 that was only used for three days and now has water damage. A glass of water was spilled over it. I examined the motherboard and there was only water next to the display connector. I cleaned it with isopropanol and the components look clean. The MacBook obviously turns on and draws 20 volts from the power supply. The keyboard backlight comes on, but the display remains black. Where should I best start? Even when I shine a light on the display, I don't see any image. I have all the tools I need, including an infrared camera. Where should I best start?...
          08-28-2025, 01:09 PM
        • edugimeno
          Stagg sms12p audio amp has water damage
          by edugimeno
          Hi! My friend just brought this audio amplifier/speaker fro his music band saying they realized its got no sound. Led powers up but there no sound at all
          I opened it and found 3 board. 2 of them are for input plugs and potentiometers, and the other larger board has the amplifiers for 2 large speakers that it drives
          There's also a large toroid transformer that feeds a lower voltage to the first 2 boards and a larger voltaje (36x2 rectified close to 100v) to the power board. The power board has the plugs for both speakers
          There is only one signal wire connecting the first boards...
          05-24-2025, 06:00 AM
        • Hondaman
          Liquid cooling?
          by Hondaman
          I hope my computer does not randomly reboot while typing this. My main system is the AsRock 970A-G/3.1 motherboard with the AMD 8150 chip. I am experiencing FREQUENT and RANDOM reboots once the system is used for a couple of hours (sometimes it reboots before I even get to the Win7/Linux Mint dual-boot screen). The problem MIGHT be the DRAM controller chip (I recently upgraded to the maximum 64 GB RAM). It also might be the VRM chips. I am using a typical aftermarket CPU cooler, which does NOT blow air DOWN onto the VRM heat sink.
          (After previous generation hardware [Gigabyte] didn't...
          05-08-2025, 09:37 PM
