CF-18 Wacom Wobble
  • pentium
    • Mar 2006
    • 2778
    CF-18 Wacom Wobble
    I built my one working Panasonic CF-18 Toughbook from two units whose display assemblies were pretty much the same other than their input methods. One used a regular touchscreen, the other had a nice Wacom digitizer.
    I built my system with the Wacom but I'm having interference issues.
    In the center of the screen from top to bottom, everything is fine.
    From the left and right sides and going an inch inwards however the cursor wobbles left and right.
    If the pen is angled outwards from the screen, the wobble gets worse. If it's angled inwards, the wobble lessens or goes away.
    This makes calibration impossible and using scrollbars on fullscreen windows is a bitch.
    The first obvious thing to point out is that the screen assembly is metallic and on the left and right sides are the antennas for the wi-fi, bluetooth, and CDMA/3G which hide under black plastic covers. Currently the only used antennas are the main/aux wi-fi antennas which are placed on either side respectively. I can't see the wireless causing this (though I have not yet unplugged the antennas to check) and the CCFL inverter is at the top of the screen and isn't a source of notably worse interference. Seeing how nobody else has complained about this and I can't see how to change frequencies for the pen like on my Calcomp, the best I can think of is I somehow messed the transplant up somehow.
    No idea what I did though.
    Find Nedry!
    Check the Vending machines!!
  • classicandy
    HP EliteBook 1030 g2 Wacom Device error
    by classicandy
    Hi Everyone, I have this HP EliteBook X360 1030 g2 with the Wacom device not installing. Because of this, the Fingerprint, Touchscreen and webcam/Face ID devices are not working as well.
    If it is a hardware fault, which area on the motherboard should I focus on? There is no boardview or schematic so far.
    I have attached some pictures of the error it gives. I need help in solving this problem. Thanks...
    10-07-2022, 08:12 AM
  • kokono
    Wacom DTH-W1310
    by kokono
    I am looking for the correct BIOS for this model. i attached Original Bios .
    Thx...
    08-02-2024, 10:32 AM
  • Hornnumb2
    Extending the antennas on router.
    by Hornnumb2
    My router has 4 antennas, could I run some rg6 with BNC connectors and put the antenna say 30 feet away to get better coverage through my home? Thanks
    07-12-2022, 07:57 PM
  • SONY_E-WASTER
    WACOM CINTIQ 24HD DTK-2400 no power.
    by SONY_E-WASTER
    hello I have a Cintiq 24 hd dtk 2400 manufactured aug 2011.
    it has no power. Tested with known good power bricks. The green light on the power brick dims when connected to the Cintiq. this is a WACOM display that takes pen input for illustration and the like.
    I dissembled it and located the power input board and noticed a heat damaged component. (see pic)
    https://photos.app.goo.gl/87cwnc1mc8Yd1zES9
    it is labeled
    FR5305
    I*R 049P
    ZD 85
    I did an ebay search...
    02-02-2022, 06:42 PM
  • Bushcat
    Pioneer PL-X9 motor speed control wobble
    by Bushcat
    I'm starting to re-cap a Pioneer PL-X9 turntable, specifically the motor control board, because although everything tests out OK according to the service manual, the speed wavers slightly despite the quartz lock light remaining on. So, I've decided to re-cap that board since it's the cheapest next step...
    Pioneer's passive component naming convention is clear to me. For example, CSZA R22M 35 is tantalum, radial leads, 0.22uF, 20%, 35V.
    BUT there are two capacitors on the board which have actual Pioneer part numbers: PCL-042. I can tell they are 0.1uF, 16V but don't...
    05-24-2023, 03:36 AM
