touchscreen computer screen controls
  • Mr_Bodgit
    • Dec 2010
    • 47
    • doncaster
    i have 2 IEI ppc-5170gs touchscreen computers that i got for nothing as the screens were faulty and IT just bought new ones,
    one of them i have just sorted the ccfl's out and fitted a power supply so it runs on 12Vdc not 240Vac ready to put this in my mk1 astra (kadett-D) to playing music, films and using satnav etc.
    info on pc/screen
    http://www.ieiworld.com/product_grou...07365300198901
    but i have found there is no way of controlling the screen brightness except through the intel extreme 2 display settings (the motherboard has a LVDS Connector a bit like a laptop so no external screen controls as its driven from the MB)
    i created a normal mode and driving mode (brightness and contrast set to min) i can chande to driving mode by right clicking on the screen (well in my case holding finger on screen) and selecting different modes, but im unable to find a option to use a shortcut key to do this?
    anyone have any ideas so i can flip from one mode to another a bit quicker?
    or if there is a keyboard out there with a function button so left and right arrow keys (or up/down) work like on a laptop for screen brightness?
    Regs
    Rich
  • NxB
    • Feb 2009
    • 1595
    Re: touchscreen computer screen controls
    Usually the intel utilities have options for setting hotkeys. Beyond that all I can think of is finding another program that does automation and will make the changes when you run a script. Then you can just have 2 scripts and not have to click around manually.
    • Mr_Bodgit
      • Dec 2010
      • 47
      • doncaster
      checked intel hotkeys, theres rotate and bring properties up etc but no mode swapping keys!! or any way to add them, searched net but cant really find owt, will keep lookin tho
      Regs
      Rich
      • MapleS
        • Nov 2010
        • 7
        Replace the laptop keyboard. You can usually find one for less than $30 and they are easy to replace. Meantime, use an external keyboard.
        thanks your information.
        • Th3_uN1Qu3
          Believe in
          • Jul 2010
          • 6031
          Or use AutoHotkey. You can define your own hotkeys with that nifty scripting language and it only requires a few lines, you can do it in 10 minutes without any prior experience.
          A working TV? How boring!
          • Mr_Bodgit
            • Dec 2010
            • 47
            • doncaster
            nice one, haddy little tool is that!
            Regs
            Rich
            • Mr_Bodgit
              • Dec 2010
              • 47
              • doncaster
              it has no keyboard lol (it came from a steelworks and it was used to monitor a furnace's pressure supplies etc so only used touchscreen) i use the onscreen windows keyboard if i need to type owt, once its fitted in the car then it will have a small wireless keyboard with touchpad
              Regs
              Rich
              • Ryan.man
                by Ryan.man
                02-04-2025, 12:23 PM
              • reformatt
                by reformatt
                07-31-2025, 08:37 PM
              • Chrissygizmo
                by Chrissygizmo
                02-10-2025, 12:33 AM
              • spice_disc
                Vizio TV M50-C1 reboot cycle and static on screen
                by spice_disc
                I'm currently trying to diagnose and fix my Vizio TV (Model M50-C1). I've tried a number of different basic solutions, but I'm trying to determine if my issue is currently a failing panel, T-Con board, or main board (or something else entirely) and whether or not it is worth my time to fix it. Details of the issue and what I've tried are below as well as why I think it is either a bad panel, T-Con board, or main board.
                The Issue: The TV will be on and working fine but after the TV is on for ~5-10 minutes the screen will freeze (with sound continuing) until the TV reboots itself. While...
                09-08-2024, 02:37 PM
                Microsoft Microsoft Surface Laptop Studio - Slider - Core i7 11370H - Win 11 Pro - GF RTX 3050 Ti - 32 GB RAM - 1 TB SSD - 36.6 cm (14.4") Touchscreen 2400 x 1600 @ 120 Hz - Wi-Fi 6 - Platin - kommerziell Hybrid (2-in-1) Specification for Upgrade or Repair
                This specification for the Microsoft Microsoft Surface Laptop Studio - Slider - Core i7 11370H - Win 11 Pro - GF RTX 3050 Ti - 32 GB RAM - 1 TB SSD - 36.6 cm (14.4") Touchscreen 2400 x 1600 @ 120 Hz - Wi-Fi 6 - Platin - kommerziell Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Microsoft Surface Laptop Studio - Slider - Core i7 11370H - Win 11 Pro - GF RTX 3050 Ti - 32 GB RAM - 1 TB SSD - 36.6 cm (14.4") Touchscreen 2400 x 1600 @ 120 Hz - Wi-Fi 6 - Platin - kommerziell...
                09-07-2024, 04:10 AM
