What does this do?
  • backtrack
    • Nov 2010
    • 38
    What does this do?
    What exactly is this product used for? Looks intriguing.
    I came across this item while I was browsing on ebay. I have no idea what its use is. Hmm.. is that a female ATA interface I see? Sure looks like it. Could be smaller but hard to tell in the photo.
    http://cgi.ebay.com/IBM-LC-9533-Oper...item5884ded8b6
    they call, they telnet, I hangup, I laugh, I get hiccups and digital breakups.
  • yyonline
    • Jul 2009
    • 692
    Re: What does this do?
    According to google, LC/9533 is a Ternary Liquid Chromatograph. It appears to be a keypad for the same. Which is what the seller says it is.
    ATA interface? I doubt it; it just uses some sort of ribbon cable.
    Probably proprietary and not much use unless you have a ternary liquid chromatograph without a keypad.
    • backtrack
      • Nov 2010
      • 38
      It sounds like some sort of chemical device. Did not know IBM made such a thing.
      • PCBONEZ
        Grumpy Old Fart
        • Aug 2005
        • 10661
        IBM = International Business Machines.
        Been around over 100 years and they do or have done about everything.
        See page 4
        Mann-Made Global Warming.
        - Dr Seuss
        • Th3_uN1Qu3
          Dell XPS m1730 powers up only when it wants to
          by Th3_uN1Qu3
          I've got this really intriguing piece of hardware here. A Dell XPS M1730 with dual 8700M GT SLi. There was a label from 2010 underside the keyboard, and the video card PCB (what's visible of it, didn't take it apart) looks like it's been heated - it's likely been reballed back then.
          The trouble is that it doesn't power up. Or, to be specific, it doesn't power up fully. All voltages come up, but the red lights don't turn on the touchpad, speakers and screen frame, i only get the power light. Every once in a blue moon all the lights will come on and the machine will work fine. When...
          04-04-2013, 04:56 AM
        • TELVM
          Capacitor cooling - Heatsinks for caps
          by TELVM
          Thermal Management of Electrolytic Capacitors
          Cap Coolers
          This is an intriguing idea and I'm considering ghetto-modding my own homebrew version.
          What do you think of the concept?
          12-19-2013, 12:27 PM
        • fsangre
          "Shadows" on LCD screen. Mura effect?
          by fsangre
          Iยดm asking you for any help about a problem affecting both my NEC SpectraView 2490 and my NEC MultiSync 2490WUXiยฒ LCD monitors.
          Description of the problem:
          After a year - year and a half of use, both displays began to show irregularly shaped dark "shadows" on the right edge from top to bottom of the screen. At first they are not much annoying because they don't affect the main working area, so I tend not to care much about it; also somewhat reassured as I can see that they change over time and don't seem to be a permanent electronic nor mechanical problem...
          06-13-2014, 05:34 AM
