BIOS programming cards?
  • bigbeark
    • Jan 2010
    • 661
    I see that there are these cards where you can remove your bios chip and use the card to flash the latest Bios. Apparently, you can do this repeatedly.
    This solves the problem where you have aborted a Bios update and the board will now not boot.
    Of course, you can also now BIOS chips online for your specific board.
    Can anyone recommend a card or whether it's just better to buy a replacement BIOS chip.
    I have several boards that may have BIOS problems, which is why I am interested.
    Thanks in advance.
  • yyonline
    • Jul 2009
    • 692
    Re: BIOS programming cards?
    Unless it's something you do regularly, I'd say just buy a preprogrammed chip.
    I've had very good luck with this eBay seller: http://stores.ebay.com/bios-depot-2010
    Prices are a tad higher than average, but he's never sent me a dud. I'd glady pay the extra buck or two for the reliability and not having to ship things back and forth. I even had one case where that seller didn't have the model listed - I just sent him the model # of the chip and the .bin file, and he was able to flash a compatible chip properly for me.
    In my experience, bios updates don't often fail unless the power goes out mid-flash, or the chip is damaged. If the chip is damaged and won't take a new flash, an EPROM programmer isn't likely to solve that.
    If you're comfortable doing it, you can hotswap the bios out of another board and force flash it. This, of course, assumes that the bios chip is not soldered on the board, and that the two boards use the same socket and bios chip type. Check the chip type carefully. They may look identical, but could be different.
    • Agent24
      I see dead caps
      • Oct 2007
      • 4981
      • New Zealand
      I use a Willem EPROM v5 purchased from www.sivava.com, it's very nice for the price.
      -David VanHorn
        • 31094
        well just remember that not all bios's interface using the same method, most are LPC but not all.
        and most are PLCC package - soldered down.
        if your real unlucky it may be a 40pin TSOP package!
        i desolder PLCC and fit a socket to the board - then prog them in my 48xp beast.
        • bigbeark
          • Jan 2010
          • 661
          So I looked at the site. Questions: I assume this device connects to a working computer via a serial port or usb port. I assume that you attach whatever Bios chip you wish to program to the device. You start up the Willem Bios program on the computer and program the chip that you have attached to the programmer. I assume you download the BIOS code from the board manufactureres site and use this device to program your Bios chip.
          Advantage over flasing on-board is that if the on-board chip is already "bricked" by someone misflashing it, you can save the chip.
          Is this easy to use? Can you use the older type Bios chips where the chip has little legs that fit into a socket? Like most socket A and 370 boards?
          Also the machine comes in six different packages. Which did you choose and why?
          Thanks for this.
          • Agent24
            I see dead caps
            • Oct 2007
            • 4981
            • New Zealand
            It does the programming via Parallel port. The USB port is only there to provide a power supply.
            (it also has an external jack for power as well, which I think you have to use if you are programming really old EPROMs that require 21v to program etc)
            Yes, normally you take the chip out of the board and plug it into the appropriate socket, load the program and write your file (which you have to download from the website or read back from a working board if they only give you a stupid winflash with the BIOS image embedded in it or something)
            It will program most chips, the old ones (28 or 32 pin DIP) go in the green socket, the PLCC32 go in either of the brown sockets, depending on if they are Parallel or LPC\FWH.
            There is a list of supported chips on the website, you can also download the program for free, to check if your chip is in the list.
            It comes in different packages because each one contains different adapters. There are adapters for TSSOP, VSOP, SOIC etc - I chose the most basic package as I only need to program PLCC32 and DIP. If you want to do others then buy the one with the adapter you need - or just buy the basic package and then any additional adapters you may require.
            You can buy from www.Sivava.com or if in Australia, www.Darkwire.com.au is an official reseller. I would advise buying only from them or from Sivava's eBay store. A lot of people make cheap clones which don't work as well or aren't as good quality etc.
            I also saw a USB version here: http://www.mcumall.com/comersus/stor...namicIndex.asp but I don't know anything about that one (features or quality-wise) I assume it's basically the same thing but with a USB rather than Parallel interface.
            -David VanHorn
            • pfrcom
              Oldbie
              • Jun 2006
              • 1230
              If you do want to program a really old chip like a 27C512, be cautious about the Sivava offering
              It's in their compatibility list, but doesn't do the job
              First time I ever left someone negative feedback on eBay, because I asked specifically before purchase if it would work, and was assured it would
              Having said that, the Sivava product is very well built, and does do most contemporary chips I've tried - but then, so does my older Willem programmer, a BrandX purchased from Hong Kong a while ago
              And if you do run into problems, support for using the Sivava is pretty scanty - mine came with a single page, which sort of describes its jumpers, etc.
              Maybe MCU would be a better option for a buyer in North America, because as I recall, they have a forum providing some assistance
              The Willem programmers are to hardware what Linux is to software - each version has its own idiosyncrasies, and support groups, as always, are a mixture of noobs and experienced electronics people (many condescending)
              And if you knew enough to modify your Willem to fix a problem, you wouldn't have bought ready-made in the first place
              Back to the original question - with more and more boards having soldered BIOS chips, the Willem, or any other external programmer, has limited usefulness
              better to keep quiet and be thought a fool, than to open your mouth and remove all doubt
              • Agent24
                I see dead caps
                • Oct 2007
                • 4981
                • New Zealand
                I *think* I read about an issue with the older chips. Compatibility is not the problem - I think the problem is the power supply.
                I believe the Willem uses a DC-DC converter of some kind to increase the voltage but it's not very good or something, and you need a higher input voltage than 5v from USB.
                Yes most chips now are soldered in, but also, most chips now are serial versions which can be programmed in-circuit. (However you can build a much cheaper device than the Willem to do this)
                I did however successfully reprogram a PLCC32 EEPROM on a CD-RW drive in-circuit with a homebuilt adapter. It probably won't work in most cases but it worked there.
                Darkwire is probably a better place to get support for the Willem (since they sell the same one as Sivava)
                -David VanHorn
                • pfrcom
                  Oldbie
                  • Jun 2006
                  • 1230
                  For the 27C512, I used an external power supply with the Sivava - did as much homework as I could, before purchasing
                  I'm wary of trying to program in-circuit, after frying an expensive (in those days) Socket7 board while trying to rescue another
                  • Agent24
                    I see dead caps
                    • Oct 2007
                    • 4981
                    • New Zealand
                    Which version of the program did you use? Perhaps you needed an upgraded version? I downloaded a version which is newer than that which is on Sivava.com. I could send you a copy if you want.
                    I know, I was also advised against in-circuit programming like that. And I would advise against it too. But it was basically try that or throw the drive away (didn't have hot air rework at that time) so I gave it a try and luckily it worked perfectly!
                    -David VanHorn
                    • pfrcom
                      Oldbie
                      • Jun 2006
                      • 1230
                      Which version of the program did you use? I could send you a copy if you want.
                      Version 0.98D5 - thanks for the offer, but I assumed new software versions were more likely to be flakey for older hardware support
                      The one I covet is the MSI TL46 Service Kit, mentioned by Rainbow in this forum
                      Judging by a Google, the TL46 was only available in East European countries
                      Unfortunately Rainbow's last visit was June 2008 - his posts were always worth a read
                      • testaccgta
                        Unable to verify IC or write/erase/flash BIOS file to XMC QH128AHIG SPI chip using NeoProgrammer/AsProgrammer
                        by testaccgta
                        Hi, everyone!
                        I've recently acquired two brand new SPI chips to replace the one currently in my Acer A514-54G laptop MB (FH5AT LA-K092P). The reason why I'm replacing the current SPI chip is because I had some difficulties with a third-party IT assistant who pretty much lacked the soldering skills and ended up destroying the current SPI chip soldered to my MB from factory.
                        I've decided to do this on my own because I spent the past month or so learning some soldering skills and BIOS modding through Badcaps and WinRaid forums, hence the attempt. I've also chosen to buy...
                        09-01-2024, 08:24 PM
                      • elzorroazul777
                        Did I Screw Up? Any Hope for Success? Programming BIOS CHIP
                        by elzorroazul777
                        Before I go further down the rabbit hole, I'd like to know if I have created a dead-end in my repair process. I am attempting to reflash my Lenovo X1 Extreme Gen 2's BIOS chip after a power interruption corrupted the BIOS data during an update.
                        I do not have backups of the data I pulled off the chip using a CH341A 24 25 Series EEPROM https://www.amazon.com/Organizer-Soc...Q%3D%3D&sr=8-5
                        I also wrote to the...
                        10-09-2022, 10:45 AM
                      • DynaxSC
                        ASRock B650M PRO RS - BIOS CHIP 25Q256JW BLOCKED BY STATUS REGISTERS
                        by DynaxSC
                        Hi
                        I have then desoldered the chip, backupped the contents, and tried to earease the chip in order to program stock image, but the chip is locked by status registers SREG2 (TB) and SREG6...
                        08-04-2025, 12:20 PM
                      • inck243
                        Acer e15-e5-576g-5762 bricked. Bios chip won't interface in AsProgrammer.
                        by inck243
                        Thanks for any help. The board version is DAZAARMB6E0 REV: E. The bios chip is winbond 25Q64JVSIQ1736. W25Q64JV is not available in AsProgrammer -- only BV CV FV or FW_1.8c. The chip won't interface with asProgrammer and a CH341A. When I have this chip on the board, the laptop will not post but when I plug it in to power, the blue LED lights up, also the orange when the battery is connected. When I push the power on button, keyboard backlight turns on and the fan starts briefely then turns off. But I can't do anything to program this bios chip so I bought another one.
                        The BIOS...
                        07-25-2024, 09:17 AM
                        Common SPI bios chip programming Questions and Answers
                        by SMDFlea
                        Q: I have a bios request,i can`t post my backup as i can`t read from the chip.
                        A: If you can`t read from it how do you expect to write to it ?.
                        Q: Why is my bios chip unreadable ?.
                        A: The programmer is faulty or has a worn or broken zif socket.
                        The USB cable is frayed,connector pins worn or some other physical damage.
                        Not enough amperage or voltage to power the programmer properly.
                        Bad...
                        09-02-2021, 04:40 PM
