Market Place hypertect find
  • The-Pump-Man-Dan
    • Oct 2022
    • 8
    Hey Guys Need some help or info on a little project i got.
    So I have an 05 Dodge Ram 1500 the Rumble Bee i am the 2nd owner of the truck so I thought I would do a little tunning on it since I don't think it ever seem premium gas I got in market place and looked for a use tuner and bam there it was Hypertech Max Energy guy was asking 200 checked the price 450 new so why not drove to pick it up and asked the guy if he had unmarried it from his jeep he said i know nothing about it I explained he needs to set his car back so i can use it on mine nope not goanna do it cause the after market wheels well i already knew how to delete the info off the SD card inside so I talked the guy down to 50 bucks for the thing I got it home it was saying it needed a firmware update done that got out to my truck plugged it in got a code to call tech support and i did found out some one tried to hack this tuner in 2016 Hypertech got a report of it so they shut the whole thing off now i have been able to get the program for the tuner downloaded but every time i hook the tuner up it gives me a error description not found or something like that can yall hell a green horn out and get this thing fixed up so i can make this Himi run
    • Jul 2011
    • 6070
    Re: Market Place hypertect find
    This might be a case where if someone was trying to use something that has a subscription service and then someone removed it and it interface with the computer on the car and it is looking for this information you might be out of luck because car stereo theft is getting worse and it might be how there cracking down on this
    My son had to get a cab controller / ABS module for his and because the truck has a different engine than what the Vehicle Number plus the cab controller part number was also not was not Vehicle Number says it should be he was questioned about it because these cab controller modules have to be programmed for your vehicle they are not generic controllers unfortunately he was able to get the controller programmed for his truck but there still is an issue with the air conditioning on this truck and it might be a controller fan not functioning correctly but this is another day
    • petehall347
      • Jan 2015
      • 4448
      website says this ...
      The Max Energy Power Programmer comes with a USB cable and a CD containing software to enable quick updates over the internet. If your vehicle has a new calibration not available when your Max Energy Power Programmer was manufactured, it is possible that you will see a “Cal not found” message on the Max Energy screen. If this occurs, you can simply update your Max Energy with the correct new calibration via the internet. Simply connect the Max Energy (using the provided USB cord) to your computer and go to www.hypertech.com. Then click on the Support button to get update downloads.
        by Vesko356
        08-11-2023, 03:27 AM
      • DXseekerMO
        Samsung PN51F8500AFXZA broke off the tuner's F connector, can't get tuner de-soldered
        by DXseekerMO
        I can hear Fred Sanford now...."YOU BIG DUMMY".....I pulled the "F" connector out of the tuner by accident. The tuner number is BN40-00248B. Low and behold I had a scrap board with tuner number BN40-00248A. Although the tuner is different (according to Encompass.com) it's footprint on the board is exactly the same as the 248B so I decided to de-solder the tuner off the scrap board to see what I was getting in to.
        As you can see in the picture the terminals and solder pads are super small. No matter what I tried I could not get either the terminals or support...
        09-15-2021, 05:15 PM
      • danielgerman681
        ENCONTRAR DATOS DMI EN EL CHIP BIOS IDEAPAD5 15ITL05 / FIND DMI DATA ON IDEAPAD5 15ITL05 BIOS CHIP
        by danielgerman681
        Hi, Im trying to find the area on the chip that contains all of my laptops information, but I havent found it. The laptop won't turn on anymore. I was updating the BIOS, and it was supposed to reboot itself, but it wouldnt turn back on. I ve tried every possible solution, every alternative on Lenovo forums, everywhere; I ve taken it to technicians, and no one has been able to fix it. I've already read the chip that contains the BIOS (Winbond 25Q128JSVQ) and searched for my laptops data, but they're nowhere to be found. I only find scribbles and lines of text indicating errors. Has anyone had a...
        08-27-2025, 01:17 PM
      • corrize
        Where to find a very small fpc connector 0.3mm between 2 pins ?
        by corrize
        Hello, I search this connector (oxydated).
        It's a fpc zif low profile connector. It come from camera sensor, it is very small : 0.3mm between 2 pins.
        I ordered 2 from Aliexpress called « 0.3mm pitch » but one was 0.5mm between 2 pins and the other 0.6mm. In fact « 0.3mm pitch » seams to be the pad width and not the distance between 2 pins.
        I can't find it. The other websites like mouser dont show the datasheet, and I can't check if it is 0.3mm between 2 pins ?
        Do you know how to find this connector please ? What is the exact name for find it ?
        08-06-2024, 05:25 PM
      • jason0503
        need help to modify a bios dumped from set-top box
        by jason0503
        The set-top box has a TV silicon tuner IC MXL608, which has a programmable channel selection filter (6MHz/7MHz/8MHz), and the default value is 8MHZ, but the manufacturer sets the set-top box to 6MHZ. How can I change this value by modifying the dumped bios? I tried using UEFITool.exe, but it doesn't work. The BIOS of the TV box is different from that of the computer. I don't know how to modify it or what tool to use. I downloaded the data sheet of MXL608, which mentioned that when the value of SYMBOL is set to 2.85, BW=6MHZ. When the value of SYMBOL is 3.75, BW=8MHZ, but I can't find the corresponding...
        12-14-2024, 01:26 AM
