Smokin' ASUS Wow!
  • kiddznet
    • Jul 2010
    • 176
    Smokin' ASUS Wow!
    Connected up a board Asus P4B533-VM it has been in storage somewhere a few years I believe , I started it fans turning and man there was sparks and smoke started from the DIMM sockets. Needless to say it didnt BOOT!
    Where do I go from here clean out the DIMM sockets? I thought some isopropyl alky and a toothbrush give it a scrub anyone got a better idea?
    Or just frisbee it?
    939 DualCore AMD Opteron, 1800 MHz (9 x 200)
    Abit AN8 / Fatal1ty AN8 SLI Series
    3072 MB (PC3200 DDR SDRAM)
    ATI Radeon HD 4300/4500 Series (1024 MB
    Lian LI Aluminium mesh case
  • ratdude747
    Black Sheep
    • Nov 2008
    • 17136
    Re: Smokin' ASUS Wow!
    desolder the usb, ps2, etc. plugs off of it (and the atx). keep for parts. scrap the rest.
    sigpic
    (Insert witty quote here)
    • Toasty
      • Jul 2007
      • 4171
      ^^^ I'm with him on this one.
      Empty DIMM sockets or populated ones?
      What is the PSU you used? One that had been working recently, or an old one that was lying about? Could be it's the culprit.
      veritas odium parit
      • kiddznet
        • Jul 2010
        • 176
        DIMM in sockets. PSU well checked and ok
        • kiddznet
          • Jul 2010
          • 176
          Here you can see the burning is it gunk there is one swollen cap as well?
          • PCBONEZ
            Grumpy Old Fart
            • Aug 2005
            • 10661
            That an OST I see by the RAM slot there?
            Mann-Made Global Warming.
            - Dr Seuss
            • Topcat
              The Boss Stooge
              • Oct 2003
              • 16958
              Atleast that asus displayed its problem.....just junk the board. With that kind of damage, its just not worth messing with imo. Most all asus boards have nothing detectably wrong with them, but the heaps of shit just don't work....I see way too many of those.
              <--- Badcaps.net Founder
              Badcaps.net Services:
              Motherboard Repair Services
              http://folding.stanford.edu/
              Team : 49813
              Join in!!
              Team Stats
              • kiddznet
                • Jul 2010
                • 176
                Comments duly noted, item has been binned.
                • digge
                  • Apr 2006
                  • 296
                  Ive seen the exact same thing once, but that time it wasn't the boards fault. One of the pads on the ram had come loose and shorted. Surprisingly the board worked fine after i replaced the memory, despite the burned socket.
                  • Toasty
                    • Jul 2007
                    • 4171
                    Vaya Con Dios
                    veritas odium parit
                    • kiddznet
                      • Jul 2010
                      • 176
                      Hmmmm... looking at the RAM that came out there are scorch marks on the the pins same spacing as the DIMM socket but at the OPPOSITE end???
                      • PCBONEZ
                        Grumpy Old Fart
                        • Aug 2005
                        • 10661
                        You stuck it in backwards?
                        - Dr Seuss
                        • brethin
                          • Dec 2008
                          • 1907
                          Yep I say that is what it was by looking at the pins in the dimm socket that are burnt.
                          • shovenose
                            Send Doge Memes
                            • Aug 2010
                            • 6575
                            stick it in right and try it again-see what happens. you might be surprised
                            • kiddznet
                              • Jul 2010
                              • 176
                              WHO WOULD BE DUMB ENOUGH TO DO THAT....EH?
                              • seanc
                                • Nov 2008
                                • 1319
                                Does the board beep with no RAM?
                                If you put RAM in and it works, that'd be great. If you change those slots and it starts/still works, very impressive.
                                • kiddznet
                                  • Jul 2010
                                  • 176
                                  Not only does it work someone else owns it now
                                  • ratdude747
                                    Black Sheep
                                    • Nov 2008
                                    • 17136
                                    ... ebay w/ AS-IS?
                                    sigpic
                                    • shovenose
                                      Send Doge Memes
                                      • Aug 2010
                                      • 6575
                                      Haha! I was right!
