microsoft color applet
  • willawake
    Super Modulator
    • Nov 2003
    • 8457
    • Greece
    i am trying to get microsoft color applet installed on winxp64
    http://www.microsoft.com/downloads/d...displaylang=en
    this is to load icm profile for the monitor (dunno why nvidia control panel does not have this function)
    anyway this anus of an app wants to download and install .net 1.1 but every time it tries install it exits with an error. i can install .net 1.1 by itself nice but the app wants to download it again and install uuuh
    anybody know solution?
    is there other software to load icm profile. this monitor sucks
    • 31283
    Re: microsoft color applet
    i didnt think microshit had gamma correction?
    • willawake
      Super Modulator
      • Nov 2003
      • 8457
      • Greece
      yes this supposed to work
      http://www.microsoft.com/prophoto/do...orcontrol.aspx
      it included in vista+
      • Junk Parts
        Court Jester
        • Jun 2006
        • 8953
        I just installed it on my PC with no drama. Only issue was that it downloaded and installed Netframework 1.1 again which was already on this system. This is a windows Xp home PC.
        Mark Twain
        John Paul Jones
        Rod Serling
        • Per Hansson
          • Jul 2005
          • 5895
          • Sweden
          Does not exist for XP x64
          Why do you need it?
          If you have a Colcorvision Spyder you can use their software to load ICM profiles, requires an update if you want it to work with multiple monitors in XP x64
          • willawake
            Super Modulator
            • Nov 2003
            • 8457
            • Greece
            i got it working on this comp at work doesnt seem to do anything
            i want to use an icm which someone made for my monitor
            • Per Hansson
              • Jul 2005
              • 5895
              • Sweden
              I see
              But all monitors are different, you need to buy a calibrator and calibrate it
              The Colorvision spyder2express is very cheap, makes a big difference, especially on cheap monitors!
                • 31283
                what is it, a sensor you stick on the tube?
                if it is, barco monitors used to have them built-in!
                • Per Hansson
                  • Jul 2005
                  • 5895
                  • Sweden
                  You hang it infront on the monitor and then run their software to have the monitor display test colors, the device then measures these colors and makes adjustments to get everything calibrated...
                  If you cheat you can even use the Spyder2 Pro software on the cheap express Spyder, this gives you the option to set the RGB values etc in the monitor itself, so the ICM file does not do all the work, but the monitor gets properly calibrated using it's own menu system instead...
                  • willawake
                    Super Modulator
                    • Nov 2003
                    • 8457
                    • Greece
                    yes these very cool. expensive though
                    i thought i might bring this samsung 226bw home to use. it was ok for general office stuff but for home its just crap i cant use it. i think i will get a big IPS or PVA display instead. i was looking at eizo FX2431
                    TN monitors used to be generally usable until they started this contrast and saturation race
