HUGE caps
  • Shagreobe
    Confused Newbie
    • Oct 2022
    • 16
    HUGE caps
    Tore apart a dc power supply/rectifier at work, and there were 3- 32000μF 40VDC caps in it. Any use for them before I get rid of them?
    • 31209
    Re: HUGE caps
    ebay - those are worth serious cash
    • Shagreobe
      Confused Newbie
      • Oct 2022
      • 16
      Re: HUGE caps
      Nice...Now, how can I test them? My meters only go to like 1000μF lol
      • spiros.p
        • Dec 2020
        • 89
        • Greece
        Re: HUGE caps
        lol my lcr meters going only 10.000μf and my both fluke's then i by extech ex623 as i need one more clamp meter going up to 40.000μf.ok only shows if still there capacitance nothing more.
        • Cartel
          • Feb 2006
          • 112
          Re: HUGE caps
          they are worth $7
            by momaka
            03-12-2025, 03:42 PM
          • eryjus
            by eryjus
            05-10-2023, 11:21 AM
          • Paxman_Swede
            by Paxman_Swede
            Hello!
            01-14-2025, 09:51 AM
            Casing Power MPT-301 [PCB ATX9806b-p REV: A3]
            by momaka
            This one should make @Pentium4 smile (if he is still reading BCN forums) – I got a new old stock / open box Casing Power MPT-301 PSU on eBay for $4 total.
            Yes, it’s a very generic-looking box, but the manufacturer isn’t (at least not back in the days), which is…
            Macron Power Technology Co. LTD.
            Let’s look at the PSU itself.
            The shell/case also appears quite generic, like many “sold-with-the-PC-case” units. However, the shell is well-formed and has decent steel thickness. In terms of...
            06-02-2021, 10:05 PM
          • captain150
            by captain150
            03-16-2025, 07:34 PM
