Nichicon - discontinuing many electrolytic capacitor series
  • redwire
    • 3912
    2022-05 Nichicon is end-of-life mass terminating many really great electrolytic capacitor series: https://cdn.badcaps-static.com/pdfs/...d334e16c2c.pdf
    Some seem to be about size? "We are notifying you that all 7mm height UPW series capacitors have reached their End of Life. Last time to buy date is September 15,2021. End of production will be on March 31,2022."
    https://cdn.badcaps-static.com/pdfs/...1dc83e4ed9.pdf
    I notice Digi-Key is listing "Not For New Designs" across the line for Nichicon electrolytics such as UPW, UPJ, UPV, UKL etc.
    If this is true, it's just tragic.
  • AleXis6
    • Feb 2021
    • 69
    • Belarus
    Re: Nichicon - discontinuing many electrolytic capacitor series
    thanks for this information.
    I like some of these impacted series
    • kaboom
      "Oh, Grouchy!"
      • Jan 2011
      • 2507
      This is unbelievable. I never thought I'd live to see this.
      As if the last few years haven't been stupid enough...
      "pokemon go... to hell!"
      EOL it...
      All style and no substance.
      guilty,guilty,guilty,guilty!
      guilty of being cheap-made!
      • CapLeaker
        Leaking Member
        • 8351
        UHE and UPW I used quite a bit. Those were decent caps.
          • Jul 2011
          • 6070
          This is not the only brand name that is doing this kind-a-crap the brand that I mostly use has done the same exact thing and I have bought some more of these items that are at the end of life list
          If these capacitor manufacturers keep doing this crap you are going to be very LIMITED to what you are going to be able to repair mainly because of size limitations and voltage limitations really
          I am getting the end of life notice from Digikey for the ones that I have bought in the past
          This is one reason I buy the small UF values under 100uf I buy 100 of them at a time because I have some KY and KZE and some other series that are not available anymore ( because I have had very good results using them in switching power supply and other devices )
          In fact I have had to switch from KY or KZE 47uf@50 volts to the automotive series ( when I did this and found out that they work just as good I bought 200 of them because I use this value a lot ) because they were disconnected a while back but they work just as good I still have some 25 volt ones in my part bin
          The higher UF values I buy at least 10 of them over what I need for a given project because I will eventually need to use the UF value and the size of the capacitor
          • Highland Tech
            • Jul 2022
            • Scotland
            While on the subject one brand of electrolytic capacitor in particular I found to be the most susceptible to failure is Rubycon so they are one brand I prefer seeing the back of. As a result I always try and obtain alternative 105 deg types.
            • lti
              • May 2011
              • 2558
              I noticed this a couple weeks ago and switched to Rubycon for my stock. It's weird that Nichicon would discontinue so many parts, especially the smaller ones.
              I haven't had any problems with Rubycon, but I always used Nichicon or Panasonic for my stock because they were cheaper. For my own stuff, I don't care much about what brand of caps I use, aside from a few that seem to have unusually high failure rates like CapXon and Fujicon. I haven't used Würth caps because their specs and marking style are a perfect match to CapXon.
              • PeteS in CA
                • Aug 2005
                • 3583
                • USA, Unsure of Planet
                Unless I’m misunderstanding that chart, it looks like selected case sizes and/or voltages are being discontinued rather than entire series. The PM/PL series has been around since the late 1980s, and the PJ series is pretty long in the tooth as well. If certain HE series parts are hard to find, the PA series is similar in impedance and ripple current rating.
                PeteS in CA
                • lti
                  • May 2011
                  • 2558
                  Yeah, they're discontinuing selected parts instead of the entire series in most cases. I used a lot of Nichicon VZ in those smaller can sizes.
                  • andrewsawesomr
                    • Jun 2022
                    • 101
                    • United States of America
                    It seems like they're discontinuing at least some of the UHD and UHE series as well(Ultra Low Impedance electrolytics)
                    • Topcat
                      The Boss Stooge
                      • Oct 2003
                      • 16959
                      Originally posted by andrewsawesomr
                      ...as well(Ultra Low Impedance electrolytics)
                      Those have been gone for years; HM, HN, and HZ series.
                      <--- Badcaps.net Founder
                      Badcaps.net Services:
                      Motherboard Repair Services
                      http://folding.stanford.edu/
                      Team : 49813
                      Join in!!
                      Team Stats
                      • andrewsawesomr
                        • Jun 2022
                        • 101
                        Not those types of low Impedance electrolytics, the UHD and UHE series(Not as low Impedance as HM/HN). It seems like Nichicon Is downgrading their selection of capacitors in all Low ESR series. Weirdly enough, DigiKey seems to list the entire UHD and UHE series as "Not Recommended for New Designs". Is that a limitation of the DigiKey website, or just conflicting information?
                        • PeteS in CA
                          • Aug 2005
                          • 3583
                          Nichicon actually continues producing and selling older series for a really long time. The PM and PS series are RoHS-compliant versions of the 1980s PL and PR series (~35 years old!). The PJ series has probably been around for 20 or 25 years.
                          Nichicon is not, at this point, eliminating many of those series, just low-selling case sizes (were 8mm, 10mm, and 12.5mm, and 16mm diameter cases affected at all?). That said, if someone is looking to design in a 16mm diameter low impedance electrolytic, choosing a PM, PS, or PJ series part for a product expected to be in production for 5 or 10 years would be a very bad choice.
                          PeteS in CA
                          • redwire
                            • 3912
                            Digi-Key lists them as mass discontinuation, I think Nichicon might be trimming through-hole parts? Vanilla 1,000uF 25V 10mm dia parts listed as not for new designs.
                            But realistically, who here has seen Nichicon in new products? Manufacturers have all gone over to using to the cheap chinese capacitors, for years now.
                            • DrewPhillips
                              Capacitor Diarrhea - Nichicon PL Series
                              by DrewPhillips
                              Hello All, I have on the bench a couple of PSU's which have some failed Nichicon PL series caps. They didn't "puke" their guts through the top, but instead "diarrhea'ed" corrosive brown electrolyte through the bottom, down the legs and onto the board. On one cap, the electrolyte rotted the cap right off the board leaving 2 little stubs, and also corroded a trace on the foil side.
                              The PSU's are Power-One MAP series and are ringing-choke topology. The semiconductors have date codes in 1993. The PSU's were used in a commercial application, fan-cooled. They had failed...
                              03-02-2025, 10:18 PM
                            • MORETTIGIAN
                              Capacitor detached from PCB – RTX 2070 Super Founders Edition
                              by MORETTIGIAN
                              Title:
                              Description:
                              During maintenance on an RTX 2070 SUPER Founders Edition, I found a capacitor lying on my desk after reassembly.
                              I did not notice it detaching, so I am unsure of its original location on the PCB.
                              Procedure performed:
                              - Removed backplate
                              - Cleaned heatsink and PCB with isopropyl alcohol + soft ESD brush
                              - Reapplied thermal compound
                              - Reassembled card
                              Observed behavior after reassembly:
                              - GPU powers on and operates normally under...
                              09-18-2025, 12:14 PM
                              ASUS Pro Series D320MT-I564000234 Pro Series i5-6400 Specification for Upgrade or Repair
                              This specification for the ASUS Pro Series D320MT-I564000234 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Pro Series D320MT-I564000234 boardview and Pro Series D320MT-I564000234 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
                              09-12-2024, 03:28 PM
                              ASUS Pro Series D310MT-0G32500650 Pro Series G3250 Specification for Upgrade or Repair
                              This specification for the ASUS Pro Series D310MT-0G32500650 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Pro Series D310MT-0G32500650 boardview and Pro Series D310MT-0G32500650 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
                              ASUS Pro Series D320SF-I564000134 Pro Series i5-6400 Specification for Upgrade or Repair
                              This specification for the ASUS Pro Series D320SF-I564000134 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Pro Series D320SF-I564000134 boardview and Pro Series D320SF-I564000134 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
