Nichicon FW on power supply?
  • felipeunix
    • Aug 2015
    • 7
    • Brasil
    I know this series is "audio grade", is this limited to using the audio signal path?
    Has anyone tested the performance of this series of capacitors in the energy reservoir stage after rectifier in linear PS?
  • spiros.p
    • Dec 2020
    • 89
    • Greece
    Re: Nichicon FW on power supply?
    yes is ok last winter i have to check one big yamaha old model receiver.inside was about 200 pieces nichicon FW caps everywere from big psu caps to the smalest amp section
    • Tynan Dill
      by Tynan Dill
      Assuming...
      11-22-2024, 01:46 PM
      03-31-2024, 02:12 PM
      07-01-2024, 06:34 AM
    • JimBanville
      Definitive technology SC 2000 subwoofer amp's power supply clicking and popping
      by JimBanville
      The sub developed a constant popping every couple seconds from woofer and power LED flickering with nothing but wall AC connected. Connecting an audio cable didn't change anything. It doesn't play but a second or two of audio in between the pops.
      I measured the power supply output going to the amp board and it too has this pulsing. Voltage cycles...
      09-13-2023, 07:21 AM
    • CMCM
      Russound CA4 Power Supply Repair
      by CMCM
      Hello Everybody,
      Trying to repair a power supply from a Russound CA4 Multizone Controller (picture attached)
      Russound no longer supports it but were kind enough to provide a schematic of the power supply (pdf attached).
      The outputs marked 12v and 20v are all measuring only 1v.
      The board is clicking, which I think means it is in something called hiccup mode when the flyback transformers switches because of an internal problem or something else on the board Overloading it.
      The capacitors physically look clean (no bludgesor leaks) and...
      07-03-2025, 01:12 PM
