How to determine the value of an SMD Capacitor?
  • mrkmpn
    • Apr 2022
    • 62
    I have a motherboard with at least one blown capacitor. I found a boardview for the motherboard and installed open boardview hoping that might have the information I'm looking for, but if it does contain the information, I can't figure out how to view it.
  • Erico1
    • May 2022
    • 6
    Re: How to determine the value of an SMD Capacitor?
    Locate the PDF schematic of the motherboard. That is where the values can be found. If it were not blown, then using an LCR meter on the capacitor after removal from the board would yield the value.
    • MORETTIGIAN
      by MORETTIGIAN
      Title:
      Description:
      Procedure performed:
      - Removed backplate
      - Reapplied thermal compound
      - Reassembled card
      09-18-2025, 12:14 PM
    • NuclearSpartan
      Samsung C32HG70 - Blown Ceramic Capacitor (CP813)
      by NuclearSpartan
      I'm new to this, so I apologize for not providing enough details. Is there anything else I need to mention? I'm trying to learn more about electronic/board repairs and hopefully fix my own.
      The only visible issue on my board is one capacitor, CP813, which appears to be labeled R 221k 2kV (possibly obsolete to B 221k 2kV now). My monitor hadn't shown any prior issues, although it is a few years old. Just before the capacitor popped, there was a high-pitched squeal for 2–3 seconds.
      I don't see any other visible damage anywhere else on the board....
      11-14-2024, 02:32 PM
    • expertreader
      Found a blown capacitor - is it necessary to replace?
      by expertreader
      Hi all, Acer Nitro 5 - GH51M LA-K862P Rev 1A motherboard. I went through all the troubleshooting steps but couldnt find a short on any coils. By chance, ended up finding a blown capacitor PCZ49 which is suppose to be 2.2uF. I can see plenty of 2.2uF in the same +5VALW line which will all parallel up anyway - do you guys think it is critical for this cap to be replaced or i can get away without one?...
      10-15-2025, 04:54 AM
    • devsigner
      identify capacitor for MacBook Pro with rare logic board 820-02037-06
      by devsigner
      Hi
      While messing around with my MacBook Pro, I stupidly pinged off a very small surface mounted component that I’m now trying to identify.
      resistance tests show a rising resistance value, indicating a capacitor.
      The laptop boots up and runs, however I'm choosing not to use it until I get it fixed.
      i can’t see any markings on the capacitor at 10x magnification using a professional jewler's loop.
      It seems like there's some damage to the capacitor - one side doesn't have "shiny bits" - can you tell I don't do this for a living!...
      11-28-2025, 01:39 PM
    • badnocap
      Trouble reading this blown capacitor
      by badnocap
      25V 470uF? Any help would be appreciated! This was in an Adam A7X speaker. I replaced with a different uF and voltage closest to the values I thought because it is all I had in stock. It restored the speaker to working condition but it is certainly not what I needed to do as it is putting out less volume than its sister speaker which presumably no issues....
      11-12-2025, 01:36 PM
