6.3v 1800uf im a beginer help pls !!!
  • Roli
    • Jun 2010
    • 42
    Ok so i got a motherboard with damaged caps , 2 of them are damaged , the board has "OST 6.3v 1800uf caps" can i change this with another capacitor from another mainboard but the problem is that the other mainboard has "OST 6.3v 2200 uf capacitors" Can i change it? will this procedure harm other stuff on the board ? Help please as fast as u can cose i need this board fixed , thanks
  • willawake
    Super Modulator
    • Nov 2003
    • 8457
    • Greece
    Re: 6.3v 1800uf im a beginer help pls !!!
    it is not recommended to use old caps from another board but maybe you succeed
    it is ok to go up one step, ie from 1800 to 2200 is ok. nothing bad is going to happen
    • Roli
      • Jun 2010
      • 42
      So you are telling me that i can change from 1800 uf to 2200 uf and nothing is going to happen ?!?!?!? And it is a problem that i change only 2 of them ? i mean there are total like 6 capacitors with 1800 uf and 4 of them are in perfect condition , can i change only 2 of the 6 , i mean if i change 2 caps , i will have 2 caps with 2200 uf and 4 caps with 1800uf , will this cause problems or can i go with it ? Please tell me i want to begin the procedure if you aprove that it will be ok !!! HELP !!!
      • Uranium-235
        Comrade Glimmer
        • Aug 2007
        • 5045
        • US
        should be fine from what I can tell
        • AK77
          • Mar 2011
          ROLI, did you use the 2200uf caps in place of 1800uf? If yes, what were the results? Was the board stable with these higher capacity caps?
