MSI -7142 ver1 no boot bad caps
  • monto
    • Mar 2023
    I am new to the capacitor world and need some help. I have a Msi 7142 ver1 that will not longer post. Looking at the board I see a bunch of bad caps. I need some help to cross-reference to a replacement.
    I have the following that need to be replaced.
    6.3v 1000uf KZG 8mm x 10mm
    6.3v 1000uf not other markings 8mm x 14mm
    6.3v 1800 KZG 8mm x 20mm
    replacement?? https://www.mouser.com/ProductDetail/647-UHN0J182MPD6TD
    16v 1800uf KGZ 8mmx20mm
    Pictures included than you!
    by momaka
    03-12-2025, 03:42 PM
  • jrodefeld
    Asus laptop won't boot (no power) - possible bad caps?
    by jrodefeld
    I would like to see if anyone could help me salvage a very expensive laptop that is no longer working.
    The model:
    Asus Zenbook Pro Duo UX582L
    I have used this laptop lightly since I purchased it new in 2022. I have always taken precautions to take care of it the best I could, and have never done anything that would risk causing damage to it or shorten it's life.
    However, around six months ago, the laptop stopped working on battery power. It continued to work fine when plugged in, but as soon as power was disconnected,...
    09-02-2024, 04:55 PM
  • eryjus
    by eryjus
    05-10-2023, 11:21 AM
  • privato89
    Nintendo Switch Oled HEG-001: Second-Stage Boot Failure
    by privato89
    I'm facing an issue with a HEG-001 motherboard that is unable to complete the Second-Stage Boot. I'd like to start directly with my conclusion, which is the decision to replace the MAX77621AEWI chip, and understand if it could be a correct evaluation.
    Before I dive into the process that led me to this decision, I want to mention that I have a fully equipped lab where I can perform any kind of tests.
    Let's begin:
    Following some guides online, I tried to understand how the Boot phase of the Nintendo Switch works, and what are the...
    03-26-2024, 06:37 AM
  • Paxman_Swede
    by Paxman_Swede
    Hello!
    01-14-2025, 09:51 AM
