Need to ID these caps
  • axlmastr
    • Aug 2005
    • 158
    Sorry no pic yet. Topcat, Kc8adu, Williwake, AKOR, MDWillington- help is appreciated. These are in some of the IBM NetVista A40s.
    Description:
    Aluminum housing- yes aluminum no plastic shrink on these babies. Markings are on top right on the vent area which is a faintly scored X. The first mark at about 12 o'clock is an eliptical O like the O in Oakley sunglasses. Then below it at 9 o'clock is a heavy black vertical bar with HD to the right and y1 to the right of that. Then below that is 1200 with finally 10V below it. I know the vertical bar marks the negative polrity of the cap. Who makes this? Anyone? Anyone? Ferris Beuller are you out there with the correct answer? Class? Anyone? Give it a shot. I'll post a pic when I get them out. I'm pretty sure they're causing this machine to not boot. PSu tests ok for now, just a matter of time for the the crap caps to puke in it too. I'll have to fix that's what the owner wants.
  • willawake
    Super Modulator
    • Nov 2003
    • 8457
    • Greece
    Re: Need to ID these caps
    post a pic of them on the board
    • kc8adu
      • Nov 2003
      • 8832
      • U.S.A!
      nichicon hd
      not seen any bad yet.
      • axlmastr
        • Aug 2005
        • 158
        Need to ID these caps (update)
        I've got some pics of what I'm trying to I.D. These are off one of many NetVista A40 I'm looking at. The boards vary as to what they contain, but this cap I have not seen until now. Most of the others are Chhsi and Teapo or Chhsi and what look to be Panasonic. Sorry about the lighting on the pan view shot, but it was very early in the morning. I will post some other pics later regarding the NetVista and it's psu which I mentioned in another thread. The proprietary piece of @#$% has an upper and lower PCB with Teapo and G-Luxon. Guess which brand blew first? Anyway here's the pics for I.D.
        • kc8adu
          • Nov 2003
          • 8832
          • U.S.A!
          like in my post above nichicon hd.no failure yet.
          these netvista boxes have been a mixed bag here too.
          • axlmastr
            • Aug 2005
            • 158
            Thanks kc8adu. Though the Nichicon HD may be ok it's the Teapo in the top of the one pic that is sad. They cheated on that few. Over near the riser card slot are some HD snap-ins. Where the Teapo are on this board I have others with what appear to be Panasonics, but don't want to take the chance. Could be counterfeit. Most of the other machines have all Chhsi or Chhsi and Teapo on the MB while the Psu has Teapo and G-Luxon. Some MB have the 470uF in Chhsi and Rubycon though the Rubycon could be fakes with correct spelling. You're right it's a mixed bag. Mostly crap caps though.
            • PeteS in CA
              • Aug 2005
              • 3579
              • USA, Unsure of Planet
              KC8, While Nichicon has an HD series (it's the starting point for all the other H* series), and it has been (is?) sold without the polyester (or PVC) sleeve, that oval logo on the caps in the pic doesn't ring a bell. Are they really Nichicon?
              PeteS in CA
              • willawake
                Super Modulator
                • Nov 2003
                • 8457
                • Greece
                i was thinking the same. search on nichicons site did not reveal similar photo. although they say they have eliminated pvc sleeving it is possible for sleeving to be present just made from different material.
                • kc8adu
                  • Nov 2003
                  • 8832
                  • U.S.A!
                  same logo on new nichicon ud smt 1500@6.3 on sealed reels here.
                  • PeteS in CA
                    • Aug 2005
                    • 3579
                    Thanks, kc8. I think they are switching from PVC sleeving to polyester as part of their Pb-free change-over. You knew polyester had to be good for something besides leisure suits.
                    PeteS in CA
                    • axlmastr
                      • Aug 2005
                      • 158
                      You are correct about smt versions of the same markings. I have some of those over by the riser card slot. I called them snap-ins in a previous post. I will confirm that the ones pictured are indeed all aluminum with NO sleeve. The O is what I question when you say Nichicon since this is not related to any of their previous markings. I was trying to confirm whether to swap these out along with the TEAPO at the top of the second pic or leave them and replace only the TEAPO.
                      • kc8adu
                        • Nov 2003
                        • 8832
                        • U.S.A!
                        seems pvc is being phased out too.
                        on 2 reels of smt tantalums i just got on the label i see
                        pb free
                        pvc less.
                        the ud parts i have are sprayed with some sort of laquer or poly.
                          by momaka
                          03-12-2025, 03:42 PM
                        • 13mh13
                          Aluminum SMD caps vs thru hole caps (reliability)
                          by 13mh13
                          The PCB motor for 1987 Technics SLP-120 CD player has slow spin-up issues. Similar to what another tech in the below video reported.
                          https://i.postimg.cc/kGrR6BpZ/image.jpg
                          I replaced the three bi-polar 47uF electros but that made no difference. The orig three bi-polar 47uF electros tested okay on my ESR M-tester.
                          I have not tested/replaced those alum. SMD electro PCB caps.
                          Are Al smd caps are more prone to failure (or degradation) than regular thru-hole electros?
                          All the thru hole electros I removed / replaced on this CDP (and most...
                          04-05-2024, 07:41 PM
                        • eryjus
                          by eryjus
                          05-10-2023, 11:21 AM
                          by momaka
                          03-15-2023, 10:17 PM
                        • Paxman_Swede
                          by Paxman_Swede
                          Hello!
                          01-14-2025, 09:51 AM
