BG caps? Who makes them?
  • kgordon
    • Mar 2010
    • 11
    One of the guys on one of my amateur radio lists mentioned some industrial switching supplies that used BG caps. All have failed within 6 months of use. He replaces them with Motorola brand caps and has had no failures since.
    So, who makes BG brand caps?
    Anyone know?
    Ken Gordon W7EKB
  • kgordon
    • Mar 2010
    • 11
    Re: BG caps? Who makes them?
    Ooops...I meant MALLORY brand....
      • 31214
      Mallory was a company that was known for making battery's
      BG are some of the best and most expensive caps you can get for psu's - dont mix them up!
      • kgordon
        • Mar 2010
        • 11
        As an old Ham Radio Op (since 1956), I know that Mallory has also made capacitors since before WWII.
        He insists that the BG caps have ALL failed within 6 months, repeatedly, as the PSU manufacturer has an excellent warranty and replaces them for free.
        However, shipping costs are higher than replacing them himself with his choice of caps, which in this case is Mallory. He says that any PSU in which he has replaced the blown BG caps with Mallory's has never failed afterwards.
        So, who makes BG?
          • 31214
          www.vishay.com
            • 31214
            and they arent rated for switching supply's, they are intended for Linear supplies - so they shouldnt have been used!
            • kc8adu
              • Nov 2003
              • 8832
              • U.S.A!
              bg as in black gates?
                by momaka
                03-12-2025, 03:42 PM
              • eryjus
                by eryjus
                05-10-2023, 11:21 AM
              • Paxman_Swede
                by Paxman_Swede
                Hello!
                01-14-2025, 09:51 AM
              • captain150
                by captain150
                03-16-2025, 07:34 PM
              • Foetuss
                Gigabyte GA-6OXT :: caps question
                by Foetuss
                Good evening
                I recently aquired a rev 1.1 Gigabyte 60XT, and was suprised of the amount of leaking caps for a motherboard of the P3 era. Especially the way the 330µf caps seems like the housing discolored even.
                Now, there are some 3300µF 6.3V KZG series around the CPU. Would it be OK to replace them with something like EEUFR1A332 ? (Panasonic FR 3300µF 10V). Or was this board designed around very low ESR caps?
                But I was also suprised about the bigger boys, which are 330µF 25V.
                Could it be they used 25V caps because they were cheaper / available at that time?...
                02-11-2025, 12:22 PM
