Can anybody ID these caps?
  • yyonline
    • Jul 2009
    • 692
    These are on a GeForce 4 MX card. I can't see who made the card. The caps are marked:
    470
    10V
    R1
    Size is 8 x 11.5mm
    I'm wondering if anybody has any manufacturer or series data on them? I'm trying to see if Rubycon ZL is a good enough replacement as I have a few thousand 470/10V ZLs.
  • kikkoman
    • Jul 2007
    • 691
    Re: Can anybody ID these caps?
    doesn't really matter what they are. they're crap, obviously.
    ZL can't be worse.
    a GF4MX isn't really demanding anyways, so there's not going to be much ripple.
    "Every normal man must be tempted at times to spit on his hands, hoist the black flag, and begin slitting throats." - H.L. Mencken
    • kc8adu
      • Nov 2003
      • 8832
      • U.S.A!
      old school linear regs.
      zl is fine.
      • yyonline
        • Jul 2009
        • 692
        Thanks for the advice, guys.
        I pulled some of the non-bloated caps off the board and tested them with the ESR meter. They measured between 0.05 and 0.06 ohms ESR. My replacement ZLs measure between 0.04 and 0.05 ohms ESR. ZL datasheet says 0.07 ESR, I suppose my meter might be a bit off. Either way, they're in the same ball park. Card was running fine even with the blown caps, so it's definitely an improvement over what was on there.
        Anyone know a reliable way to stress test a video card?
        • etnietering
          • Apr 2009
          • 379
          I use AtiTool from here: http://www.techpowerup.com/atitool/
          You can use it to overclock and all sorts of things also, but I just use it for the stress testing. It's handy for monitoring temps, too.
          • Scenic
            o.O
            • Sep 2007
            • 2642
            looks like a GeForce 2 GTS
            if so, mine had YXG's
            • c_hegge
              • Sep 2009
              • 5219
              I usually use Video Card Stability Test to stress a video card
              http://freestone-group.com/video-car...ility-test.htm
                by momaka
                03-12-2025, 03:42 PM
              • eryjus
                by eryjus
                05-10-2023, 11:21 AM
              • Paxman_Swede
                by Paxman_Swede
                Hello!
                01-14-2025, 09:51 AM
              • captain150
                by captain150
                03-16-2025, 07:34 PM
              • Foetuss
                Gigabyte GA-6OXT :: caps question
                by Foetuss
                Good evening
                I recently aquired a rev 1.1 Gigabyte 60XT, and was suprised of the amount of leaking caps for a motherboard of the P3 era. Especially the way the 330µf caps seems like the housing discolored even.
                Now, there are some 3300µF 6.3V KZG series around the CPU. Would it be OK to replace them with something like EEUFR1A332 ? (Panasonic FR 3300µF 10V). Or was this board designed around very low ESR caps?
                But I was also suprised about the bigger boys, which are 330µF 25V.
                Could it be they used 25V caps because they were cheaper / available at that time?...
                02-11-2025, 12:22 PM
