Capacitor Questions
  • Jordan
    • Oct 2005
    • 16
    Capacitor Questions
    Does the physical size of a capacitor matter? Like a tiny 16v 1000uf just as good as a large 16v 1000uf?
    Also what about voltage? I have a mod that needs 6.3v or 16v caps, but will 25v of the same uf rating work fine?
  • AK0R
    • Mar 2005
    • 204
    Re: Capacitor Questions
    The smaller (physical size) capacitor probably has a *LOWER* temperature rating, which is bad, because it doesn't have as much surface area to dissipate the internally-generated heat. More than likely, it also has a *HIGHER* ESR rating, which is bad, because it will generate more heat due to whatever ripple voltage it sees. In general, you want to use the largest physical size that will fit, while also having low ESR.
    A higher voltage rating will work just fine. The capacitor will be physically larger than its lower voltage counterpart, so that will help with heat. Check the ESR rating as well.
    • Jordan
      • Oct 2005
      • 16
      The one I have to compare is a OST 100uf 16v 105c RLG cap. Its black with gold writing. Then, I have a smaller one that everything is rated exactly the same, and the colors and stuff are all the same. The only thing thats different is it says RSM rather than RLG. I couldnt find any info other than most low ESR caps are 105c, which both of these are. I also read somewhere that green or black wrapper with gold writing is usually low ESR.
      Sound right?
      • willawake
        Super Modulator
        • Nov 2003
        • 8457
        • Greece
        not great advice to follow, bad brands like to imitate the colors of the good brands.
        check the FAQ, section 3.2 good capacitor manufacturers :
        https://www.badcaps.net/forum/showthread.php?t=425
        • PeteS in CA
          • Aug 2005
          • 3583
          • USA, Unsure of Planet
          I've seen low ESR series from UCC in blue, brown, and green sleeving. Some series can be made with more than one color: I've seen KZE parts in brown and green; I've seen LXZ parts in blue and brown. AFAIK, UCC doesn't do color-coding. OTOH Nichicon seems to use brown sleeving on low Z parts that have non-aqueous electrolyte (e.g. PW, PM, PJ, PS, PL, PR series), and black sleeving on low Z parts that have aqueous electrolyte (e.g. HC, HD, HE, HZ, HM, HN series). Panasonic uses blue sleeving on its FC series, which has non-aqueous electrolyte; its FM series, which has aqueous electrolyte, has a black sleeve. All the low Z Rubycons I've seen are in black sleeving and have aqueous electrolyte.
          Some vendors do color-coding within their product line, others don't. There is no industry-wide color-coding.
          PeteS in CA
          • PeteS in CA
            • Aug 2005
            • 3583
            Be careful in substituting a higher voltage part. You need to be sure the part's impedance is the same or lower than the original part, and that the ripple current rating is the same or higher.
            PeteS in CA
            • Jordan
              • Oct 2005
              • 16
              where can I get data sheets for these OST caps then?
              • willawake
                Super Modulator
                • Nov 2003
                • 8457
                • Greece
                why would you want OST datasheets? their products are crap and prolly working well out of specs after a while. just substitute a recommended brand like Panasonic, Rubycon, Sanyo choosing their low esr series and substituting a value/voltage equal to or slightly higher and end of story, the board is working fine.
                • Jordan
                  • Oct 2005
                  • 16
                  Alright will do. Didnt realize OST was that bad. DFI uses them on their older boards (nf2) and no one has ever complained about DFI's caps....
                  • MORETTIGIAN
                    by MORETTIGIAN
                    Title:
                    Description:
                    Procedure performed:
                    - Removed backplate
                    - Reapplied thermal compound
                    - Reassembled card
                    09-18-2025, 12:14 PM
                  • chth96
                    Is it no harm to replace with capacitor without ripple current rating?
                    by chth96
                    When I tried to repair LG 29 inch CRT TV, I found that the ESR value of samyoung SMS capacitor(160v 2.2uf), which is very close to D1879 transistor, is 6 ohm.
                    Judging from above ESR Meter Table,I think It is necessary to replace this sms capacitor.So I visited local electronics shop,and I purchased 160v 2.2uf rubycon YK capacitor.
                    But when I browse through rubycon YK datasheet,I found that there is no ripple current rating for 160v 2.2uf specification. But On the contrary, I found 39 mA ripple current rating for 160v 2.2uf SMS capacitor.
                    Rubycon YK DataSheet (b...
                    04-19-2024, 05:19 AM
                  • Per Hansson
                    Motor run capacitor physical size vs voltage rating & measurements?
                    by Per Hansson
                    (TL;DR skip the first paragraph)
                    I encountered my first dead motor run capacitor at a customer this week.
                    For some fields I guess it is a very common occurrence but the usual way for industrial machines here is to use 3-phase motors.
                    (Unless a servo motor makes more sense that is).
                    But for some reason this 3-phase machine uses a 1-phase motor for its liquid coolant pump.
                    The pump would run but sometimes trip the 10A breaker.
                    I monitored it starting and stopping for over an hour until it finally stopped in a specific spot between its windings:
                    Then it could...
                    09-20-2020, 06:32 AM
                  • Prolog
                    by Prolog
                    12-01-2024, 08:27 PM
                  • Adenitz
                    Explanation of capacitor rating
                    by Adenitz
                    I'm reading an article about the "capacitor plaque" in early 2000s and I have found one sentence I cannot understand.
                    The normal lifespan of a non-solid electrolytic capacitor of consumer quality, typically rated at 2000 h/85 °C and operating at 40 °C, is roughly 6 years. It can be more than 10 years for a 1000 h/105 °C capacitor operating at 40 °C.
                    What this 2000h or 1000h means? Why 1000h capacitors have longer life span?
                    12-26-2022, 12:36 AM
