VRM Mosfet replacement with non originals
  • JorgeHernan
    • Apr 2006
    • 42
    Hi guys
    I have some NEC 2sk3296 blown but i can't get them at any stores over here.These are some old socket 370 and some 462.Can i replace them with some IRFZ44 will it work?
    Thanks you
    • 31026
    Re: VRM Mosfet replacement with non originals
    i would need to check the datasheets.
    i'll say this though, you shouldnt mix fets.
    if one is dead and there are a set of 3 - replace all 3.
    that way you wont get any imbalance on multi-phase power circuits.
    • seanc
      • Nov 2008
      • 1319
      Sometimes, the manufacturers are generous and will send free samples - thank you Niko-Sem!
      Doesn't hurt to ask, all they can do is say no.
      • precision001
        • Sep 2009
        • 43
        I was wondering why do IC mosfets need 8 legs - 3 for the source and 4 for the drain? What advantage does this have? I'm thinking of experimenting with a board, and removing all but one pin for source and drain, just to see what happens.
          • 31026
          the legs act as heatsinks and 3 legs will carry 3 x the current.
          • precision001
            • Sep 2009
            • 43
            As far as testing them goes, for a P channel would I just measure resistance S-D(pos terminal on S) ? I have come across dead boards and found some mosfets measuring as low as 50 ohms. I presume they are bad - but there doesn't always appear to be any signs of damage - they look perfectly fine.
            • JorgeHernan
              • Apr 2006
              • 42
              Yes i already know that . I learned the hard way some time ago when replaced one shorted NEC 2sk3296 (instead of replacing the 3 present on the pcchips 810 i only replaced the shorted one) with an irfz44.It worked, got video and all but only for a couple of seconds until the irfz44 started to melt and went up in smoke.I guess that happened because of the imbalance you mentioned.I wasnt able to solder the irfz44 transistor body to the board because of not having any heat gun, so that made things worst because it could not dissipate enough heat, as the the originals did.
              • precision001
                • Sep 2009
                • 43
                Could you connect a bad mosfet source to drain to force it on? I observed a (functioning) gateway laptop once that had the source of one mosfet tied to the drain of the other mosfet in the pair. I believe they were 4407s. Does anyone know why this caused the circuit to work? How could I use this information to test mosfets on a motherboard?
                • DoOm86
                  Dual mosfet replacement help
                  by DoOm86
                  Hello.
                  I have a notebook with a shorted mosfet, it's a E6930 GA8125.
                  It seems to be a 30V dual asymmetric N-channel AlphaMos.
                  Luckily the notebook is working, so I just need to find a good replacement for this mosfet.
                  And here is where I need help!
                  It's the first time I have to replace this kind of mosfet, I checked on mouse and I found this: (mouser No) = 512-FDPC5030SG.
                  I need your help to be sure is a good replacement or there is another with better compatibility, since I can't find the same exact (just from China).
                  Thanks!...
                  10-31-2023, 12:03 PM
                • jm942
                  Hp Lh482p 5 short 3 long short after cpu vcore mosfet replacement
                  by jm942
                  My laptop went dead and after checking ,the main 19 volt power rail was shorted. After some checks i could identify that a high side vcore mosfet was shorted.
                  I replaced the mosfet and now the white powerled is present , fans start spinning but capslock shows the famous 5 long and 3 short code.
                  I checked the vcore voltages after replacement and i get for all 1.01 V so means for me that the driver is still working of the replaced shorted mosfet. On the Nvidia i measure around 0.8 V after the mosfets.
                  I did voltage injection on the cpu with 0.7V and i have a current...
                  07-11-2024, 05:11 AM
                • Jane
                  How do you test MOSFET in laptops ?
                  by Jane
                  I tried to use this method:
                  Testing an N-channel MOSFET:
                  Step 1: Discharge the Gate (turn off the MOSFET)
                  Place the black probe (COM) on the Source (S) and the red probe on the Drain (D). The multimeter should show no continuity (high resistance or "OL" – open line).
                  Then, touch the black probe to the Source (S) and the red probe to the Gate (G). This discharges any stored charge in the Gate, turning the MOSFET off.
                  Step 2: Charge the Gate (turn on the MOSFET)
                  Now, place the red probe on the Gate (G) and the black probe on the
                  09-27-2024, 03:31 AM
                • String2016
                  SMD MOSFET REPLACEMENT
                  by String2016
                  Hi I need help on this mosfet replacement SM4511NHKPC can I replace this with M3056 OR M3058 please help
                  01-23-2025, 06:35 PM
                • String2016
                  by String2016
                  i NEED Help any replacement for this mosfet M3092M?can i replaced with EMB20N03
                  12-15-2024, 05:31 AM
