Need help to identify capacitor brand
  • oldirdey
    • Jan 2019
    • 6
    • germany
    Want to repair some broken floppy disk drives. I need help to identify the brand of this capacitor to find a suitable replacement.
    Did someone know the brand of the capacitor or a suitable replacement in terms of esr / ripple?
    • 31213
    Re: Need help to identify capacitor brand
    it's 35v rated, but it cant be seeing more than 12.
    i personally would use a 25v tantalum cap.
    no point trying to fit another smd electrolytic - they are all junk and unless you have hot-tweezers you will probably damage the replacement anyway.
    • oldirdey
      • Jan 2019
      • 6
      • germany
      Thank you for the reply.
      It´s not a thing how to replace the cap, I have all these nice tools and know how to use them. I am just searching a cap with same spec in terms of esr and ripple. I knew that the one on the picture has 10uf and is 35v rated, but can´t see any other spec.
      Don´t want to solder mlcc or tantalum cap.
        • 31213
        well it looks like a nippon-chemicon symbol on it.
          • 21653
          It looks like there`s some corrosion as well on the IC above that cap .
            • 31213
            actually it looks like the ceramic cap infront of the chip has been broken away from the board on one end.
            • oldirdey
              • Jan 2019
              • 6
              • germany
              thank you very much.
              there is some dirt and corrosion, but nothing thats not fixable. but the mlcc is fine as you can see after cleaning the area a bit.
              • PeteS in CA
                • Aug 2005
                • 3581
                • USA, Unsure of Planet
                It may be an ordinary surface mount electrolytic cap rather than a polymer. If so, a good quality 105C general purpose part would probably suffice.
                PeteS in CA
                • oldirdey
                  • Jan 2019
                  • 6
                  • germany
                  Sorry for missing information. It´s a panasonic floppy from 1991.
                  • redwire
                    • 3912
                    The electrolytic cap is close to the motor H-bridge IC, and likely for local decoupling.
                    Note that the PCB will accomodate a larger cap there, the footprint is larger. The 10uF is likely not critical at all, for ESR.
                    • MORETTIGIAN
                      Capacitor detached from PCB – RTX 2070 Super Founders Edition
                      by MORETTIGIAN
                      Title:
                      Description:
                      During maintenance on an RTX 2070 SUPER Founders Edition, I found a capacitor lying on my desk after reassembly.
                      I did not notice it detaching, so I am unsure of its original location on the PCB.
                      Procedure performed:
                      - Removed backplate
                      - Cleaned heatsink and PCB with isopropyl alcohol + soft ESD brush
                      - Reapplied thermal compound
                      - Reassembled card
                      Observed behavior after reassembly:
                      - GPU powers on and operates normally under...
                      09-18-2025, 12:14 PM
                    • ckrtech
                      Help Identify cap brand and quality, please
                      by ckrtech
                      This is a cap on a motherboard from 1994. “Ark” is the only brand I know of that has an A inside a rectangle, but I wanted to run it by you guys and get any thoughts on quality.
                      Thanks in advance....
                      06-09-2025, 12:28 PM
                    • BlackBurn
                      Help to identify a laptop mainboard SMD capacitor LA-9982P
                      by BlackBurn
                      I have an Dell Inspiron 15 3537 laptop mainboard (LA-9982P Rev. 3.0 (A02)) with a blown SMD capacitor as shown in the attached images. However, there is no printed specifications near the capacitor or a codename for the capacitor to identify the specification of the capacitor to replace it. I wonder how to identify the capacitor since the mainboard schematics are also useless as the capacitors are not named on the board. Any help would be highly appreciated.
                      Thank You. Stay Safe.
                      Chamara...
                      11-27-2020, 08:30 AM
                    • chth96
                      If I replace with inferior capacitor, Is it No harm to other IC components at all?
                      by chth96
                      I replaced some capacitor which is located on optical pickup pcb which is shown in the table below(PCB #2).Because it have been out of order.
                      Now,It works very well,But I just have found that all caps (6svpc100my and other part number as well) ,which is shown in the table below, has ultra-high ripple current spec.
                      It is not able to obtain any capacitor which can be a substitute for this ultra-high ripple current nichicon capacitor.
                      So I replaced it with samxon and rubycon's general capacitor(GP,YXA series).
                      I know that these capacitor will not last as long as nichicon capacitor...
                      12-22-2023, 04:34 AM
                    • chth96
                      How can I test non-polarized capacitor?
                      by chth96
                      I desoldered samwha NF capacitor(50v 5.6uf) from PCB circuit of 29inch CRT TV which have symptoms of no display after I heard sound of inrush of current to TV whenever I switch on this television.
                      I measured ESR value of this non-polarized capacitor(samwha NF capacitor 50v 5.6uf) by means of MESR-100 ESR meter and It displayed 0.3 ohm
                      And When I measured its capacitance with digital multimeter and LCR-T4 Mega328 meter, It displayed 10uf from DMM and 8uf from LCR-T4 meter.
                      I found catalogue of samwha capacitor(samwha-catalogue_3.pdf file), which is attached to this thread,...
                      06-02-2024, 07:31 PM
