Need help Finding replacement capacitor
  • Storyteller12
    • Jun 2020
    • 624
    Please help me identify this capacitor and find a replacement. Markings on it read
    F273J E
    1250PPS1
    Tried google but didn't really get any hits. Thanks in advance.
    • 31002
    Re: Need help Finding replacement capacitor
    27nf polyester or poypropylene film.
    • Storyteller12
      • Jun 2020
      • 624
      Thank you for the info, however I cannot find a replacement. Can anyone provide a link to a replacement capacitor.
      Thank you in advance.
      • jayjr1105
        • 281
        https://www.ebay.com/itm/12195526859...0AAOSwhDdXDqR6
        Ryzen 3600x
        16GB Patriot 3600MHz
        MSI B450 Gaming Plus
        MSI Air Boost Vega 56
        Acer 32" 1440P Freesync
        Rosewill Capstone 750W
        Hakko FX-888D Station
        FX-8802 Iron
        MG Chem .8mm 63/37 RA 2.2%
        • Per Hansson
          • Jul 2005
          • 5895
          • Sweden
          Here you have a couple hundred to choose from:
          https://www.mouser.se/Passive-Compon...yznbzsZ1z0wps3
          • jayjr1105
            • 281
            10 for a dollar
            https://www.mouser.com/ProductDetail...qBkmrHzA%3D%3D
            Ryzen 3600x
            FX-8802 Iron
              master hoarder
              • May 2008
              • 12170
              • Bulgaria
              I don't see anyone mention anything about the voltage rating. That said, the cap looks too small to be rated for 1250V (in addition to 1250V being a rather odd voltage rating) as the second info line would suggest. At the same time, it does look a bit too big for just being a 250V cap... though if I had to guess, it probably is a 250V-rated cap.
              Could we get a clue in what application this cap was used or what part of the circuit?
              Yup... or just metal film if you want to generalize.
              Though there is a slight difference in the performance between PP (polypropylene) and PE (polyester) caps, with the former having much more stable characteristics at high frequencies. Of course, PP caps also tend to be a bit more expensive than PE, generally.
              • r2digital
                klipsch kda-500 amplifier suitable power supply capacitor replacement ?
                by r2digital
                I have a klipsch kda-500 that would turn on and allow me to get into the web management but it was picking up a lot of noise from audio sources so i decided to replace the smd caps on the power supply along with radial one. Some one was in here before me and they basically burned the bottom side of the traces off for the radial cap but i was able to repair it without any real problem. I thought i did a good job sourcing out replacement caps but apparently not and now i can't get the power supply to turn on it just constantly try's to keep turning on. Attached is a picture of the power supply before...
                04-18-2024, 03:50 PM
              • rwkish
                Discontinued Capacitor looking for Replacement
                by rwkish
                Capacitor has been discontinued (EGXF101ELL331MM20S) all of the replacements I have found have are smaller than 0.709" Dia (18.00mm). I would like to use the same size or at least close to the same size Capacitor. 19mm would be too big as they would touch and not be able to through hole mount. Tia...
                08-18-2024, 06:54 PM
              • Hylax
                Replacement capacitor options please?
                by Hylax
                Hi, I'm super new to this capacitor stuff but I've some basic soldering experience with old cellphones PCBs and headphones. I have this APAQ AR5K 820∆μF 3V Dc Capacitor from a motherboard that I'm looking to replace, photos I've attached. But I'm unable to find a 3V one like I've marked in the spec sheet in red (This is the one currently present in the motherboard). But the 6.3V one I can find (marked in blue) is of similar dimensions but different specs as mentioned in the table. Is it okay to replace it with higher voltage cap, slightly higher ESR, slightly lower ripple current, and double...
                08-09-2024, 11:25 PM
              • unimatrix93
                Finding proper replacement rectifier
                by unimatrix93
                I'm trying to fix up my battery charger. Where I found a dead schottky rectifier.
                This is the dead component PTR30L120CTF:
                PTR30L120CTF datasheet(1/7 Pages) PFC | 30A 120V HPTR Schottky Rectifier (alldatasheet.com)
                And I have a spare 30CPQ150:
                30CPQ150 datasheet(1/5 Pages) IRF | SCHOTTKY RECTIFIER (alldatasheet.com)
                Can I use this diode as a replacement or if not, can you recommend me a proper replacement?
                I cannot find the exact unit anywhere besides aliexpress and such.
                Thank you guys!
                03-05-2024, 09:18 AM
              • GKdays
                Single capacitor replacement on arcade pcb
                by GKdays
                I have a damaged capacitor from a bootleg double dragon arcade pcb and I have the normal values from it:
                10 volt, 100uF, 85c, but someone from an arcade forum said that the ripple current is not that critical and any good quality low esr cap would be fine, the damaged one is an electrolytic can type but I don't know what to look for as far as low esr is concerned, can a ceramic capacitor be used instead, the capacitor is going to the +5 volt
                I don't know the brand but on the top of the capacitor is stamped "76 F6" if there is a datasheet ide be able to...
                08-09-2022, 05:21 AM
