Power Supply (PSU) Questions
  • bigbeark
    • Jan 2010
    • 661
    I've got a couple of Old FSP-300s that failed the Power-Good Test on my inexpensive tester, so I tore one apart and removed the caps. There were six and all were bulging. They were all Fuhiyyu. One of them is 3300 10v but the can size is 10mmx35mm.
    Where do you get those? The big axial resistor has the skin peeled off it. Should I re-coat it with something? Can't see what the banding is but I believe the body was pink.
    Any ideas?
    Also have a Zippy Emacs H2-6460P EPS that was "racing" on startup. I have several others of these that work, so I know this one's got a problem.
    Shortly after you boot up, the fan races, then slows down, then races faster, then shuts down and finally the whole thing just shuts down.
    Tried this with several boards, so I know its the PSU at fault.
    Removed the cover - there are no bulging caps at all. Incredibly heavy-duty contruction inside. Any idea what could be causing these symptoms?
  • etnietering
    • Apr 2009
    • 379
    Re: Power Supply (PSU) Questions
    The consensus around here is that the big Fuhjyyus aren't honestly rated. Somebody (I don't remember who) measured one once that was supposed to be 4700uF and if I remember correctly it was actually around 3000uF. So chances are yours isn't even close to 3300uF. You may, however, be able to stuff a 12.5mm diameter cap in it's place. They usually have the same lead spacing (5.0mm), so it's just a matter of clearance around the edges. Something like this would work: http://search.digikey.com/scripts/Dk...name=P12735-ND and since you know you'll have clearance height wise you can probably up the capacitance a notch or two.
    For the resistor - can you open another of the same type of PSU (you said you had multiple) and see what the value is? Or if somebody else here has one they might be able to check for you.
    The Zippy...my guess would be the temperature sensor or thermal protection circuit is malfunctioning. If this is screwed up it would cause the fan to go crazy (assuming it's a temperature controlled unit), and then put itself into thermal shutdown, even though it's not too hot. That's just a guess though, it could be something totally unrelated. Somebody else might have more insight...
    • 370forlife
      Large Marge
      • Aug 2008
      • 3112
      Topcat sells the 10v + 16v samxon RS series that are 10mm x 30mm 3300uf.
      • Tynan Dill
        by Tynan Dill
        Assuming...
        11-22-2024, 01:46 PM
        03-31-2024, 02:12 PM
        07-01-2024, 06:34 AM
      • shamsudeen
        Hi, Can we use SMPS Bench Power Supply for Laptop troubleshooting?
        by shamsudeen
        Hi all, I just need to know that, can i use SMPS type power supply to test and short circuit detection on a laptop motherboard?
        I saw 95% of repair guys are using only Linear bench power supply. linear bench power supply is pricy, thats why i planned to get one SMPS supply.
        i know that in linear power supply the noise will be very low comparing to SMPS supply....
        07-19-2025, 07:14 AM
      • JimBanville
        Definitive technology SC 2000 subwoofer amp's power supply clicking and popping
        by JimBanville
        The sub developed a constant popping every couple seconds from woofer and power LED flickering with nothing but wall AC connected. Connecting an audio cable didn't change anything. It doesn't play but a second or two of audio in between the pops.
        I measured the power supply output going to the amp board and it too has this pulsing. Voltage cycles...
        09-13-2023, 07:21 AM
