Vishay, Yageo - What are these capacitors like?
  • Agent24
    I see dead caps
    • Oct 2007
    • 4958
    • New Zealand
    http://newzealand.rs-online.com/web/...duct&R=4406632
    http://newzealand.rs-online.com/web/...duct&R=1670105
    They don't sell any of the rubbish brands as far as I know so I expect that these aren't too bad either.
    But does anyone have any experience with the quality of these? Or even what the are usually used in?
    Because I have never actually seen them in any piece of electronic equipment!
    -David VanHorn
  • shadow
    • Feb 2007
    • 732
    Re: Vishay, Yageo - What are these capacitors like?
    Well your best friend is probably the spec sheet. Find out what capacitors it stacks up with in terms of ESR and ripple compared to the common capacitors that are recommended on these boards. Ones like the Panasonic FM and FC, Nichicon HE, Rubycon MBZ etc.
    I know Vishay are well known for producing semi-conductors like BJT's and MOSFET's and small IC chips. No idea about their caps thou.
    • Agent24
      I see dead caps
      • Oct 2007
      • 4958
      • New Zealand
      ESR I didn't look at but ripple is about a third of what the Panasonic of the same value can handle.
      According to the spec sheet, they are just general purpose capacitors, which would explain it.
      I don't think they even tell you the ESR. So probably not useful anyway, even if they are good quality.
      -David VanHorn
      • shadow
        • Feb 2007
        • 732
        General Purpose capacitors have much lower ripple than equivalent low esr capacitors. And yes, ESR is not always shown in general purpose capacitor spec. sheets.
        In short, these capacitors are not good enough for use on most computer equipment. General purpose capacitors do have their uses (and these are probably good GP caps). However not so useful on say a motherboard.
          • 31040
          vishay make some of the best caps in the world, but not for low-esr high frequency usage.
          they make really good long-life high ripple stuff for Linear psu repair though.
          • Wizard
            • Mar 2008
            • 2296
            vishay also makes diodes and some semiconductor stuff (power stuff).
            Cheers, Wizard
            • 370forlife
              Large Marge
              • Aug 2008
              • 3112
              Yageo are teapo. Yageo is the world's largest producer of resistors, they bought teapo a while back.
              • Agent24
                I see dead caps
                • Oct 2007
                • 4958
                • New Zealand
                Being Teapo and owning Teapo are different, though...
                Maybe the quality of Teapo will improve under new management?
                Or maybe they can get Teapo to make their capacitors for them, for cheaper
                -David VanHorn
                • 370forlife
                  Large Marge
                  • Aug 2008
                  • 3112
                  They've owned them for quite some time. They definitely have teapo make their caps, vents are the same, series are the same, colors are the same, even the font is the same, just different names.
                  I think yageo is one of the major reasons of teapo's seemingly steady rise in quality, at least to me they are no longer "replace on site" in power supplies, but I've never seen them on a newer motherboard other than their poly's.
                  • dragon3x
                    by dragon3x
                    power on.
                    Here are some examples :
                    switching supply area).
                    than 6.3 V.)
                    03-21-2025, 02:46 PM
                  • slybunda
                    AA and AAA battery charger capacitors?
                    by slybunda
                    hey all, iv got my favourite battery charger here which iv had for many years probably 15 years now or maybe even more. it still works good but thought id open it up to clean the dust out of it, lots of dust inside but now its clean and noticed 4 capacitors inside it and wondered if i should replace them.
                    it has inside:
                    2 x 47uf 16v caps 105c branded as Su'scon (lol sounds sus to me)
                    2 x 470uf 16v LZ105c branded as G.Luxon
                    not heard of these brands are they any good?
                    iv attached photos of the charger and the board inside for an idea on the type of...
                    12-24-2023, 04:41 AM
                    After all of...
                    07-13-2024, 08:14 PM
                  • Ady2017
                    Are there any datasheets available for Elna RJG capacitors?
                    by Ady2017
                    I have a 2007-era Panasonic VHS combo that is full of of Elna RJG capacitors. I am trying to test the capacitors to diagnose the machine and then select replacement capacitors but I can not find any datasheets for them. I did find a Elna catalogue from 2007-2008 but there is no mention of this capacitor series. Where these specially made for Panasonic and so not made available to the public? Any ideas what to find out what the ESR values should be without the datasheets? They are all between 10V and 50V and 47uF and 1800uF. None are leaking or bulged but I know that they need to be tested to be...
                    05-25-2025, 02:19 PM
                  • ctroxtell
                    Samsung UN70tu7000wxza no standby light, do I have bad capacitors?
                    by ctroxtell
                    I picked up a 70" Samsung UN70TU7000WXZA. The original owner said they were watching it when the power surged and knocked it out. I pulled the back off the TV and disconnected the main board from the power board, and the LED backlight came on, which I was told meant the power board was good. When everything is plugged in the standby light will not come on, looking at the main board BN94-17775A with a thermal imaging gun I can see one of the chips labeled 3202 is 251 degrees F just sitting idle. I found a replacement board, BN94-16115X; this board has the same symptoms, except it is a different...
                    01-03-2025, 08:57 PM
