How bad electrolytic cap behaves in a circuit
  • Askic
    • Sep 2018
    • 187
    • BIH
    Hello guys,
    I hope there are people here who can explain me what bad or blown electrolytic cap change in the circuit. How its capacity is changed?
    Recently I had a problem with my Samsung 940N monitor. When computer is started for the first 1 or 2 minutes the picture is slightly flickering, later is OK.
    The problem is solved by replacing three bumped caps 470 uF, 25V on power supply board.
    I also found two slightly bumped caps on my motherboard, but the it is working fine, so for now I didn't change them. In this case, there is absolutely no indication that something is wrong or not functioning properly because of bad caps. The caps are 1000 uF, 16V.
    So, in two cases I had bumped caps and in one case I had indication something is wrong (startup flicker) in other case everything seems OK.
  • PeteS in CA
    • Aug 2005
    • 3581
    • USA, Unsure of Planet
    Re: How bad electrolytic cap behaves in a circuit
    Well, the bad capacitor doesn't do what it is supposed to do, or it does something it should not.
    If it fails short circuit things may blow up or a fuse may blow or a power supply's over-current protection may be tripped.
    If a capacitor's capacitance drops it can't hold the charge it is supposed to store.
    If a capacitor's equivalent series resistance goes up, it may not be able to supply the energy it is supposed to be storing. Or it may not reduce the ripple and noise in a circuit.
    The monitor problem you described sounds like the capacitors were not supplying needed energy until they warmed up, causing the flickering.
    The domed capacitors in your motherboard are probably not filtering VRM output noise adequately, and you may see erratic performance, errors, etc.. I believe that if those capacitors are not replaced and deteriorate badly enough, the increased ripple amplitude could damage components, but I'll defer to others here on BCF with greater experience regarding that possibility.
    PeteS in CA
    • televizora
      ghettomodmaster
      • Nov 2016
      • 957
      • Bulgaria
      Capacitors are elements used to store energy or because of their freq characteristics - as part of a filter.
      Here are some examples of capacitor use
      1. Capacitor used as a part of RC generator
      2. Capacitor as a filter, buffer
      3. Capacitor as a ballast
      Ex 1 - the circuit that relies on the RC generator will not work correctly. Ex - PSU.
      Ex 2 - the capacitor on the exit of the PSU with high ESR will cause low voltage on exit.
      Ex 3 - complete malfunction of the circuit
      Ex 4 - PFC of the PSU
      Ex1 details - cheap PSU-s use IC-s to drive the MOSFET of the switching PSU, that don't have internal oscilators.
      Use external RC to provide base freq
      Ex2 details - most PSUs have capacitors on their output. To smooth the voltage after rectification. If ESR too high, then they become like resistors connected to the output. Then you have lower than specified voltage on the output of the PSU.
      Ex3 details - for example cheap AC led lightbulbs. Capacitors have certain reactive resistance for certain freq.
      Some of the cheap lighbulbs use them instead of dedicated drivers, on place of what usually will be resistor.
      This cannot be used for DC. Capacitor for DC = infinite resistance.
      Ex4 details - malfunction of the PSU, that relies on CAP to boost the voltage.
      There are rare cases, when they just blow up or one of the legs is torn or corroded. Replace ASAP.
      These are some uses in digital electronics and PSU-s.
      Analog uses include filters - low pass, high pass or combined and again - oscillator circuits.
      For ex - NE555 relies on external components to tune up the oscilation.
      Read about time constant. Caps can make the circuits around them to fail as well.
      Not properly working PSU, wrong freq - heat, shorting of MOSFETS and so on.
      Usually the PSU IC-s are smart enough to turn off the PSU if not operating in the specified parameter range.
      But don't count on this, because of many cheepies, where the component number is extremely reduced.
      Caps are also used in buck voltage converters.
      One more ex - you have Switching mode PSU that relies on RC generator to generate impulses, so the MOSFET is driven.
      The MOSFET-s have a different parameters. Constant load and impulse load. For ex, you have MOSFET that can tolerate
      duty cycle of 20Khz. At one moment, because of failed cap, the frequency becomes 5Khz or total bust.
      If there isn't a smart IC the mosfet will overheat, blow, short, take half of the live side of the PSU and possibly damage the transformer.
      The short will also take the input rectifier with it, as well as the fuse. Full cascade failure.
      What could happen depends on where where the cap is and what it's function is.. From almost nothing to total failure.
      The bright side is that the caps don't usually go out of spec or blow up suddenly. Usually you will have much time and prior notice
      that something is not okay. And time to fix it. If you ignore it, you know what awaits you.
      Also - one topic to read fro our forum - https://www.badcaps.net/forum/showthread.php?t=211
      Useful conversions. I don't "speak" imperial. Please use metric, if you want to address me.
      1km=1000m=100000cm, 1inch=2.54cm, 1mile=1609.344meters, 1ft=30.48cm 1gal(US)=3.785liters, 1lb=453grams, 1oz=28.34grams
      • Askic
        • Sep 2018
        • 187
        • BIH
        Excellent explanation televizora!
        Thank you very much.
        • Astonished
          Fixing the Charge Circuit of the Batteries of the DC Motor
          by Astonished
          Hi friends of electronics
          What you see in the video and pictures attached is the circuit for charging the batteries of a DC motor.
          The problem is that this circuit cannot charge the batteries (3 1800mAH NiMH batteries) any more. When the circuit was OK, its green LEDs lit up one at a time to show that the batteries have charged more. But now that the circuit is flawed, LEDs light up as you see in the video and at the same time successive beeps are heard.
          Please help me fix this circuit.
          (the datasheet of the IC: https://pdf.datasheet.live/28...
          01-28-2025, 06:24 AM
        • Tarot Superstars
          Short Circuit tester
          by Tarot Superstars
          Hello.
          I have seen a short circuit tester made with 3 * 9V batteries, a voltage limiter component and a resistor connected to the probes of a multimeter.
          The theory is that the meter becomes sensitive enough to read very low resistances and the lowest resistance to ground on a circuit is likely to be a short circuit in that area.
          Link
          The Amazing $1 Short Finder Upgraded! Convert ... - YouTube
          https://www.youtube.com/watch?v=0eixDdCpiO4
          My multimeter isn't normally sensitive to very small resistance, but when I put a 1 mega ohm resistor...
          09-25-2023, 09:11 AM
        • Alimash
          op amp circuit function?
          by Alimash
          I am repairing a ups which doesn't turn on ,it has the following ICs:
          SG3525 used to drive inverter mosfets.
          couple of uc3483, one for the power supply and another to drive a big mosfet at the output stage(i think the technique is called boost)
          A LM358 and TL074 for control mechanism and of course the uController.
          The SG3525 is shutting down every time the ups is turned on.
          I want your help to know the function of LM358 and TL074 in the system.
          I reverse engineered the LM358 circuit and i think that one of the block(A) is used for battery level...
          07-31-2025, 07:45 AM
        • M1NEBLANK SHOW
          MSI B250 Gaming M3 Short circuit in CPU power supply circuit
          by M1NEBLANK SHOW
          Hello. MSI B250 Gaming M3 board, short-circuit on the power supply. Found a problematic mosfet VQ1
          (N-PK616BA_PDFN8-HF) soldered it out - short circuit is gone. I replaced VQ1 + VQ5 (N-PK632BA_PDFN8-HF). VQ1 was replaced with PK618. After starting attempt VQ1 is lit again. What can be the problem? In the driver?
          Schematic and Boardview here
          04-04-2025, 03:57 PM
        • прямо
          Viper22A 5VSB circuit
          by прямо
          So I have a cheap non working ATX PSU that I was learning to repair a decade ago. At the time, it blew the main fuse, bridger rectifier, NTC, and primary 9A 900V MOSFET. Replaced all except the MOSFET. 5VSB came back online. Then I poked around in it so much, measuring components one by one to a point I accidentally made the 5VSB circuit primary side went bang. Blown the AP8022 (Viper22A) PWM chip, along with a low resistance resistor and the PC817 opto isolator. I replaced them all.
          In the process of poking around, I also lost a zener diode that stabilize the voltage coming from...
          01-13-2024, 07:05 PM
