Difficulty trying to match ESR of a replacement capacitor
  • Ady2017
    • Dec 2017
    • 55
    Hi all
    I am trying to find a replacement capacitor for a CapXon KM 100uF 400V. I have read that the big ones really go wrong but it is the last one left on the power supply board that has not been changed and the TV is still playing up so it is getting swapped too.
    I have read that I need to find a replacement cap with the same or higher ripple and the same or lower ESR, with all the usual being matched. The ripple is easy to match but the ESR seems to be a challenge.
    From the KM datasheet I have got, dissipation factor = 15% (therefore 0.15).
    I have put that into the equation from here,
    https://forum.digikey.com/t/calculat...-from-tan/2633
    This has given me an ESR of 1.99
    Looking at the equation on that site, if 'f' and 'C' are the same then if the dissipation factor is matched then then ESR will also be matched.
    So I have been trying to find a 100uF 400V cap with a dissipation factor of 0.15 or less but am struggling. The best I have found so far is 0.2
    Am I doing this wrong? It is confusing as the CapXon KM is not specifically listed as a low ESR capacitor but more of a high temp general purpose cap.
    • 31283
    Re: Difficulty trying to match ESR of a replacement capacitor
    that's on the mains input right?
    so esr dont matter at 100Hz - ripple is the key - higher = better.
    and if you can up to a 420 or 450v it would be better.
    • Ady2017
      • Dec 2017
      • 55
      Yes, it is on the main input.
      I finally found one or two with a low dissipation factor but they have got a short life of about 2000 hours. Others with a slightly higher ESR are often 10,000 hours. I was expecting to find something specifically designed for power supply applications but no luck yet. I have found ones for 'ballast' applications, whatever that is?
      Does anyone have any experience with the Panasonic EE series? Specifically this one,
      EEUEE2G101
        • 31283
        when you read "power supply applications" it will be refering to the output not the input.
        for high voltage caps you should look at Rubycon - they have the biggest range,
          master hoarder
          • May 2008
          • 12175
          Don't worry about the dissipation factor here. Just get a quality Japanese 105C-rated cap that meets the ripple current and has the longest lifetime/endurance (usually will also have the biggest case size, so watch the dimensions.)
          And if the PSU has an APFC circuit, upgrade the cap to 420V or even 450V, as stj noted. A lot of PSU manufacturers cut corners here when they use a 400V on a PSU with APFC. And as a result, most APFC PSUs with failed primary caps typically feature 400V caps.
          Of course, if this is a regular flyback PSU without APFC (most likely the case, especially if the PSU is under 60W or so), then 400V cap will be fine.
          • Hitto
            • Apr 2019
            • 95
            • Italy
            Chemicon KXJ is a good replacement. Being 12.000H/105°C, it will outlast that TV. Do not worry about dissipation factory for the reasons written above.
            • Tynan Dill
              by Tynan Dill
              Assuming...
              11-22-2024, 01:46 PM
            • reformatt
              by reformatt
              07-31-2025, 08:37 PM
            • the_rem
              Unknown transformer : how to find a good replacement part ?
              by the_rem
              Hello guys,
              I would like a quite old but still good 800 W ATX PSU to be repaired. The problem was an extremely heavy coil whine coming from the small secondary transfomer on the PCB.
              I desoldered it hoping the references on the upper side would allow me to find a adequate replacement part. Sadly the written references drove me nowhere but to the manufacturer (I-MAG). I sent them a message like a bottle in the see asking them to send me a datasheet of the transformer. And... They responded ! I received a kind of datasheet (see attachment) but my competencies do not allow...
              04-23-2025, 01:48 AM
            • ezenia
              PS4 controller left stick potentiometer replacement issue
              by ezenia
              Not sure if this is the correct section, but I have a PS4 controller that I am trying to fix. It developed stick drift on the left stick and the usual simpler methods did not fix the problem.
              So I went on eBay and ordered some replacement potentiometers. https://www.ebay.co.uk/itm/174967976757 is where I got them from.
              I took the green potentiometers off the replacement sticks and soldered them onto the PCB. Assembled the controller and ran some tests. The drifting was somewhat fixed (not fully in center, but way better than before). However,...
              09-30-2023, 02:19 PM
            • boosti45
              Macbook pro logic board replacement parts quesion
              by boosti45
              i have a 2020 macbook pro 13" A2251 with 820-09149 logic board so i found an issue with chip labeled U6903 according to schem. boardview using flexBV software, so i removed it from the board and the issue im having is that the chip says "07A08FI ELC180​" on top of it but when searching for a replacement chip, i can find tons of identical looking chips that also have "ELC180" printed on them but the first set of digits is never the same so im trying to find out if i need this exact chip with these same numbers as mine and if not which ones are compatible as a replacement?...
              08-21-2024, 05:23 AM
