Are this caps something special?
  • AndreStarTrek
    • Oct 2017
    • 20
    • Nederland
    I been repairing special mainboard for a exposure machine but after replacing a chip and some cleaning it seems not to boot correctly so seen the machine is about 25 years, I have replaced all the caps with cheap chinees caps because that was something i have in stock. But after that there was no life at al. Been probing with a oscilloscope but noting.
    So I been thinking, sure the cheap chinees caps are not the best but noting at all seems a bit strange. Are this something special?
    • 31265
    Re: Are this caps something special?
    those are just regular - low-spec electrolytics.
    i replace them all the time in sega gamegear consoles.
    i would have replaced them with SMD tantalums
    • AndreStarTrek
      • Oct 2017
      • 20
      • Nederland
      Thanks, I take it using tantalum caps that capacity is not a big deal, if I at least meet the minimum requirements?
        • 31265
        tantalums are better and probably smaller
        • AndreStarTrek
          • Oct 2017
          • 20
          • Nederland
          I understand that, but that was not what I was asking I like to know if it could be a problem if i use tantalums, would it be a problem if the capacity are bigger that the normal caps that are on the board right now?
          I dont think it would, but want to be sure.
            • 31265
            there is no problem as long as the voltage rating is atleast 1.5x what it is connected to and you dont put them in backwards!
            company's like apple and sun etc used to cover the boards in tantalum caps - the only reason they stopped is cost.
              Tantalum cap:
              https://www.arrow.com/en/research-an...lum-capacitors
              • Hitto
                • Apr 2019
                • 95
                • Italy
                Just use 50V parts and you should be okay. Kemet produces 50V parts for both 10 and 33uF tantalums, search for T52X serie.
                Use a Panasonic 1uF@50V SMD electrolytic, it should fit. EEE-HC serie.
                • AndreStarTrek
                  • Oct 2017
                  • 20
                  • Nederland
                  Thanks for all you reply's.
                  • AndreStarTrek
                    • Oct 2017
                    • 20
                    • Nederland
                    After 1 1/2 year this caps still haunts me.
                    After replacing the caps with the tantalums caps did not fix the problem it even create a problem, i found that out just recently.
                    After a year trying to fix this board we finally got a other board that worked. But this board has a lot of leaking/defective caps. So I replace 1/3 with tantalums and after that it wont boot, so i replace them again with caps that are not dead from a other donor board and the system boot again, but with a catch. We have to boot twice and I think this is because of the high resistance in the cap.
                    So i bought a ESR meter and got to work and the 33uf 16v caps has a ESR of 4.2 ohm with a 100KHz meter, and what i could find oud that is pretty high.
                    So I been searching for the right replacements and this are the one I found that could be it with my logic:
                    33uf 16v : https://nl.mouser.com/ProductDetail/...ZkYnMMng%3D%3D
                    10uf 16v : https://nl.mouser.com/ProductDetail/...52BHR3OQ%3D%3D
                    1uf 50v : https://nl.mouser.com/ProductDetail/...0g3nTfyA%3D%3D
                    So could it be that the tantalums are to fast? Are this caps the right one to replace with? Also a big chance i go with the radial version because this caps are even a bit to wide. I cant find a direct replacement for this cap.
                    In the end I am a bit lost, are this caps something special, could the tantalums be to fast and what should i replace it with? I hope someone could help me out.
                    • mockingbird
                      • Dec 2008
                      • 5488
                      I doubt it.. It could be you butchering the traces on the board with the iron... If those capacitors leakes, they may have weakened the traces or pads.
                      The caps you linked to are fine... I would probably use something like Panasonic FT, it has a higher endurance, and the last item you linked to is out of stock.
                        • 31265
                        check for electrolyte damage near the caps - those old boxed ones dump a surprising amount of liquid out!
                        • AndreStarTrek
                          • Oct 2017
                          • 20
                          • Nederland
                          I am pretty sure the traces are fine. The solder points are a bit dirty but no leakes on the board. It helps that the caps hanging upside down on the board. I am also pretty sure there is no damage from soldering as I made sure i heat the pads as shortly as possible.
                          I wil take a look at the Panasonic FT caps but dont think the higher endurance is necessary, the setup only have to work for a few years.
                          Both thanks for the info
                            • Jul 2011
                            • 6070
                            You would be correct that this value would be very high depending on what series you have it could range from 0.39 to around 1.something
                            The brand name that I use that are 33uf@50 volts read 0.39 new
                              by momaka
                              03-12-2025, 03:42 PM
                            • eryjus
                              by eryjus
                              05-10-2023, 11:21 AM
                            • Paxman_Swede
                              by Paxman_Swede
                              Hello!
                              01-14-2025, 09:51 AM
                            • captain150
                              by captain150
                              03-16-2025, 07:34 PM
                            • Foetuss
                              Gigabyte GA-6OXT :: caps question
                              by Foetuss
                              Good evening
                              I recently aquired a rev 1.1 Gigabyte 60XT, and was suprised of the amount of leaking caps for a motherboard of the P3 era. Especially the way the 330µf caps seems like the housing discolored even.
                              Now, there are some 3300µF 6.3V KZG series around the CPU. Would it be OK to replace them with something like EEUFR1A332 ? (Panasonic FR 3300µF 10V). Or was this board designed around very low ESR caps?
                              But I was also suprised about the bigger boys, which are 330µF 25V.
                              Could it be they used 25V caps because they were cheaper / available at that time?...
                              02-11-2025, 12:22 PM
