Re: Panasonic FC series - leaking? quality gone?
I don't mind Su'scon that much. Their GP caps are not that great when there is a bit more heat. But their PSU caps aren't all that horrible. Seem to be doing better than most Teapo and even maybe on par with Taicon (though I haven't encountered as many PSUs with Taicon and Su'scon as I have with Teapo - both failed and working... so can't really say if it's a direct apples-to-apples comparison.)
I'm pretty sure everyone hates Su'scon (except that one guy).
I still have a computer power supply with Su'scon caps from 1998.Leave a comment:
http://www.su-scon.com.tw/en/category/L.html
Su'scon (Taiwanese) catalog is interesting, clearly listing out their anhydrous caps.
They also have audio, low leakage and three types bipolar caps.Leave a comment:
worry other fire sources first, FC will add minor fire hazard if the PSU or the car catch serious fire, i think.
I have many old spare japanese caps in the tool box, purchased from un official sources, with some very genuine looking paper carton (FC series) or plastic bags date coded 10-15 years ago. I recapped my hot LG monitor with them 4 years ago and will see how they last.Leave a comment:
share some of my experience, the stuff (liquid and paper) in Panasonic FC is moderately flammable, will ignite with a cigar lighter and sustain fire.
many other caps are not flammable or unable to sustain fire.
this suggest fc is organic based with very little water.
with my limited chemistry knowledge, less water means less corrosion more stable and longer lifeLeave a comment:
LXJ too? Yikes. Never seen one leak before but I wouldn't put it past them. I know they were also used in old proprietary Newton Power 200W PSUs from 20+ year old Dells. FC should not use the quaternary ammonium salts. Chemi-con released a notice in 2003 (attached in this post) maintaining that none of their series in production at the time used the quaternary salts, including SXE, whose older datecodes were also known leakers. But I noticed LXJ was not included in that document. I initially thought it was because it was going out of production at the time. Maybe the real reason is due to the usage of quaternary salts in the electrolyte.
Even then, rubber does decompose after decades. It doesn't help when ammonia/ammonium attacks rubber and some plastics, expediting the process.Leave a comment:
the problem with FC is not the electrolyte - it's the bung failing.Leave a comment:
Am wondering as well. I've also seen a few FCs leak in older GM/Ford ECUs. likewise Nichicon PF/PL/PR, NCC LXF/LXJ leakers that I can remember that I've seen in many 80s/90s old electronics. Does anybody know if FC uses quaternary ammonium salts or something related like the early Low ESR from that era? Am aware that FC is non-aqueous.Leave a comment:
Huh, PM? PW is supposed to be a miniaturized analog of PM.... That's not very reassuring. Don't they both use the same non-aqueous electrolyte?
It would be nice to use only LXZ, but NCC caps are often much more expensive.
Wester547: would you agree with the statement that it is possible to find old butyric acid capacitors in some 50 year old equipment that still test perfectly fine?Leave a comment:
Another example: UCC's KZG datasheet claims that KZE and KZG share the same electrolyte, just as KZJ's datasheet says KZG and KZJ share the same electrolyte. Yet KZE is still much more stable than the other two series (although it's worth noting KZE has a considerably smaller percentage of water in the electrolyte).
I recollect you saying the case size was 5x11 for those 100uF 16V Nichicon PM capacitors, though. According to the datasheet, it should be 6.3x11. So I wonder if they truly were genuine.Nichicon PR, PF, PL, PY, PQ, and PG were all affected by the “quaternary ammonium salt” issue.
Have 5 more in my stock, but they haven't gotten worse.Leave a comment:
The Panasonic FC series also got popular for audio use because they sound fine, not a lot of distortion or dielectric non-linearity.
I have to recap a soundbar and subwoofer, going to use FR series although they are specifically stated as "not for automotive use" for some reason.
there is also an ISO standard.
at the moment only FC passes.Leave a comment:
I've used Nichicon PW in some PSU repairs, and so far so good.
I am still a bit weary of some of the Nichicon entry-level caps, though. For example, I had genuine (from Mouser) Nichicon PM leak from the bottom (from the leads) while still new in package after a few years in storage. I've also seen old Nichicon PR caps do that. Not sure if PL was affected too.Nichicon PR, PF, PL, PY, PQ, and PG were all affected by the “quaternary ammonium salt” issue.
I have to recap a soundbar and subwoofer, going to use FR series although they are specifically stated as "not for automotive use" for some reason.Leave a comment:
I am still a bit weary of some of the Nichicon entry-level caps, though. For example, I had genuine (from Mouser) Nichicon PM leak from the bottom (from the leads) while still new in package after a few years in storage. I've also seen old Nichicon PR caps do that. Not sure if PL was affected too.Leave a comment:
A bit late to the conversation, but the obvious question would be about Nichicon's FC equivalent which is PW.Leave a comment:
Yea don't get me wrong, I'm not trying to be the dictator of Badcaps here!
But the thought I had was exactly what you write: how many more brands/models do we put on the "maybe bad list"?
I mean it's pretty strange that HM/HN was not updated on that list even!
P.S: I added the note about KZG maybe being ok from year 2008 that you informed me of in another thread way back when.Last edited by Per Hansson; 02-12-2020, 10:24 AM.Leave a comment:
This specification for the ASUS Pro Series D320MT-I564000234 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Pro Series D320MT-I564000234 boardview and Pro Series D320MT-I564000234 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...09-12-2024, 03:28 PM
This specification for the ASUS Pro Series D320MT-TR362D can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Pro Series D320MT-TR362D boardview and Pro Series D320MT-TR362D schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...09-12-2024, 03:28 PM
This specification for the ASUS Pro Series D320MT-I564001774 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Pro Series D320MT-I564001774 boardview and Pro Series D320MT-I564001774 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...09-12-2024, 03:28 PM
This specification for the ASUS Pro Series D320SF-I564000134 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Pro Series D320SF-I564000134 boardview and Pro Series D320SF-I564000134 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...09-12-2024, 03:28 PM
This specification for the ASUS Pro Series D310MT-0G32500650 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Pro Series D310MT-0G32500650 boardview and Pro Series D310MT-0G32500650 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...09-12-2024, 03:28 PM
- Loading...
