Component Identification Help Please
  • Nevillet
    • Sep 2019
    • 272
    • United Kingdom
    Hi All,
    I have just momentarily short circuited the output of an amplifier and heard a pop. On inspection it took out a 2.5A fuse and also what I think is an NTC thermistor.
    Excactly like the black one pictured here:
    My question is, am i right is this an NTC and if so how do i identify the rating/spec in order to get a replacement.
    Many thanks
  • R_J
    • 9583
    Re: Component Identification Help Please
    Yes it is a NTC made by Cantherm, Pt# MF72-010D15
    • Nevillet
      • Sep 2019
      • 272
      • United Kingdom
      That's great, many thanks.
      • Shulgin
        Acer predator XB241YU Component identification
        by Shulgin
        I have a problem with my Acer predator XB241YU screen. When I plug it in, the startup LED turns on instantly, and I can't turn off the screen without unplugging it.
        After disassembly and inspection of the electronic cards I found what looks like a broken inductor, it is marked with the letter A and is at location L58.
        In the first photo you can see the broken component, in the second photo you can see where it is on the board, in the third photo you can see the silkscreen and in the fourth photo you can see the identification sticker of the main board
        I...
        05-11-2024, 11:06 AM
      • thebomb602
        ASUS GA402R IC identification
        by thebomb602
        Hey guys! my name is kyle, new to motherboard troubleshooting and a little confused still on chip identification if yall could help identify this chip..
        also if you could teach me how to fish on this particular topic... i did read through the ic identification sticky, and couldnt identify this with that info... thanks!
        EDIT, just realized thats a 5 and not an S in the first line... finding results for it now. cant figure out how to take down thread so im not embarrassed...
        11-21-2023, 02:30 PM
      • Tend0
        hp elitebook 840 G4 no 5v IC identification
        by Tend0
        Hello everythone
        i have on the bank hp elitebook 840 G4 6050a2854301 mb a01 missing 5V cause IC is damage on this board 5V and 3V IC is separatly
        i have 3V but no 5V i found 5V IC damage . i need our help to find IC identification, the 3v ic has mentionned ALVH 572 i found reference but no see something like IC . I poste the 3V here if someone have is reference. i don't found motherboard schematique or boardview...
        05-31-2025, 09:13 PM
      • Tomylee
        Identification of Component T5 on NEXIQ USB-Link 2 (damaged due to crushing)
        by Tomylee
        I'm currently repairing a NEXIQ USB-Link 2 that was physically damaged due to crushing. After a thorough inspection, it appears that only one component is visibly damaged: the T5 component, located right next to the Mini-USB port.
        It's a 4-pin SMD component, with one pin at each corner, aligned front-to-back along the USB port axis. Unfortunately, it is broken, and there are no visible markings left on the part to identify it.
        I'm looking for help with the following:
        The exact identification or part number of the T5 component
        05-28-2025, 12:42 PM
      • FrozenHaxor
        SOT23 component identification
        by FrozenHaxor
        Hello, I have two identical circuits and one has a component with a hole in it, it is some sort of MOSFET driver, as two gates of large MOSFETs are connected to the lower right pin of it, I'd rather avoid guesswork if positive identification is possible.
        04-09-2025, 03:17 AM
