Identifying Soldering Faults
  • Richie_asg1
    • Feb 2009
    • 21
    Just thought this is worth a look for examples of good practice -
    http://workmanship.nasa.gov/lib/insp...uirements.html
    As a newbie to most of this. This kind of information is needed so we can spot a good one from a bad one.
    Please post other example pictures in this thread as you see fit.
    Other pictures from the net - copyright of their original owners.
    (All of the above are actually bad)
  • MegaOne302
    • Apr 2009
    • 94
    Re: Identifying Soldering Faults
    Check this site out; they have mostly every type of PCB defect possible.
    Does an idiot make a sound if no one’s there to hear them talk?
    • Wizard
      • Mar 2008
      • 2296
      Here's extremes.
      Was in 2002:
      You have a circuit board that passes all visual tests till a experienced tech showed me and I was shocked. Through hole capacitor lead is not bonded to the solder even you had all good signs of solder! It was easy test, Wiggle the component back and forth, it will break the weak bond.
      Hot glue on the component will and does wick down into the through hole and destroy the solder bond by thermal cycling due to thermal expansion cycles in 1 to 2 years and low-level ultrasonic vibration (unavoidable with switching regulators, *any* transformers in 20-100KHz range. That was original manufacture. So I do no longer use hot glue. I use RTV to secure components where necessary.
      Now exact device that DID not get the hot glue on same component, said failure did not happen.
      This also depend on OEM design to keep resistors and component within thermal envulope when item is operating. Exceed that and you will have cracked solder.
      Cheers, Wizard
      • krazykev64
        • Feb 2009
        • 49
        just to inform forum members that it is not just computers and other similar items that have bad solder joints. i have a friend who owns a business specialising in Nissan cars. there are various models of nissan that are prone to faulty air flow meters. this is the part on the inlet manifold that looks like a carb. if it is the type with an alloy plate around 2 by 2.5'' then i will let you into a little secret. first of all you need to remove the unit which is easy. make sure you disconnect the battery first. if you remove the little plate by cutting the black sealant and then prising it off with a small screwdriver you will see a 2 small circuit boards. the problem is the solder joints as they are prone to breaking down causing the car to run rough. 99 times out of a 100 there is no faulty part. you just desolder then resolder the joints on the top board and fix the plate using silicone sealant and the job is done. i have been repairing these units for my friend for around 4 years and virtually every one has worked ok. i have even included a picture of the board with the alloy plate removed. before you remove the throttle position sensor make sure you mark it first so it goes back the same way. a full guide can be downloaded from
        https://cdn.badcaps-static.com/pdfs/...50931bd89c.pdf
        • japlytic
          • Oct 2005
          • 2086
          In 1975 (the same year colour TV started broadcasting in Australia), my parents bought a Rank Arena C1851 (if the model is correct, because they said that the size matches the description). This was a rebadge of an NEC set.
          I was told that it had a number of bad solder joints and apparently worked when warm. It was even put on top of the barbecue and worked then, then it finally stopped working completely in 1983 (if that is correct), when they bought a more reliable Thorn (Mitsubishi rebadge) set (still working today, never required repair since day one!)
          In a valve (or tube) radio which I use every day, it developed an intermittent problem, which was caused by a bad solder joint when replacing the paper capacitors.
          A heat gun can help identify areas with bad solder joints.
          • Player2
            • Aug 2009
            • 98
            Originally posted by Wizard
            Here's extremes.
            Was in 2002:
            Cheers, Wizard
            Wow! That's good to know. I've used hot glue a couple times, even Googled it and couldn't find anyone saying it was a bad idea. Will definitely use the RTV silicone from now on.
            • acedogblast
              by acedogblast
              11-02-2024, 05:13 PM
            • Ady2017
              SMD fuse soldering advice please
              by Ady2017
              Hi all. I need to replace an SMD fuse on my camcorder and this is the first time I have had to do any SMD soldering so your advice would be appreciated. Below is a picture of the board that I am working on and I have highlighted the fuse that needs to be replaced. I managed to zoom in to take this picture but the fuse is really tiny and is sandwiched between other components so this is going to be a new milestone for me. I appreciate that I am going to have to buy a new soldering iron if you could advice on what I need please. I was thinking about putting a big soldering iron across the whole...
              11-07-2025, 12:03 PM
            • mitsu2k
              The Real Dangers of conductive glue.
              by mitsu2k
              I know many folks on this forum warn against conductive glue and suggest removing it immediately upon site. I'm here to vouch and say these people know what they are talking about. To be more accurate, the glue isn't intended to be and doesn't actually start out conductive. It gets conductive as it is heated by components that get hot. The glue starts out to be a light tan color but as it is exposed to heat, it gets darker and darker until it is a dark brown. I have found that it becomes conductive at the point that it reaches a light brown color on darker.
              Here is an experience I...
              04-16-2023, 06:29 PM
            • Azurain
              Elitebook 840 G5 Bios Chip Soldering Question
              by Azurain
              I have an HP Elitebook 840 G5 that I am trying to get working again. I've removed the front bios chip (the 32mb one) and have run it through HP unlocker already. I've uploaded and verified the new bin, but am now experiencing an issue that has led me to believe I've been soldering the chip back to the motherboard incorrectly.
              Essentially, after re-soldering the chip back into its place and reassembling the laptop, the charging light immediately flashes orange and white and then shifts to a solid white. The capslock and numlock lights blink seven times...
              04-14-2023, 06:58 PM
            • SarcasticOP
              Seeking Guidance on Motherboard Diagnostics
              by SarcasticOP
              Hello everyone!
              I hope this is the correct place to post this, if not please let me know and I will post in the appropriate location.
              I'm venturing into the intricate world of board repair within electronics, and I'm reaching out to this community for some guidance and shared wisdom. I have tried to do some research myself and find this information on my own, but I don't know what I don't know, and that is really starting to become an insurmountable issue that I cannot overcome. The only person I had nearby that I could turn to passed away recently so I do not have anyone...
              01-10-2024, 03:35 PM
