Help with capacitor substitution for a DVR
  • hitokage
    • Jun 2013
    • 6
    • U.S.A.
    I have a DVR that I was replacing the fan in, and noticed one of the capacitors on the power supply board had failed (all others are fine). It was slightly domed with the bottom pushed out. It's a Rubycon 2200μF 10V MCZ - so it's ultra low ESR. Since these have been discontinued, there isn't a direct replacement. I've tried finding something with similar specs, and what I think will work is the RNL series from Nichicon - specifically this one. It's the same capacitance, slightly higher voltage rating (which I understand is fine), and the diameter is the same, slightly shorter (height isn't critical here anyway). I think the ESR rating is okay - the Rubycon is rated to 9mΩ and the Nichicon for 8mΩ. It's the ripple current rating(s) I'm not sure of, and possibly other things I'm not aware of/overlooking.
    Basically is this a good substitute, or does anyone have a better recommendation?
    Thanks in advance to all that respond.
    • 31025
    Re: Help with capacitor substitution for a DVR
    was the dvr new?
    i cant imagine MCZ in a psu.
    • hitokage
      • Jun 2013
      • 6
      • U.S.A.
      It's a DirecTV DVR HR21-100 made in March 2008 (by Thomson).
      It has six MCZ series on the power supply board, and five of them on the main board. Both boards have other various model capacitors - a very quick look shows some ZL and ZLH Rubcon's among a few other makes.
      The HR20-700 DVR (made by Pace) that was their first that had MPEG4 support (circa 2006), also had ultra low ESR capacitors on both of its boards (this one has a combo power supply/main board and then a tuner board). Those had issues with the "capacitor plague" though, and those capacitors were replaced a few years ago.
      • Per Hansson
        • Jul 2005
        • 5895
        • Sweden
        That is a great replacement capacitor you have found!
        ESR matches well and the ripple current rating is almost 3 times better.
        I must agree with stj though, very strange with ultra low ESR caps in a power supply.
        But if that is what they used the replacement will work more than well
          • 31025
          *if* the psu managed to handle MCZ i wonder if it would run with cheap polymers???
          • hitokage
            • Jun 2013
            • 6
            • U.S.A.
            I've attached some pictures of the power supply board from an eBay listing - it appears to have all the same capacitors. So, it doesn't seem to be from someone else previously replacing them. I have two more of these (same model) that I'll be replacing the fans in as well, so that should further confirm they're original.
            The only voltages I know for sure it outputs are +5VDC and +12VDC (which is standard) for the hard drive. The other connector doesn't have the voltage(s) printed on the board, and uses the same color wire for all its connections. They are likely 3.3VDC or less for the Broadcom CPU, RAM, and other supporting components.
            The one that failed is in the cluster of four to the right of the transformer between two voltage regulators. The front two in that group are the same value - the one the failed is the one closest to the transformer. The other MCZ series capacitors on the power supply board and main board are all 1000μF 16V.
            • mariushm
              • May 2011
              • 3799
              I sincerely doubt you need so high end capacitors.
              Most likely it was some overstock capacitors they had, or someone used them instead of other capacitors.
              I mean, you typically need these ultra low ESR capacitors to be soldered as close as possible to the circuit board, as close as possible to the switching regulator IC or transformers to keep the current loop as small as possible.
              Leaving such long leads on those capacitors kind of defeats the purpose, the extra wire length adds resistance and a very tiny amount of inductance
              Should be fairly safe to use FM, FR series from Panasonic, KZE from United Chemi Con...
              Also ...2200uF 10v is kind of in between... the psu outputs 12v, 5v and probably 3.3v ... so a 10v capacitor is most likely used to filter 5v or 3.3v, so you can easily use a 6.3v rated capacitor.
              So this would probably work : https://www.digikey.com/product-deta...198-ND/3998084
              And this 1800uF 6.3v capacitor would probably be just fine : https://www.digikey.com/product-deta...9-1-ND/5180935
              • hitokage
                • Jun 2013
                • 6
                • U.S.A.
                The cluster two 2200μF caps are close to the circuit board, it's the 1000μF that aren't. I'm sure it's not just them trying to use up overstock ultra low ESR capacitors - at least two different manufacturers (Pace & Thomson) and models (HR20-700 and HR21-100) have them. Looking at some of the other power supply boards listed on eBay, the revised version of this DVR (HR22-100) from the same manufacturer (Thomson) also has the same capacitors. I don't know what the design reasoning is, just that's what it has. The plan at this point is to replace both 2200μF capacitors in this DVR - unless after opening up the other two HR21-100s I find a more extensive amount of failed capacitors.
                I have a few other makes and models here that I will eventually be checking for these type of problems, so I'll see what they used. I have a Samsung made version of the HR21 and a Humax version of the HR24 model.
                • PeteS in CA
                  • Aug 2005
                  • 3581
                  • USA, Unsure of Planet
                  Given that this is a product that users are likely to use in ways that make for poor heat dissipation and, IIRC, MCZ is a 2000-hour rated capacitor, I wonder if the slightly higher impedance of KZE, FM, HE, or ZL parts might be a good trade-off for a much better rated life.
                  PeteS in CA
                  • hitokage
                    • Jun 2013
                    • 6
                    • U.S.A.
                    After having a brief look at all the other DVRs, two the exact same model and three others, none of them had visibly failed capacitors.
                    Part of the reason I'm leery with substitution is knowing there was what the design engineers had wanted and then what was actually used due to cost reduction measures. Straying from what was used likely takes it further away from what the original design specifications.
                    While longer rated capacitor lifetime would be good, it would be pointless unless I recap the whole thing, which is beyond what I want to get into.
                      • 31025
                      there is nothing "cost reduction" about MCZ, they were the very best of the best when they were made - they werent cheap!
                      • chth96
                        Is it no harm to replace with capacitor without ripple current rating?
                        by chth96
                        When I tried to repair LG 29 inch CRT TV, I found that the ESR value of samyoung SMS capacitor(160v 2.2uf), which is very close to D1879 transistor, is 6 ohm.
                        Judging from above ESR Meter Table,I think It is necessary to replace this sms capacitor.So I visited local electronics shop,and I purchased 160v 2.2uf rubycon YK capacitor.
                        But when I browse through rubycon YK datasheet,I found that there is no ripple current rating for 160v 2.2uf specification. But On the contrary, I found 39 mA ripple current rating for 160v 2.2uf SMS capacitor.
                        Rubycon YK DataSheet (b...
                        04-19-2024, 05:19 AM
                      • Prolog
                        RTX 3080 FE Identifying capacitor
                        by Prolog
                        Hi people, I hope this is the correct spot to post this, I'm new to the forum.
                        I have an RTX 3080 Founders Edition which has a burnt up capacitor (it was in parallel with another capacitor which appears damaged too), so I am hoping to be able to identify the capacitor values and order replacements.
                        I hope these photos make it clear which component I am referring to:
                        (yes, the soldering is a bit botched from removing the blown one, I know)
                        I have found the board schematic (attached), but there does not seem to be a boardview available. I have never...
                        12-01-2024, 08:27 PM
                      • Per Hansson
                        Motor run capacitor physical size vs voltage rating & measurements?
                        by Per Hansson
                        (TL;DR skip the first paragraph)
                        I encountered my first dead motor run capacitor at a customer this week.
                        For some fields I guess it is a very common occurrence but the usual way for industrial machines here is to use 3-phase motors.
                        (Unless a servo motor makes more sense that is).
                        But for some reason this 3-phase machine uses a 1-phase motor for its liquid coolant pump.
                        The pump would run but sometimes trip the 10A breaker.
                        I monitored it starting and stopping for over an hour until it finally stopped in a specific spot between its windings:
                        Then it could...
                        09-20-2020, 06:32 AM
                      • Adenitz
                        Explanation of capacitor rating
                        by Adenitz
                        I'm reading an article about the "capacitor plaque" in early 2000s and I have found one sentence I cannot understand.
                        The normal lifespan of a non-solid electrolytic capacitor of consumer quality, typically rated at 2000 h/85 °C and operating at 40 °C, is roughly 6 years. It can be more than 10 years for a 1000 h/105 °C capacitor operating at 40 °C.
                        What this 2000h or 1000h means? Why 1000h capacitors have longer life span?
                        12-26-2022, 12:36 AM
                      • chth96
                        If I replace with inferior capacitor, Is it No harm to other IC components at all?
                        by chth96
                        I replaced some capacitor which is located on optical pickup pcb which is shown in the table below(PCB #2).Because it have been out of order.
                        Now,It works very well,But I just have found that all caps (6svpc100my and other part number as well) ,which is shown in the table below, has ultra-high ripple current spec.
                        It is not able to obtain any capacitor which can be a substitute for this ultra-high ripple current nichicon capacitor.
                        So I replaced it with samxon and rubycon's general capacitor(GP,YXA series).
                        I know that these capacitor will not last as long as nichicon capacitor...
                        12-22-2023, 04:34 AM
