Going to order some caps, any recommentations?
  • s0lid
    • Jul 2009
    • 14
    I'm planning to get some caps for mobo + graphic card repairing. Well just a lot more what i've had earlier :P
    25x 1000uf 10V Panasonic FC 10x16mm caps ~10$ Digi-key
    25x 1000uf 10V Panasonic FC 8x20mm caps ~10$ -||-
    25x 2200uf 16V Sanyo MV-WX 12.5x25mm caps ~35$ Local store
    50x 680uf 6.3V Sanyo Os-Con 10x11.5mm caps ~72$ Ebay
    Any recommentations etc?
    Same s0lid from XS and 2cpu forums.
  • shadow
    • Feb 2007
    • 732
    Re: Going to order some caps, any recommentations?
    They all look good.
    The only thing to be really careful about is that the capacitors from Ebay are real and not counterfeits.
    I am not sure that you are aware of this, however Panasonic FM have much better specifications than Panasonic FC. Having said this the FC's are still very good for most applications.
    • s0lid
      • Jul 2009
      • 14
      Originally posted by shadow
      They all look good.
      Thanks, looks like FMs lifetime is twice longer than FCs at 105C and little cheaper too
        by momaka
        03-12-2025, 03:42 PM
      • Foetuss
        Gigabyte GA-6OXT :: caps question
        by Foetuss
        Good evening
        I recently aquired a rev 1.1 Gigabyte 60XT, and was suprised of the amount of leaking caps for a motherboard of the P3 era. Especially the way the 330µf caps seems like the housing discolored even.
        Now, there are some 3300µF 6.3V KZG series around the CPU. Would it be OK to replace them with something like EEUFR1A332 ? (Panasonic FR 3300µF 10V). Or was this board designed around very low ESR caps?
        But I was also suprised about the bigger boys, which are 330µF 25V.
        Could it be they used 25V caps because they were cheaper / available at that time?...
        02-11-2025, 12:22 PM
      • eryjus
        by eryjus
        05-10-2023, 11:21 AM
      • Paxman_Swede
        by Paxman_Swede
        Hello!
        01-14-2025, 09:51 AM
      • black6host
        Replacement caps for Samson Resolv studio monitor 65A Amp board.
        by black6host
        Good day!
        I have a Samson Resolv studio monitor that has no sound output. I've opened it up and found two caps that are bulging on what I believe to be the power supply section of the amplifier board. The board is marked Resolv 65A AMP V1.2. The caps in question are YUSCON, 2200uF, 35V, 85C temp and have markings of RA(P) and are 16mm x 25.5mm tall. I've attached the schematic and the caps in question are C5 and C6. I'm assuming they are low esr caps. I've tested both caps and they test low uF, nowhere near 2200uF.
        I'm going to replace the caps and I'll be the first...
        02-06-2024, 08:22 PM
