How is Jackcon nowadays?
  • Leopard
    • Mar 2008
    • 109
    • Finland
    My ADSL modem is getting flaky. Opened it up and found Jackcon caps, none bulging, but man that thing runs hot. Some caps are hot to the touch and you cannot keep your finger on them for longer than ~5 seconds. Any recent findings of bad Jackcons? They have -07 datecodes on them.
    Symptoms are:
    - Large delay in page loading times. (This "Post New Thread" page took 228 seconds to fully load!) Even Google takes ~10 seconds to load.
    It hasn't dropped the connection, but yesterday I power cycled it and the symptoms went away. Today, it's doing the delay thing again, and power cycling helped only mildly. Could dried up caps cause this?
    Make and model is A-Link RR84.
    Thanks for any help.
  • ratdude747
    Black Sheep
    • Nov 2008
    • 17136
    Re: How is Jackcon nowadays?
    a hot cap is a bad cap, symptom of high esr. some caps fail without visual signs. replace all bad brand caps including jackcon, which is a known troublemaker.
    sigpic
    (Insert witty quote here)
    • Agent24
      I see dead caps
      • Oct 2007
      • 5027
      • New Zealand
      Couldn't just a generally bad router design also cause the capacitors to run hot?
      Of course if it only just started doing it, then you know the capacitors are the problem and should be replaced...
      -David VanHorn
      • zklgfs
        Anker SoundCore 2 Bluetooth Speaker Turns Off After a Few Seconds (Possibly Firmware Issue?)
        by zklgfs
        I have an Anker SoundCore 2 (A3105) that I saved from the trash (well, I guess there's a reason why it was supposed to go into the trash...). The problem is that it always turns off after a few seconds (sometimes it stays on a bit longer, between 30 and 60 seconds, but it still turns off). The power light turns on and the bluetooth light starts blinking, but both abruptly turn off again. The "turn off sound" is still played after the lights turn off. Sometimes, it also loops the on-off cycle several times without me pressing any buttons. If I connect an AUX cable, music...
        08-11-2025, 02:14 PM
      • twonk9098
        Lenovo Legion 5 high fan spin turns off after 34 seconds
        by twonk9098
        I have a Lenovo Legion 5 with a Ryzen 7 series CPU and RTX 3070 GPU. My issue is that it turns on and all seems fine except after a few seconds the fans spin up high and the laptop turns off after 34 seconds.
        I can get into bios and can even boot and login to Windows however after 34 seconds no matter if Im at the bios screen or booted into Windows it will just turn off.
        I have managed to run HWmonitor and the temperatures of the CPU and GPU are fine, I can also touch the heatsync which is warm but not hot.
        I have tried a few new bios but exactly...
        07-14-2024, 11:19 AM
      • liquidzorch
        Lenovo 15iml05 Power led lights for 12 seconds then off 12 seconds
        by liquidzorch
        Hello. I bought a faulty Lenovo ideapad 3, but it turns out the 3Valw buck converter burnt a hole through the board. I was able to clean it up, and remove all the shorts. I now can power the 3.3v rails from a bench power suppy while connecting the laptop to its psu, and I get the additional 5valw, 1.8v, and 1.05v, form what I can tell in the schematics, those are the only 4 voltages I should see before turning on, and they are present. When I hit the power button, the power indicator on the left side turns on (not the one on the power button), stays on for about 12 seconds, then turns off for...
        10-18-2024, 05:19 PM
      • Rick_1234
        by Rick_1234
        Good evening, gentlemen.
        Things I tried
        06-22-2024, 04:44 PM
      • PowellSkier
        Harman/Kardon AVR 645 returning to stand-by after a few seconds.
        by PowellSkier
        A Harman/Kardon AVR 645 repair has been a hobby of mine for the past several years. My latest attempt involved the purchase of a DOA unit for part swapping and testing. The original AVR would power up then shut down after a few seconds. I completely tore down both units, found a couple of bad components and reassembled one of them. Same issue, no speakers connected. After extensive research I found a repair document from Harman/Kardon that explains the protection circuit in fantastic detail and provides specific test points for each fault (power, DC detection, overload & power) and the voltage...
        06-17-2024, 11:43 AM
