Are these caps ok ?
  • bianchi77
    • Jun 2016
    • 1121
    Are these caps ok ?
    Dear Members,
    I saw these mark on primary caps,
    Are they ok ?
    Have a look on my photos,
  • bianchi77
    • Jun 2016
    • 1121
    Re: Are these caps ok ?
    anyone?
    • PeteS in CA
      • Aug 2005
      • 3581
      • USA, Unsure of Planet
      Your pix are not well focused, but if you mean the reddish marks on the PCB, those are probably inspection marks (made by the inspector to show (s)he looked at that part).
      PeteS in CA
      • R_J
        • 9591
        Looks like there is glue holding the caps in place, this is common.
          • 31214
          glue - probably EVOstick!
            It looks like it spreads all the way to the Bridge rectifier, just remove the cap and see.
            • bianchi77
              • Jun 2016
              • 1121
              Is it glue or the liquid from leaking capacitors ?
                That is why you remove the cap to find out, I cannot really tell from the pictures.
                  by momaka
                  03-15-2023, 10:17 PM
                  Casing Power MPT-301 [PCB ATX9806b-p REV: A3]
                  by momaka
                  This one should make @Pentium4 smile (if he is still reading BCN forums) – I got a new old stock / open box Casing Power MPT-301 PSU on eBay for $4 total.
                  Yes, it’s a very generic-looking box, but the manufacturer isn’t (at least not back in the days), which is…
                  Macron Power Technology Co. LTD.
                  Let’s look at the PSU itself.
                  The shell/case also appears quite generic, like many “sold-with-the-PC-case” units. However, the shell is well-formed and has decent steel thickness. In terms of...
                  06-02-2021, 10:05 PM
                • eryjus
                  by eryjus
                  05-10-2023, 11:21 AM
                  by momaka
                  03-12-2025, 03:42 PM
                • Paxman_Swede
                  by Paxman_Swede
                  Hello!
                  01-14-2025, 09:51 AM
