Matsushita NXL caps?
  • Behemot
    • 4845
    • CZ
    Found two old Matsushita NXL caps, 47/35 and 100/16. Seems to be 105°C series, likely from early 90s at the latest as it has that white rubber bung (with no canals/openings for washing soldering agents away). Found nothing, no datasheets, any idea what type is this series?
    • 31015
    Re: Matsushita NXL caps?
    isnt matsushita = panasonic?
    • Behemot
      • 4845
      • CZ
      Since 2008. How does that help me?
        I just do the search for 'panasonic NXL series capacitor'.
        • Behemot
          • 4845
          • CZ
          Interesting, been searching here (BC) and found nothing so I thought it'll be worse So this looks like "long life" series…thanks!
            by momaka
            03-12-2025, 03:42 PM
          • eryjus
            by eryjus
            05-10-2023, 11:21 AM
          • Paxman_Swede
            by Paxman_Swede
            Hello!
            01-14-2025, 09:51 AM
          • captain150
            by captain150
            03-16-2025, 07:34 PM
          • Foetuss
            Gigabyte GA-6OXT :: caps question
            by Foetuss
            Good evening
            I recently aquired a rev 1.1 Gigabyte 60XT, and was suprised of the amount of leaking caps for a motherboard of the P3 era. Especially the way the 330µf caps seems like the housing discolored even.
            Now, there are some 3300µF 6.3V KZG series around the CPU. Would it be OK to replace them with something like EEUFR1A332 ? (Panasonic FR 3300µF 10V). Or was this board designed around very low ESR caps?
            But I was also suprised about the bigger boys, which are 330µF 25V.
            Could it be they used 25V caps because they were cheaper / available at that time?...
            02-11-2025, 12:22 PM
