Gigabyte GA-K8NXP-SLI poly replacements?
  • Yakusa
    • Jan 2019
    • 7
    • Poland
    Hi. Have this decent motherboard. I want to ask for recomendation about replacement this bad caps for poly caps.
    https://photos.app.goo.gl/K8qeHyfrtAQwzo3t8
    (blue board, two first images are from ASUS P5B-VM motherboard)
    5x 3300uF, 6.3V
    4x 1800uF, 6.3V
    Thanks in advance!
  • Sparkey55
    • Jan 2010
    • 1523
    Re: Gigabyte GA-K8NXP-SLI poly replacements?
    Who is the maker of the first two photos yellow/tan motherboards.
    If not ASUS then those caps are in backwards, reverse polarity.
    • Yakusa
      • Jan 2019
      • 7
      • Poland
      Hi. The first two images are from ASUS P5B-VM from this thread
      https://www.badcaps.net/forum/showthread.php?t=74482
      (edited description. sorry)
      • Stefan Payne
        • 1267
        Crappy low end Polymers like Kemet A750 are a good idea for the KZG
        1500uF/6,3V is somewhat similar. For the 3300uF you can either also use the A750 or switch to Panasonic FM. Those tend to be a bit larger though.
          • 31289
          4x 1500/6.3
          the 3300's are going to be tricky, the largest poly's iv seen are 2000
          • Stefan Payne
            • 1267
            There are some new Nichicon IIRC, but they are too low ESR.
            BUT: Pana FM are comparable to KZG, just a bit bigger.
              • 31289
              bigger is a problem near heatsinks though.
              i'm not sure the esr is such a problem in vrm circuits, they are often filled with ceramics anyway.
              • Yakusa
                • Jan 2019
                • 7
                • Poland
                I drop polymod... Im not a pro.
                But id like to know Your opinion about this replacement for 3300uf 6.3v capacitors
                https://www.digikey.com/product-deta...9CT-ND/7381288
                They are worth to buy? Universal fit for all boards 10mm footprint, 5mm lead spacing.
                • ChaosLegionnaire
                  HC Overclocker
                  • Jul 2012
                  • 3266
                  • Singapore
                  thats not a universal fit! your board uses a mix of 8mm and 10mm diameter caps for the cpu vrm output. measure the caps there and make sure the right sizes fit.
                  the 3300uF ones are 10mm in diameter and the 1800uF ones are 8mm in diameter.
                  and yakusa, please do not link your images to external sites. use the attach files manage attachments function when posting to upload your photos to the forum website.
                  • Stefan Payne
                    • 1267
                    You have no choice as there are no other decent 8mm types available besides polymer capacitors.
                    Those small 6,3V/1,500uF you have to replace with polymers - or use inferior parts.
                    The best you can do non polymer is Panasonic FM 1200uF, if you're lucky to find it.
                    Polymers are easy to find in that size...
                    Not really...
                    Because they are to replace Ultra Low ESR Capacitors.
                    The FS Series is new and optimized for size but doesn't have the ripple current and ESR as the KZG Series.
                    With Polymer Caps for the smaller ones that might work well, without them, it might not be the best idea...
                    • DynaxSC
                      GIGABYTE GA-H110M-S2 - Stuck at Debug Code C2 - don't like Patriot Viper Steel RAM but works with G.SKILL
                      by DynaxSC
                      I discovered a strange behaviour of GIGABYTE GA-H110M-S2 board.
                      General test conditions:
                      - Tested with Core i5 6500 and Core I7 6700K - no difference
                      - Default BIOS settings, but tried also altering several memory setting - does not change anything
                      What is wrong:
                      With BIOS F1 and F2 the board normally POST's and boots to Windows 11 with 2 x Patriot Viper Steel PVS416G440C9K RAM (4400MHZ, Samsung B-Die chips)
                      When BIOS upgraded to anything above F2 (ie. F20-F27b) the board POST stucks after 3 Debug Codes on Code C2
                      03-21-2025, 06:23 PM
                      Thermal pad thickness for various laptop GPU / Graphics Cards
                      ASUS Dual RTX 2070 OC 8GB
                      ASUS ROG STRIX RTX 3080 OC
                      ASUS ROG STRIX RTX 3090
                      ASUS TUF Gaming RTX 3080 OC Edition
                      ASUS TUF GTX 1660 S-O6G GAMING
                      EVGA RTX 3060 Ti XC GAMING 8GB
                      EVGA RTX 3060 XC GAMING 12GB GDDR6
                      EVGA RTX 3080 FTW3 ULTRA GAMING
                      EVGA RTX 3080 TI FTW3 ULTRA GAMING
                      EVGA RTX 3090 XC3 ULTRA GAMING 24GB
                      Gainward RTX 2080 Phoenix GS Specs
                      Gainward RTX 3070 Phoenix 8GB
                      Gainward RTX 3080 Ti Phoenix
                      GIGABYTE AORUS RTX 3080 MASTER 10G
                      02-09-2024, 08:08 AM
                      A Dead/DOA Gigabyte GP-P450b 450W ATX PSU
                      by momaka
                      More eBay specials: this time a Gigabyte GP-P450b 450W ATX PSU for $8 with free S&H. Listed “For part/not working”, as usual. Showed up in a beat up EVGA box without any padding… but that's understandable given the total price. PSU made it out fine without damage. It's a non-modular (yay!), pretty modern-day looking PSU with a black paint and all black cables (meh, not my favorite, but figure it's good to keep a few of these in case I do need one for a more modern PC build, just so my old gray boxes don't look too odd in there.)
                      And a shot of the label:...
                      01-26-2022, 03:26 AM
                    • nikovmiroslav
                      Gigabyte A5 X1 Need Bios
                      by nikovmiroslav
                      Hi Everyone,I need help with this strange Gigabyte laptop,it turns on with black screen and after 30sec fans on the Max for few seconds and it shuts down,I think the bios is bricked,They say it is Clevo under the hood,there is nowhere on motherboard what is the model which is strange,i will write S/N and P/N from the motherboard,thats only what is writen there and upload old bios,if anyone can help,Thanks!
                      Gigabyte A5 X1
                      From motherboard:
                      S/N: 1TNH55ER1350895
                      P/N: 6-77-NH55ERQY-D02-2CGB
                      On sticker from the back of the laptop:
                      S/N: SN21351J000657...
                      08-24-2025, 09:15 AM
                      Gigabyte AORUS 15X Netbook Specification for Upgrade or Repair
                      This specification for the Gigabyte AORUS 15X Netbook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 15X boardview and 15X schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Gigabyte AORUS 15X Netbook...
                      09-07-2024, 07:19 AM
