Do all capacitors fail do to evaporating water?
  • 370forlife
    Large Marge
    • Aug 2008
    • 3112
    The electrolyte does deteriorate due to water evaporation; it is no myth. That is the main reason most good-quality mobo manufacturers use solid polymer caps.
    Thats from someone on techspot, they say that its no myth that all capacitors die from water evaporation
    How does the water evaporate when the capacitor is sealed, it will just go back in.
  • Wizard
    • Mar 2008
    • 2296
    Re: Do all capacitors fail do to evaporating water?
    Electrolytics can have non-water types or water-based electroyte. Either way, both fail if the package is improperly done and it get pressurized and vented even capacitor doesn't show sign of pressure damage (doming, popped bung etc) also blown vent or popped bung, both latter are extremes. Does happen either way. By the way water-based elecrolyte had water escape slowly by thermal cycles, pressure, or diffusing through rubber bung. Hence the term "dried out" capacitors or ESR rise.
    Cheers, Wizard
    • Sus256
      HISENSE 65E7KQ PRO - no boot
      by Sus256
      Hi all!
      HISENSE 65E7KQ PRO
      RSAG7.820.13512 - chassis
      MT9618BAATAB - cpu
      RSAG7.820.12059 - power
      HD650Y3U77 - panel
      KLM8G1GETF - emmc
      Replaced emmc.
      Terminal log
      UART
      AC_ON
      E-B
      FDE enabled
      06-01-2025, 02:11 AM
      20 year old Kenmore refrigerator ice maker bad water valve coil took a crap
      I got lucky that when I got home and was about to get some ice out of the ice dispenser I hear and see water running down the outside of the ice dispenser what the heck is going on here
      At first I thought that the ice dispenser mold was cracked so I brought a new ice maker because this one has been in there for about 10 years now
      Well I put the new one in and wait and I wait for the water valve to open and let water in no such luck well there is a way to check the function of the motor and the water valve on this ice maker just need a jumper wire “L” to...
      04-09-2023, 08:04 PM
    • edugimeno
      Stagg sms12p audio amp has water damage
      by edugimeno
      Hi! My friend just brought this audio amplifier/speaker fro his music band saying they realized its got no sound. Led powers up but there no sound at all
      I opened it and found 3 board. 2 of them are for input plugs and potentiometers, and the other larger board has the amplifiers for 2 large speakers that it drives
      There's also a large toroid transformer that feeds a lower voltage to the first 2 boards and a larger voltaje (36x2 rectified close to 100v) to the power board. The power board has the plugs for both speakers
      There is only one signal wire connecting the first boards...
      05-24-2025, 06:00 AM
    • RetroComputingGrotto
      Water Damaged Toshiba 48L1435DB
      by RetroComputingGrotto
      I have a water damaged Toshiba TV that was hanging nicely on the wall then over the summer we had a new multi-million pound boiler system put in and right where this TV was hanging is a nice new pair of water pipes for the radiators...
      The TV hasnt been used for a fair few months but it was needed again the other day and needless to say, it didn't power on or show any signs of life (no standby LED etc). After checking the fuse in the plug (and that the socket it was plugged in to worked) I decided to get up some step ladders to take a closer look and low and behold! It looks like...
      10-07-2024, 08:23 AM
    • rzsn
      water damaged G513I
      by rzsn
      Hello friends, so I have got a "water damaged" (or cola/beer/coffe .. something dark and sticky) G513I system - which has the board and schematics from this thread. After cleaning up all the visible sticky residue with water and detergent (thankfully mostly on the top/keyboard side), I have a partial success. IPA was of no use for cleaning this.
      Using a bench power supply on the DCIN jack (as it seems that the PSU keying pin is not wired at all - series resistor R6003 is not populated), and using a shoring wire for the power button (either pin 5 on CN251 keyboard, or one...
      12-22-2024, 09:02 PM
