Caps on QDI MOBO
  • Gianni
    • Jul 2008
    • 681
    • Italy
    Caps on QDI MOBO
    I posted a question here and I'm back with more questions: I received yesterday a PC that began to have problems.
    Sometimes it start correctly and most of time it doesn't POST at all; when this happen very often it emits BEEP as RAM was missing.
    I tried different memory bank but the MOBO behaviour it is not costant: sometime it BEEPS sometime it stays silent even if CPU FAN is running but very seldom it POST.
    I can't identify the BRAND caps around CPU, they are aluminum without sleeve with HD W4 text on top; they look good OK.
    There 10 small caps, 1000uF 6.3V, spread on the board, they are green with a gold logo; I suspect these are not good and part of the problem. I can't identify the brand.
    There are 2 Fujicon 470uF 10V, they look good.
    What I would like to try is to connect good caps in parallel to the 1000uF 6.3V and see if the problem is there.
    About PSU: it is an Alied , it has been changed not long ago and it looks still OK but I will test the MOBO with a better PSU.
    Here few pics of the MOBO (Kinetiz 7E-A VIA).
    Ciao
    Gianni
    "In the confrontation between the stream and the rock, the stream always wins...Not through strength, but through persistence."
    H. J. Brown
    master hoarder
    • May 2008
    • 12175
    • Bulgaria
    Re: Caps on QDI MOBO
    The sleevless caps with HD on top are Nichicon HD. I don't think those had any problems like the HM/HN, so they should be good (but you never know what that Allied PSU could have done to them).
    As for the green caps - I've never seen their logo before so I don't really know anything about their quality. They do seem suspicious, though.
    You can try and add caps in the empty spots in VRM, but I doubt the problem is with the Nichicon HD caps. I'd say the green caps are crap and need replacing, but like I said, I've never seen them before so I wouldn't know what their quality is like. They are around the ram slots, so that could explain the weird beeping as if memory was not present.
    • Gianni
      • Jul 2008
      • 681
      • Italy
      Hi momaka
      I followed your suggestion and this afternoon I replaced the green caps and the 2 Fujicon, here attached some pics.
      I replaced the 1000uF 6.3V (green caps) with 1000uF 10V Panasonic FM and since I had not enough pieces I used one 1000ยต 16V; for the Fujicon I had not FM caps so I mounted Rubycon YXF caps.
      I didn't try to place the caps in parallel because it is not esy to solder them, the solder points are not big.
      The logo on green caps is DST , I will test them on Monday in my office.
      As I wrote before, I don't know what happen to this PC, probably someone tried to fix it with an hammer... just look to the cabinet pictures attached here.
      Right now I'm updating windows and I want to run some test and I hope everything will be all right otherwise next step is to replace all HD caps.
      Ciao
      Gianni
      H. J. Brown
        master hoarder
        • May 2008
        • 12175
        • Bulgaria
        Maybe the guy didn't use a hammer. Maybe he just hit it very gently, but the case was crap and it just crunched . After all, isn't this the Deer/Allied/L&C case that came with the Allied PSU?
        I have a few cases like those as well and they seem to be made of very cheap steel. A beer can is easliy stronger. Hopefully the motherboard hasn't been damaged by that case.
        I also did a quick research on the DST caps. Both capacitorlab and this website list them as bad. Same with the Fujicon caps. From what I noticed on different threads here, they seem to be very common for QDI boards too.
          Seasonic B12 BC-550 โ€“ barely 2 years old and with BAD CAPS already!
          by momaka
          03-12-2025, 03:42 PM
        • eryjus
          by eryjus
          05-10-2023, 11:21 AM
        • ChaosLegionnaire
          by ChaosLegionnaire
          09-13-2022, 09:02 AM
        • Paxman_Swede
          by Paxman_Swede
          Hello!
          01-14-2025, 09:51 AM
        • jimjoe123
          LCD TV Green/Pink screen problem
          by jimjoe123
          I have a Dick Smith 37" LCD TV, Model GE6804. I am using it as PC extended monitor only.
          Problem is while watching tv, I hear a semi loud click(like a electrical breaker tripping due to overload, just sound like it but no actual electrical overload), then screen is covered with green or pink. I can still see the original picture image but overlayed by green or pink. See attached images. Pink.jpg is what I see, and Normal.jpg is before green or pink screen, What I captured was pink screen, but about 80% of time it's green and 20% of time it's pink.
          Then each time...
          02-23-2020, 01:29 AM
