Help with Sprague cap replacement
  • orangevw
    • Sep 2018
    • 4
    What would be a suitable replacement for this Sprague capacitor. I wasn't able to find any info online for a H9111 cap. It's on an Outbound Mac clone notebook board from 1991. Pictures attached.
    master hoarder
    • May 2008
    • 12175
    • Bulgaria
    Re: Help with Sprague cap replacement
    Are you sure the brown cap with "H9111" is a Sprague? It looks to me like a Nichicon cap with a date code indicating it was produced in week 11 of year 1991. I also see a "PR" text on the other brown cap next to it, so perhaps this is Nichicon PR series. Please confirm.
    If it is Nichicon PR series indeed, I do actually recommend replacing those, as I've seen plenty of these leak electrolyte from the bottom and destroy PCB traces. Direct replacement for Nichocon PR is Nichicon PS. However, PW and PM series will also work, size of capacitor permitting. I like PW the best, as I've really seen those prove themselves in the field. Not that PS and PM are untrustworthy (I use those too in my recaps)... but PW is known reliable workhorse.
    Other alternatives are Panasonic FC, Rubycon YXJ, and United Chemicon LXV, LXY, and LXZ. Chemicon KY and KYB series will probably also work, though. Most (if not all) of these should be easily obtainable through Digikey and Mouser.
    • Wester547
      • Nov 2011
      • 1268
      • USA.
      Momaka, Nichicon’s history specifies that there was a time (September 1970 and July 1991 at least) where Nichicon and Sprague established a joint venture for producing tantalum capacitors, so it’s quite possible that Sprague was also distributing (putting their name on) genuine Nichicon electrolytic capacitors for a time. NCC also bought out part of Sprague’s electrolytic division IIRC, and their tantalum division was eventually sold to Vishay.
      But yes, I agree that replacing the PR, especially now that it is ~27.5 years old, is par for the course. Nichicon’s PR, PF, PL, PY, PQ, and PC series, etc, were all known leakers due to the use of quaternary ammonium salts in the electrolyte. All Japanese brands had their share of leaker series at the time due to this type of electrolyte.
      Nichicon PS is a fine choice for a replacement. PW are indeed excellent, like the above mentioned equivalent series from NCC (LXZ) - I’ve never seen either series fail and you can’t go wrong with them (so long as they are appropriately chosen for their application).
      • PeteS in CA
        • Aug 2005
        • 3581
        • USA, Unsure of Planet
        The Nichicon PS series is supposedly the RoHS-compliant version of the PR series. Similarly the PM series is the RoHS-compliant version of the PL series. These probably are the best go-to series for replacing low impedance caps in vintage equipment.
        The UCC/NCC LXV series is a generation or two newer, but still a safer (= stability) choice than the LXZ or PW series (which are pretty much equivalents). I forget where Rubycon's YXJ series fits in that spectrum.
        In the late 70s into the mid-late 80s, Sprague's low ESR series were 672D (similar to NCC/UCC RX series), 673D/674D (similar to NCC/UCC RZ series), and 676D/677D series.
        PeteS in CA
        • orangevw
          • Sep 2018
          • 4
          Thank you for the options! The H9111 is marked Sprague, just couldn't get a good angle for a picture.
            master hoarder
            • May 2008
            • 12175
            • Bulgaria
            Wow, didn't know that. Thank you!
            I just went by the picture the O/P posted, and both the text and the sleeve color of the cap (along with the "X") vent looked like Nichicon's so I went by instinct here.
            Ah, that explains the "PR" text I saw on one of the sleeves.
            Still, is there no other text on the cap, other than the "H9111" and Sprague? I think there has to be a series somewhere.
            • orangevw
              • Sep 2018
              • 4
              Wow, my bad. I looked again and I missed grabbing a pic of that side. It says 517D(M).
              • PeteS in CA
                • Aug 2005
                • 3581
                "517D" would be the series name. "(M)" is the tolerance, +/-20%.
                PeteS in CA
                  master hoarder
                  • May 2008
                  • 12175
                  • Bulgaria
                  ^ Yup. And here is the datasheet for these (apparently owned by Vishay now):
                  https://cdn.badcaps-static.com/pdfs/...bb0c4a11d9.pdf
                  So looks like these are general purpose 105C-rated caps - i.e. probably no need to go with low ESR ones. That aside, is there a reason why you are changing these caps? Granted they are from 1991 (over 27 years old), so it's probably not a bad idea to change them anyways. But I'm curious if you have checked their ESR, just to make sure these caps are the source of whatever issue you may be having with the board (if there is even one?? )
                  As for replacements, looks like Nichicon VZ, Rubycon PX, and United Chemicon KMG should work. But the entry-level low ESR mentioned in my previous posts above may also be a good idea, if the circuit has any switching regulators on it.
                  • firespace
                    • Aug 2010
                    • 28
                    Any recommended replacement suggestions for this:
                    Sprague 501D106M063LL
                    10uf 63V aluminium axial electrolytic - is there anything particularly special about it being axial, could I just flat mount a standard equivalent radial?
                    Actually quite interested where this brand considered to be any good?
                    I found some for sale and they seem to be selling for a ludicrous sum of money!
                    Thanks,
                    FS
                      • 31033
                      when in doubt - panasonic FR series.
                      axial vs radial - no difference performance wise.
                      • PeteS in CA
                        • Aug 2005
                        • 3581
                        Axial caps usually are general purpose, nothing special about them, possibly excepting some that may be 105C. So, assuming such things are available, a 105C axial part that fits should be fine. If axial parts are not available then kludging is a general purpose 105C radial part should be OK (whatever series from a good brand with a good price).
                        PeteS in CA
                        • ChaosLegionnaire
                          HC Overclocker
                          • Jul 2012
                          • 3264
                          • Singapore
                          how do u fit the legs of the radial cap through the holes meant for axial caps tho? there seems to be clearance issues and the lead spacing makes it awkward to fit one there.
                            • 31033
                            i like to bend one leg back along the cap and put a heatshrink sleeve over the cap so it looks like a radial.
                            you may have to extend the wire doing this.
                            • eccerr0r
                              Solder Sloth
                              • Nov 2012
                              • 8701
                              sometimes I wonder, will this be as bad as leaving radial caps not flush to the board...
                              No difference with extra wire length to fake an axial cap this way, right?
                              (I've straddled the two holes with a radial cap before too and bent both wires close to the board surface. Don't think it's any better or anything but yet another way to mount...)
                                • 31033
                                if you extend the ground and keep the + short it's probably fine
                                  master hoarder
                                  • May 2008
                                  • 12175
                                  • Bulgaria
                                  It depends on the circuit.
                                  Leaving radial caps "hanging in the air" is not always a bad thing. But again, it just depends on the circuit. For any switch-mode (read: relatively high frequency power switching), it can matter and is not recommended. But for GP stuff where high-frequency is usually not involved, the extra lead length of those axial or radial caps hardly matters. If you look on old boards with axial caps, anything high-frequency or RF that needs filtering is usually done with tantalum, ceramic, film, or a combo of these three. The electrolytics on these old boards are simply there for general "smoothing" (and in rare occasions, timing.)
                                  So using radial caps with long leads in place of axial ones is *usually* OK.
                                  • DaveHarry
                                    Seeking replacement for EOL Nichicon PLV1J220MCL1TD. Found APAQ and ELITE (CHINSAN)
                                    by DaveHarry
                                    Hi group,
                                    I am looking for a replacement for Nichicon PLV1J220MCL1TD (22uF, 63V, Conductive Poymer Aluminum Solid Electrolytic, 8x9 but we can go up to 8x11).
                                    While searching, I found some APAQ and ELITE replacements that would fit on our products (APAQ ARHA series and ELITE UGT and UPD series).
                                    How good are these brand/series and what other alternative would you recommend? I've searched the big name already and didn't find an equivalent.
                                    Thanks!
                                    05-27-2024, 08:08 AM
                                  • nick3092
                                    Mid/late 80's Nichicon Yellow Caps
                                    by nick3092
                                    I recently acquired a set of Bose Roomate speakers from the mid to late 80's. Basically the right speaker cabinet is completely passive, and the left one has the power transformer and amplifier circuit in it. Out of curiosity, I opened it up to see what the circuit looked like. Looks like they used all Nichicon VX (2x 4700uF/16v for smoothing off the bridge rectifier), a couple random Nichicon SE series sprinkled on the board, and what really caught my eye - 2 yellow sleeved Nichicon caps (both 1uF/50v with no real series marking. Below are pictures of the caps. The only thing not shown in these...
                                    08-28-2022, 03:56 PM
                                  • reformatt
                                    by reformatt
                                    07-31-2025, 08:37 PM
                                  • BigTroll
                                    Nichicon PC(M) replacement
                                    by BigTroll
                                    Hello, Iam working on my dads EEC-IV computer from his 94 Lightning Pickup, it has bad nichicon PC(M) 2x47uf 16v and 1 10uf 63v what would be a decent replacement? I noticed Panasonic makes the General purpose NHG series any they are rated to 105c whould those be okay?
                                    also on the bottom left of the board capacitor I see I guess a diode or something, it has no markings and had electrolite under it which i cleaned, did that cap possibly short it out?...
                                    02-21-2021, 11:23 PM
                                  • the_rem
                                    Unknown transformer : how to find a good replacement part ?
                                    by the_rem
                                    Hello guys,
                                    I would like a quite old but still good 800 W ATX PSU to be repaired. The problem was an extremely heavy coil whine coming from the small secondary transfomer on the PCB.
                                    I desoldered it hoping the references on the upper side would allow me to find a adequate replacement part. Sadly the written references drove me nowhere but to the manufacturer (I-MAG). I sent them a message like a bottle in the see asking them to send me a datasheet of the transformer. And... They responded ! I received a kind of datasheet (see attachment) but my competencies do not allow...
                                    04-23-2025, 01:48 AM
