15" Dell saved from the trash
  • Bishop
    • Apr 2009
    • 99
    I pulled a 15" dELL flat panel monitor from the dumpster at work. It looked brand new. I plugged it into a spare pc and the screen flashed for one second and went black, but I could see the screen is still working.
    Never had opened a LCD screen before but wanted to learn. I found one bad radial cap and pulled it. Ordered a set of six 1000uf's at a cost of $5.39 delivered and resoldered a new cap in.
    The monitor works great now.
    After my wife saw this monitor, she wanted it for her pc, because the frame on this LCD is smaller than her old one.
    Total cost for the cap alone was $.18.
    The hard part was getting the LCD monitor apart without breaking it apart.
  • 370forlife
    Large Marge
    • Aug 2008
    • 3112
    Re: 15" Dell saved from the trash
    Brand, series caps used to replace?
    • Krankshaft
      • Jan 2007
      • 2328
      Bottle opener through the vents with a swiss army knife to press the securing tabs is that best way to open these clamshell cases.
      I hope you used a low ESR cap and not a bad brand or General Purpose one.
      • Borse2008
        by Borse2008
        • There’s
        07-15-2025, 04:55 AM
      • Bowline
        by Bowline
        06-11-2025, 10:13 AM
      • DanPoka
        by DanPoka
        02-15-2025, 05:05 AM
        by momaka
        03-15-2023, 10:17 PM
      • Jesus Coder
        Issues Reviving Old Dell 2408WFPb Monitor
        by Jesus Coder
        I have been having some difficulties reviving an old Dell 2408WFPb PC monitor that I received for free. When I first acquired it, the backlights of the display were on but alas no image was showing. After extensive research on the topic, I went ahead and purchased a new t-con board for the monitor. After installing the board, I was then presented with a new screen that was half black and half green (more so black). I have been unable to figure out what to do next as I have limited knowledge of display electronics. Might anyone on this forum have an idea of what may...
        06-25-2023, 02:33 PM
