Comparing ripple current on capacitors with different temperature rating
  • Y. Signal
    • Apr 2018
    • 77
    • Spain
    Hello. I'm looking for good quality general purpose caps rated at 105 C. After reading this forum I have concluded that these ones are good:
    - Rubycon PX
    - Chemi-con KMG
    The problem is that the datasheets have ripple current data at 105 C while the ripple current data I have from the old capacitors is rated at 85 C. How can I know if the capacitor is appropiate without having ripple current ratings at the same temperature?
    • 31289
    Re: Comparing ripple current on capacitors with different temperature rating
    temperature effects life, not ripple.
    dont overlook rubycon YXF
    • Y. Signal
      • Apr 2018
      • 77
      • Spain
      Although Rubycon YXF capacitors appear as GP in the Rubycon catalog they are in the low ESR category. I'm looking for standard GP caps.
      Are you sure of that? in the Chemi-con SME datasheet there is a Ripple Current Multiplier for Ambient Temperature. I can't find that data in Rubycon datasheets.
      If the temperature doesn't effect ripple, are Rubycon PK way superior to Rubycon PX? both Standard GP, 85 C and 105 C respectively. PK would have considerably higher ripple current.
        • 31289
        they are just bordering on low - i use them for GP applications.
        i dont have pk or px datasheets in front of me,
        but i have noticed in the past that 85' caps can have higher ripple than 105' - having said that, lower esr allows for higher ripple.
        so your fighting a losing battle trying to get high ripple AND high esr.
        • Y. Signal
          • Apr 2018
          • 77
          • Spain
          Maybe although ESR is not affected by ambient temperature it can affect the ripple current that the capacitor can manage?
          I'm looking for 105 C general purpose not low-esr capacitors that are slightly better than these ones: Chemi-con SME, Nichicon VX and Rubycon CE W.
          Ripple current for 100uF 16V:
          Nichicon VX(M): 160
          Chemi-con SME: 180
          Possible alternatives:
          Chemi-con KMG: 110
          Rubycon PX: 130
          Rubycon PK: 175
          Rubycon PK seems adequate but it's only 85C. Rubycon YXF is way higher (~ 70%) with 250.
          • Andrew F. Ali
            • Jan 2014
            • 2450
            • Trinidad & Tobago
            What application would you be using these caps that you are asking about? From what I am reading, either you are just guessing or just not sure what you are talking about. You have been given your answer but you still want more. Can't eat your cake and have it at the same time. Excuse me.
            • brethin
              • Dec 2008
              • 1907
              Exactly!
              • PeteS in CA
                • Aug 2005
                • 3583
                • USA, Unsure of Planet
                Assuming the GP part was used appropriately, "general purpose" means the application is not stressful. In other words, any part will work fine.
                A part that is rated for 105C will tend to last longer than an 85C part in an environment that does not exceed 85C.
                A lower impedance (or ESR) part will self-heat due to ripple current less than a general purpose part. But in a general purpose application the self-heating due to ripple current is not going to be very great.
                All in all, you can use a good low impedance part like Nichicon PW or HE, or Nippon Chemicon LXZ or KY or KZE, or Rubycon ZL in a general purpose application and it will perform well. I would suggest the main factors you should look at are rated life, price, and availability. And consider, too, how long you want your device to last. A 5000 hour rated part (which will last much longer at temperatures below the maximum rating) may do as well as a 10000 hour part if the expected life of your electronic device isn't much greater than the expected life of the capacitor.
                Personally, I've had good experience with all the series I listed above and would not hesitate to use any of them in a general purpose application, unless a general purpose part were significantly less expensive.
                YXF is simply one of Rubycon's older (or oldest) low impedance series. Nichicon's PS series is too, sort of, and probably of similar performance. These series are probably especially useful in replacing the output capacitors of switching power supplies that are more than 20 years old. Their performance is similar to that of the original parts, and thus less likely to cause stability issues (which a much lower impedance part might do).
                PeteS in CA
                • Wester547
                  • Nov 2011
                  • 1268
                  • USA.
                  Electrolytic capacitors do have ripple current multipliers which allow them to conduct more ripple current at lower temperatures. The rather elderly but still pertinent KMG datasheet I attached (on page 2) shows the multipliers for lower temperatures (1x at 105ºC and 1.75x at 85ºC). What determines the ripple current multiplier is the maximum permitted core temperature rise, which varies anywhere between 40ºC and the maximum category temperature (85ºC and 105ºC). At low temperatures, for 105ºC capacitors, the maximum permitted core temperature rise can be anywhere from 15ºC to 30ºC, depending on the series and brand. At very high temperatures such as those the capacitors are rated for, the limit is around 5ºC to 10ºC - sometimes even as low as 3ºC for some series (LXZ/LXY/LXV and a few others come to mind, according to NCC).
                  • Y. Signal
                    • Apr 2018
                    • 77
                    • Spain
                    Thank you all for the information, I'm trying to learn how to properly choose the best caps.
                    Some time ago I recapped two Sega Mega Drive consoles with Panasonic FR capacitors and after 1 hour of use they produced video noise. Later I recapped them with Panasonic FC and they worked fine, no problem even using them >4 hours in a row.
                    Since then I've used Rubycon YXF and apparently these capacitors work fine for this application, but I have noticed horizontal interference in a console (similar to this video but not so pronnounced) after 30 minutes to 1 hour of use. I'm not saying the YXF are the cause of this problem, but anyway I want to stay in the safe side using just slightly better caps.
                    Then in this case I suppose the Rubycon PX will be fine. Thanks.
                      • 31289
                      hmm
                      i'd be wanting to hook the console to my tek wvr500
                      • chth96
                        Is it no harm to replace with capacitor without ripple current rating?
                        by chth96
                        When I tried to repair LG 29 inch CRT TV, I found that the ESR value of samyoung SMS capacitor(160v 2.2uf), which is very close to D1879 transistor, is 6 ohm.
                        Judging from above ESR Meter Table,I think It is necessary to replace this sms capacitor.So I visited local electronics shop,and I purchased 160v 2.2uf rubycon YK capacitor.
                        But when I browse through rubycon YK datasheet,I found that there is no ripple current rating for 160v 2.2uf specification. But On the contrary, I found 39 mA ripple current rating for 160v 2.2uf SMS capacitor.
                        Rubycon YK DataSheet (b...
                        04-19-2024, 05:19 AM
                        Surface Mount Fuses Fundamentals Datasheet
                        TE Circuit Protection offers the widest selection of surface-mount fuses available for addressing a broad range of overcurrent protection applications. Helping to prevent costly damage and promote a safe environment for electronic and electrical equipment, our single-use chip fuses provide performance stability to support applications with current ratings from .5A up to 20A.
                        TE Circuit Protection also offers the telecom FT600 fuse for telecommunications applications. This telecom fuse helps comply with North American overcurrent protection requirements, including Telcordia, GR-1089,...
                        10-07-2024, 06:07 AM
                      • quickname
                        Cyberpower 1500AVR UPS repair
                        by quickname
                        I'd like to start out by thanking this forum for providing the info to be able to repair my 15 year old CP1500AVRLCD UPS. Here is all the info I gathered during my trouble-shooting and re-capping.
                        I decided to verify that the batteries were...
                        11-12-2023, 09:57 AM
                      • bauto601
                        KDM 480W PSU upgrade succes! (opinions?)
                        by bauto601
                        Back in 2020 i bought a (2nd hand) compact ATX psu to replace my current one. My PC case only fits very short ATX power supplies so i didn't really have the choice of buying a decent 80Plus unit. The current unit is a modded YoungYear unit that i made a thread about a while ago:
                        A "nice" YoungYear unit? - Badcaps
                        The "new" unit is a KDM-M6480 480W psu, the 480W number is a typical KDM bullshit claim of course, but the 24A rating on the 12V rail seemed reasonable and the "Active PFC" claim gave me a bit of hope that this was going to be decent-ish....
                        12-26-2023, 03:05 PM
                      • Perry Babin
                        Electrolytic cap endurance
                        by Perry Babin
                        From what I've found, the endurance of a liquid electrolytic cap is determined by the loss of electrolyte. If a cap is rated for 1000 hours. That's typically for a straight run test. How would the life vary if the cap is intermittently heated to its rated temperature (105C). Maybe for an hour at a time then cooled back to 30-40C (just a random number). Would the life still be 1000 hours?
                        Does it make a difference in the life expectancy if the cap is heating from ripple current (internal heating) instead of from the external ambient temperature?
                        Why do polymer capacitors...
                        10-18-2025, 05:21 PM
