Replacing 22nF ceramic capacitors on 7805
  • Y. Signal
    • Apr 2018
    • 77
    • Spain
    Hello.
    I have observed that the Sega Mega Drive has 22nf ceramic capacitors in the 7805 regulator input and output, while the L7805CV datasheet recommends the use of 330nF and 100nF, respectively.
    Maybe then it was pricier to use higher value ceramic caps so I wonder if it's a good idea to replace them with these ones.
    This is the circuit: https://emudocs.org/Genesis/mega1.png
    • 31214
    Re: Replacing 22nF ceramic capacitors on 7805
    if the regulator doesnt oscillate then leave them alone.
    btw, your forgetting the total capacitance on the output caused by all the decoupling capacitors across the chips.
    • Y. Signal
      • Apr 2018
      • 77
      • Spain
      That's a good point, thank you. I'll leave the stock capacitors meanwhile they don't fail.
      • Tyran
        Replacing capacitors on a 12v 5000w Pure Sine Inverter .
        by Tyran
        Greetings folks. I darn near blew the heck out of my 12V inverter the other day by connecting it to a 24V battery source. :poof . Well lesson learned...... or maybe not . But in the meantime I have 4 Capacitors that need immediate replacing each rated at 16V 3300uf and 105deg. I saw a break down review You Tube video where the host suggested that the 35V Capacitors were a better choice for manufacturers to use. Another video suggested that replacing capacitors of higher Voltage is fine but that the 3300uf rating should be kept the same. Can someone please clarify what the functional benefits...
        04-22-2022, 08:26 AM
      • yuzupatogik
        Help with replacing Capacitors on Altec Lansing ATP 3
        by yuzupatogik
        I have this old (2004?) Altec Lansing ATP3 and i would like to replace the capacitors. I have identified 34 out of the 36 of them as Samxon GR of various capacities and voltages.
        I can't find datasheets for the Samxon in any of the following variants:
        10000uF 25 v - this one i really want to replace because i suspect it is what causes a dull hum regardless of the volume knob position or if the source is plugged in. I am eyeballing the Rubycon 25PK10000MEFCGC18X35.5 for this purpose. So if i pay a 10x the price part for shipping i might as well go ahead and...
        02-14-2025, 04:11 PM
      • samtron786
        Ceramic capacitors half short circuit or full short circuit?
        by samtron786
        Hello
        two small ceramic capacitors with values 040. Can you tell me
        whether they are half short circuit or full short circuit?
        Thank you
        01-07-2024, 05:20 AM
      • frannyjunk
        Vizio M60-C3 Replacing 1000uF 16V with 1000uF 35V capacitors?
        by frannyjunk
        Hi, my Vizio M60-C3 does not power on. No lights whatsoever. Upon opening up the TV, the power supply board has 4 bulging capacitors. Each is 1000uF 16V. I have read that one can use capacitors of the same uF and higher voltage rating, but is 1000uF 35V capacitor too high of a voltage rating? My local shop only has these higher voltage capacitors so would rather just buy the 35V variety if it is OK to use them.
        Any thoughts if OK to use these higher voltage capacitors?
        11-04-2021, 05:59 PM
      • dragon3x
        After updating motherboard capacitors, what to do next (Asrock K7VT2, SOLTEK SL-75FRN2L)
        by dragon3x
        Hi, I have some 32 bits computer motherboards that need repair, as they fail to
        power on.
        Here are some examples :
        (N.B. "capacitors" indicated here are electrolytic capacitors located in the onboard
        switching supply area).
        (N.B. #2 : I could not find a 3300 microF aluminum-polymer with a higher voltage
        than 6.3 V.)
        1 - Motherboard #1 : this is an Asrock K7VT2 (socket A) that still works well. To put it on test
        I replaced capacitors with aluminum-polymer.
        3300 microF/6.3 V. x 4 replaced by 3300 microF/6.3 V. (KYOCERA...
        03-21-2025, 02:46 PM
