Choosing a Ceramic Multilayer Capacitor
  • John843883
    • Nov 2012
    • 71
    Hi, I need to replace a Ceramic Multilayer Capacitor out of a car battery charger and was wondering which one to select? I've been reading up on those types of capacitors and have found out that they can change depending on applied voltage.
    Here's the deal, I can't find anything related to this in the datasheets for the shortlist I have compiled. Its almost like the manufacturers would rather you didn't know this information.
    The capacitor on the board had failed semi-short (150 ohm) so I can only guess the specs, but it looks to be about 1uF and is on the input of an op-amp. No idea what kind of voltage it see's but the op-amp does run off a 15v rail, its in series with a 4.7r resistor so probably does some RC stuff. The charger enclosure gets quite hot although it is fan cooled.
    I know X7R is the best dielectric I can get in this size, but with manufacturers not publishing the voltage dependent capacitance and me not knowing what the charger subjects this capacitor to I'm having trouble deciding.
    Anyone recognize some of the capacitor series in my shortlist care to point me in the right direction? This list was compiled based on availability in small quantities and current stock, there was a lot more currently out of stock or with massive minimum order quantities.
    tl;dr Which of these capacitors are less likely to deviate in capacitance with applied voltage? The datasheets don't mention it.
    Thanks.
  • PeteS in CA
    • Aug 2005
    • 3583
    • USA, Unsure of Planet
    Re: Choosing a Ceramic Multilayer Capacitor
    Here's something on X7R temperature coefficient from TDK.
    And here's something on X7R voltage coefficient from Vishay.
    PeteS in CA
    • MORETTIGIAN
      Capacitor detached from PCB – RTX 2070 Super Founders Edition
      by MORETTIGIAN
      Title:
      Description:
      During maintenance on an RTX 2070 SUPER Founders Edition, I found a capacitor lying on my desk after reassembly.
      I did not notice it detaching, so I am unsure of its original location on the PCB.
      Procedure performed:
      - Removed backplate
      - Cleaned heatsink and PCB with isopropyl alcohol + soft ESD brush
      - Reapplied thermal compound
      - Reassembled card
      Observed behavior after reassembly:
      - GPU powers on and operates normally under...
      09-18-2025, 12:14 PM
    • chth96
      Is it possible to test small ceramic disc capacitor with analogue meter?
      by chth96
      I read EBOOK of Testing Electronic Component and found that
      "In order to test the small blue resin coated ceramic disk capacitor which has 104 50v specification,it is possible to test this small ceramic capacitor by making use of analogue meter.
      Set to times 10Kohm that has 12v output from the probe to check disorder of ceramic capacitor.
      It is not uncommon that testing result of digital capacitance meter is okay,But It show shorted reading when you check it with analogue meter."
      Is it really possible to test small ceramic disc capacitor with analogue...
      03-09-2024, 10:03 PM
    • NuclearSpartan
      Samsung C32HG70 - Blown Ceramic Capacitor (CP813)
      by NuclearSpartan
      I'm new to this, so I apologize for not providing enough details. Is there anything else I need to mention? I'm trying to learn more about electronic/board repairs and hopefully fix my own.
      The only visible issue on my board is one capacitor, CP813, which appears to be labeled R 221k 2kV (possibly obsolete to B 221k 2kV now). My monitor hadn't shown any prior issues, although it is a few years old. Just before the capacitor popped, there was a high-pitched squeal for 2–3 seconds.
      I don't see any other visible damage anywhere else on the board....
      11-14-2024, 02:32 PM
    • rictechie
      smd ceramic capacitor use in iphones
      by rictechie
      is there a brand of smd ceramic capacitor use in iphones? or they are generics
      07-26-2024, 08:28 PM
    • Prolog
      RTX 3080 FE Identifying capacitor
      by Prolog
      Hi people, I hope this is the correct spot to post this, I'm new to the forum.
      I have an RTX 3080 Founders Edition which has a burnt up capacitor (it was in parallel with another capacitor which appears damaged too), so I am hoping to be able to identify the capacitor values and order replacements.
      I hope these photos make it clear which component I am referring to:
      (yes, the soldering is a bit botched from removing the blown one, I know)
      I have found the board schematic (attached), but there does not seem to be a boardview available. I have never...
      12-01-2024, 08:27 PM
