Leviton LTB60 Timer Switch Bad Cap – Part? Improvement? Suggestions?
  • IthinkIcan
    • Dec 2011
    I need a capacitor for my Leviton LTB60 Timer. The problem is replacing like for like (1 uF 350v) is just a temporary solution, and I'm hoping for a long(er) term solution. Ideally, someone specs out a brand, size etc (best if it was in the bad cap store) so I can replace the capacitor and any other simple modifications presented.
    I think the (design) problem is best described in this guy's youtube video
    https://www.youtube.com/watch?v=BQM4ERy-wpY
    My interpretation of his findings is that the capacitor fails because it's right next to a significant heat source. In the video at 7:29, he says “…they could have used a Ceramic Capacitor…”. Is that one possible solution?
    If it makes any difference, I use the switch to control a bathroom fan (this switch is designed for fans, there's a different cheaper switch if you're just using it for lights).
    1. Would bending the capacitor and resistor away from each other help?
    2. Would slipping a piece of plumbers heat shield (Zoltek Pyron fibers) between the cap and resistor help? Hurt?
    Any help would be greatly appreciated!
  • KYBOSH
    Leviton SmartlockPro Programmable Electronic Timer Switch With Astronomical Clock Wont Keep Time After Power Outage
    by KYBOSH
    Model number VPT24-16Z.
    https://leviton.com/products/vpt24-16z
    I have 3 of these in my home for over 10 years now and Im planning on replacing them as I lean towards a Philips Hue home setup.
    They are great units but they lost the ability to keep/store the time and settings after power outages and brown outs.
    I knew it was a battery in there somewhere but never got around to looking into it.
    Well an opportunity came for me to remove this from its home in my wall so I disassembled it to see what was going on.
    I found a 3.6V LIR1632 battery spot...
    07-31-2024, 09:37 PM
    Acer Switch Switch V 10 SW5-017P Hybrid (2-in-1) V 10 Specification for Upgrade or Repair
    This specification for the Acer Switch Switch V 10 SW5-017P Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Switch V 10 SW5-017P boardview and Switch V 10 SW5-017P schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
    09-06-2024, 05:30 AM
  • Natob82
    Micro Momentary Push Switch?
    by Natob82
    Great to be here! I'm a newbie here trying to find a "micro", momentary push switch to repair a Sony "clamshell" video walkman. This micro switch has long since discontinued by Sony, however I hope there are third-party switches of the same size and functionality that I might be able to source to play the same role. The purpose of this switch is to tell the video walkman that the user has activated the mechanical tape eject button, turning that physical action into an electronic signal that tells the tape transport mechanism to open so one can load or eject a video tape. I...
    12-21-2022, 05:22 AM
  • grimacelord
    NEC TurboExpress On/Off Power Switch Replacement Help
    by grimacelord
    I've been working on a NEC TurboExpress and I accidentally got the plastic inside the power ON/OFF switch too hot while doing other repairs and melted it. At first, it would still power on when sliding the switch, but you had to really press inward while sliding to get it to work.
    I removed the switch component and tried to gently melt the plastic back so it would work more reliably and all I managed to do was make it worse.
    I need to find a replacement On/OFF switch for this, but having some trouble figuring out which kind of switch I need....
    11-09-2023, 09:49 AM
  • SluggerB
    Help making a switch work the opposite way with a relay
    by SluggerB
    I have a very small float switch, I'm using in a very small tank. It only fits in one way. Link https://www.amazon.com/uxcell-Switch.../dp/B07DZ1J2GB
    I want the switch to be open when the water is high, and closed when the water is low. Unfortunately it works the opposite. And since this switch is designed to be underwater, it's all sealed up, there is no taking it apart or hacking it up.
    It will be driving a water pump, basic idea, when the water is low, switch closes, which turns on water pump, when enough water is in the tank, float switch floats,...
    02-07-2025, 07:57 PM
