Leviton SmartlockPro Programmable Electronic Timer Switch With Astronomical Clock Wont Keep Time After Power Outage
  • KYBOSH
    • Oct 2011
    • 581
    • Unknown
    Model number VPT24-16Z.
    https://leviton.com/products/vpt24-16z
    I have 3 of these in my home for over 10 years now and Im planning on replacing them as I lean towards a Philips Hue home setup.
    They are great units but they lost the ability to keep/store the time and settings after power outages and brown outs.
    I knew it was a battery in there somewhere but never got around to looking into it.
    Well an opportunity came for me to remove this from its home in my wall so I disassembled it to see what was going on.
    I found a 3.6V LIR1632 battery spot welded and nestled in there.
Name:	2024-07-31 23.10.29.jpg
    I think i will replace all the batteries and put them up to give them a good home.
    This is good excuse to get a good LiON spot welder i have been meaning to procure.
    • 31256
    those come with the tabs on them - a spot welder will generate too much heat in something that small
    if it was me i'd fit a socket/holder anyway
    • KYBOSH
      • Oct 2011
      • 581
      • Unknown
      It maybe possible to fit a holder in here but I think these werent designed to last a lifetime and thus no one would think the end user would attempt to replace the battery.
      Alternatively I could run a wire from the leads to holder which resides off the PCB. Then it would be semi servicable without the need to totally disassemble the unit every 5 years.
Name:	2024-08-01 00.26.38.jpg
      • CapLeaker
        Leaking Member
        • Dec 2014
        • 8340
        Doesn't have to be a coin cell. Here in Canada we can't get readily replacement Li-Ion coin cell with tabs, unless one is willing to fork over $100. Since then, I modify the battery to whatever works for me and can get cheap batteries for. I've done anything from swapping out batteries to put coin cell holders and regular CR2032's and installing a small flat pouch battery. As long as there is room, go for it.
          • 31256
          those arent 3v, they are 3.6v rechargeable.
          • CapLeaker
            Leaking Member
            • Dec 2014
            • 8340
            So is a small Li-Ion pouch battery. Like I said, anything that fits goes in there. Off course you have to see if it is rechargeable circuit or not, then choose accordingly.
            • subroto
              Programmable and non-programmable SIO list
              by subroto
              ene kb9012 programmable
              ene kb9016 programmable
              ene kb9018 programmable
              ene kb9022 programmable
              ene kb9028qc programmable
              ene kb9010 programmable
              ene kb3930qf/b1 programmable
              ite it8585e programmable
              ite it8586e programmable
              ite it8985e programmable
              ite it8587e programmable
              ite it8522 programmable
              ite it8987e programmable
              ite it8589 programmable
              ite IT8380E programmable 192kb
              ite IT8380VG programmable 192kb
              ite IT8995E-128 programmable
              ite it8886H...
              01-13-2018, 09:15 AM
            • DeanWy
              WD Sentinel DS5100 (NAS) boot issues
              by DeanWy
              I have a Western Digital Sentinel DS5100 NAS system which has stopped working. It has dual BIOS. I bought the system second hand with an already broken primary BIOS (it rebooted multiple times until second BIOS was used).
              It worked until recently. The system was idle in Windows Server 2012 and a BSOD occurred, I think it was 'critical process died'. Thereafter it didn't boot, it just sat there with no video output and fan speed at 100% (there's a proprietary Windows driver by WD which controls the fan, outside of that it always runs at 100%).
              There...
              07-30-2024, 04:13 AM
            • Amin89
              Bypass timer apc bx650ci
              by Amin89
              How to disable the timer on the APC BX650CI-MS UPS, because it shuts down every 15 minutes even though the battery is still full....
              10-18-2025, 09:01 AM
              STM32F103C8, STM32F103R8, STM32F103V8, STM32F103T8, STM32F103RB, STM32F103VB, STM32F103CB, STM32F103TB Datasheet
              The STM32F103C8, STM32F103R8, STM32F103V8, STM32F103T8, STM32F103RB, STM32F103VB, STM32F103CB, STM32F103TB medium-density performance line family incorporates the high-performance Arm Cortex-M3 32-bit RISC core operating at a 72 MHz frequency, high-speed embedded memories (Flash memory up to 128 Kbytes and SRAM up to 20 Kbytes), and an extensive range of enhanced I/Os and peripherals connected to two APB buses. All devices offer two 12-bit ADCs, three general purpose 16-bit timers plus one PWM timer, as well as standard and advanced communication interfaces: up to two I2Cs and SPIs, three USARTs,...
              10-07-2024, 04:40 AM
            • Storyteller12
              Need help picking 12v timer!!
              by Storyteller12
              I need a 12v timer that cuts on when 12v applied (when door is opened) and cuts off after 2 minutes even if he door stays open with the 12v trigger. And resets when door is closed.
              The ones I see tend to start the timer when powered down. (Momentary switch)
              Thanks in advance
              09-05-2022, 07:24 AM
