Replacing a Capacitor in Asrock G31M-S
  • Quickgold
    • Apr 2018
    • 5
    • Venezuela
    Hi I'm fixing my old g31m-s and I'd remove 5 blown capacitors, but I made a little mistake and I don't know where the 16v 470mf capacitor goes in this mobo (in this mobo only use a capacitor with these characteristics), I looking for a pic, a scheme or a help about it...thanks!
  • Sparkey55
    • Jan 2010
    • 1523
    Re: Replacing a Capacitor in Asrock G31M-S
    Most photos of that motherboard are taken from the topside looking down. That makes it very difficult if not impossible to see enough or any printing on the sides of the caps. i suggest that you put your multimeter in continuity mode and put one probe in one of the +12 (YELLOW) connectors on the main power socket (20 or 24 pin) that is on the board and the other probe on the +POSITIVE cap holes one by one until you find either the lowest resistance or a BEEP. YMMV.
    • Sparkey55
      • Jan 2010
      • 1523
      You state that you removed 5 caps in total. How many 470uf 16V did you remove? And what are the other 4 caps?
      • Quickgold
        • Apr 2018
        • 5
        • Venezuela
        Only one, four are 6.3v 1000mf, in this mobo only one is 16v 470mf (there are another four 16v but with 1000mf near the cpu)
        I did remove:
        1- 16v 470mf
        4- 6.3v 1000mf
        • kaboom
          "Oh, Grouchy!"
          • Jan 2011
          • 2507
          Asrock used GSC/Evercon for lots of the 1000u 6.3v units. Actually, any/all evercons should go.
          Don't forget that Asrock marks the positive with a half-circle, not the negative! Replace a few at a time- easy to shotgun them and put em in backwards. Ask me how I know.
          Caught it before applying power, and did not cause a "kaboom."
          If it actually requires a 16v part, it'll be tied to the +/- 12v supply.
          "pokemon go... to hell!"
          EOL it...
          All style and no substance.
          guilty,guilty,guilty,guilty!
          guilty of being cheap-made!
          • Quickgold
            • Apr 2018
            • 5
            • Venezuela
            Thanks guys! I will try the second round on monday and I will tell how I go.
            • Quickgold
              • Apr 2018
              • 5
              • Venezuela
              Hi folks I didn't hold it until tomorrow and I replaced the capacitors following your advices....and success..by the moment this PC is alive, is alive, is alive ....Thanks!
              • MORETTIGIAN
                by MORETTIGIAN
                Title:
                Description:
                Procedure performed:
                - Removed backplate
                - Reapplied thermal compound
                - Reassembled card
                09-18-2025, 12:14 PM
              • chj4591
                asrock h410m-hdv value of the mlcc capacitor
                by chj4591
                asrock h410m-hdv
                I wonder the resistance value of the mlcc capacitor between atx24 pin and usb3.0.
                03-08-2025, 06:47 AM
              • Ibod
                Corsair cx600 psu & ASRock B450Pro4 mobo wont start
                by Ibod
                HI I have a PC using a Corsair cx600 psu & ASRock B450 Pro4 mother board that won't power on after a shutdown (replaced a dead drive in a raid array) Not the boot drive.
                With most things unplugged, including the 24 pin ATX connector, but not the ATX12v to cpu, I have +5.01V on the +5vsb pin 9 from the PSU. When I plug the 24 pin back in to the mobo, the +5vsb fluctuates between 1.1v & 1.9v.
                Not sure where to go from here ?
                Is the PSU at fault or is the mobo causing the problem
                Look forward to any help :-)
                If I plug the 24...
                02-08-2023, 11:00 AM
              • chth96
                by chth96
                12-22-2023, 04:34 AM
              • chth96
                by chth96
                06-02-2024, 07:31 PM
